Bob wrote:
Hello, Am not a pilot, but was wondering about this. In commercial aviation, and I guess for private flying also, when directions are given, are they assumed to be True or Magnetic ? Almost everything is magnetic. What do pilots use these days for direction ? I assume a gyro compass of some sort but am not sure. Is this correct ? If so, is this Magnetic or True ? Gyro based direction indicators are set from the magentic compass and are called heading indicators. The true gyrocompasses used in ships are not used in airplanes. I can't believe they spend the effort converting from one to another. Do they ? Yes. Are chart roses they use shown as True or Mag. ? Depends on what you mean by "chart roses". Aviation charts have rings around VOR stations that are magnetic. They also have true NSEW grid lines and lines showing the local magnetic variation. What's in the cockpit ? Do they still have a Mag. compass there ? It is one of the few instruments required by regulation for all airplanes. Any thoughts would be most appreciated. OK, there are more than just floating needle magnetic compasses these days. http://en.wikipedia.org/wiki/Fluxgate_compass Thanks, Bob -- Jim Pennino Remove .spam.sux to reply. |
Vertical Card Compasses vs GPS Compass Display | [email protected] | Soaring | 16 | September 25th 07 06:44 AM |
[ATTN] Jim Weir or anyone knowing about old gyro compasses | B.B. | Home Built | 1 | November 22nd 04 05:49 PM |
Vertical card compasses | Dan Luke | Owning | 13 | March 1st 04 11:23 PM |
Marfa Task areas & directions | chris | Soaring | 1 | December 3rd 03 01:12 AM |
