Pneumatics Question
Old May 25th 10, 05:47 PM posted to rec.aviation.soaring
sisu1a
Default Pneumatics Question
. *Replaced the connector this year.
- the VariCalc has connections for all three lines; the Winter
mechanical connects to TE and capacity. *A problem in static shouldn't
affect both instruments.
Faulty multi-connectors can also cause your described symptom as well.
Check the O-rings well, and silicone grease is your friend.
Hmmm, this puts possible tailboom static issues back on the map and
your VariCalc could be cross-talking that or an internal pitot leak
error to your Winter. Run it once with cockpit static before getting
too fancy with time consuming ground testing. It's real easy and you
get to fly... Your vario isolation test will also be useful here, I
suggest unhooking (plug loose lines!) the VariCalc first.
-Paul
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Question re CNX-80 ROBIN FLY Instrument Flight Rules 6 April 15th 04 04:05 PM
Question about KLN-89B Casey Wilson Instrument Flight Rules 9 March 8th 04 08:07 PM
