#21
Get rid of the 4-way connector. *They are unreliable, sometimes
causing cross-talk between paths. *For peace of mind, use separate connectors. He mentioned it's a 5 way (although only 4 ports are currently being used) in another post, which I mean to take is a Winter unit. I've personally had good luck with those but I still prefer the positive locking threaded compression connection of my 4 way PZL version. I've had no leaks with either though, nor any crosstalk (ahem- well just be sure you didn't x-thread the PZL unit back together on after you show it off just before takeoff... heh.) Only problems I've heard of with the quick connects are leaks when the stock O-rings are old/crusty, which is an easy inspection/replacement (spend the extra $.12 on Viton!). While crosstalk is possible on the PZL 4-way with it's compression loaded seals, on the Winter 5-way there is no *real chance of it as the o-rings form a male seal at least 1/4" into the female sockets, effectively isolating the individual lines from each other in case of seal failure, even with dual seal failure. Rubber is not ageless... and again, silicone (spray, applied via cotton swab) is your friend, same for the probe/socket... It's also unlikely a probe connection problem since it is not a double- probe and I feel safe to assume the probe gets taped at each assembly of course. Borrowing a probe from another ship will help isolate any problems with the probe itself it It winds up being suspect. I may just have tunnelvision but really I think an old vario (with aged internal seals...) that has pitot and TE seems more suspect of crosstalk issues than a new Winter quick connect or probe performance issues... Slightly OT, I like to use these to seal pneumatic instrument hoses on barbs: http://www.jollygerman.com/products/goats/rings.shtml cheap, last bout 5yrs and gives a uniform 360deg seal (UNlike zipties...) that is easily future-accessed with no damage to hose/barb. Got idea from Borgelt but it took me a while to figure out what these little green rubber Cheerio things were *really* used for... OUCHY!!! -Paul |
![]() It's also unlikely a probe connection problem since it is not a double- probe and I feel safe to assume the probe gets taped at each assembly of course. Borrowing a probe from another ship will help isolate any problems with the probe itself it It winds up being suspect. The Brunswick socket won't have any internal seals. Just one tube inside another. Tape is unreliable. A short length of silicon tube tightly fitted over the joint is better. If the tube can stay in situ in the trailer then wire it or castrate it with a couple of Cheerios and leave it well alone. I may just have tunnelvision but really I think an old vario (with aged internal seals...) that has pitot and TE seems more suspect of crosstalk issues than a new Winter quick connect or probe performance issues... Seems the first port of call for an elimination exercise. I await some more real data with fascination. |
Whee ! Looks like I'm in for some fun this coming weekend, trying to
figure out what's leaking. I'll probably fly it in the daytime and try to test it during the evening, or bring the panel home to test the varios. I think I was happier before I asked the question... oh well, test it out and get it working nicely. Thanks to all for the information and advice; I'll report back when I figure it out. -John |
I've gone over the tubing looking for leaks and it all seems patent.
I pulled everything apart, lubed and reconnected and it's looking good (including the much-maligned quick-connector). Unfortunately, I haven't had a chance to fly it to find out if the tubing was my problem or if it's the instruments (but BOTH varios behaving badly the same way seems to indicate that it's not the instruments). On the plus side, one off my club's members is a licenced instrument mechanic and he's said he'll take a look at my setup when we can get together. Hopefully that'll get it fixed. Now, is there some way that I can use this as an excuse to convince my wife that the "mistress" needs a panel upgrade? |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question re CNX-80 | ROBIN FLY | Instrument Flight Rules | 6 | April 15th 04 04:05 PM |
Question about KLN-89B | Casey Wilson | Instrument Flight Rules | 9 | March 8th 04 08:07 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
