On Jun 7, 5:42*am, Gary Osoba wrote:
In any event, much of this does run counter to the normal "racing" protocol. E.g., Moffat's final turn at the top of a climb when it is tightened and you accelerate across the thermal core before exiting. I've never understood how you are supposed to do that. I'm *already* circling as tightly as I can at the speed I'm flying! Unless all you're doing is increasing the bank angle while maintaining the same elevator setting, which will make you turn in a bit more and enter a dive. |
On 6/6/2010 7:29 PM, Bruce Hoult wrote:
On Jun 7, 5:42 am, Gary wrote: In any event, much of this does run counter to the normal "racing" protocol. E.g., Moffat's final turn at the top of a climb when it is tightened and you accelerate across the thermal core before exiting. I've never understood how you are supposed to do that. I'm *already* circling as tightly as I can at the speed I'm flying! Do you mean you are flying close to stalling? My glider, and many others, climb better if flown about 5 knots above stall, so I can always tighten my turn if I need to reposition my circle, or take evasive action if another glider gets too close. -- Eric Greenwell - Washington State, USA (netto to net to email me) |
On Jun 7, 7:20*pm, Eric Greenwell wrote:
On 6/6/2010 7:29 PM, Bruce Hoult wrote: On Jun 7, 5:42 am, Gary *wrote: In any event, much of this does run counter to the normal "racing" protocol. E.g., Moffat's final turn at the top of a climb when it is tightened and you accelerate across the thermal core before exiting. I've never understood how you are supposed to do that. I'm *already* circling as tightly as I can at the speed I'm flying! Do you mean you are flying close to stalling? My glider, and many others, climb better if flown about 5 knots above stall, so I can always tighten my turn if I need to reposition my circle, or take evasive action if another glider gets too close. -- Eric Greenwell - Washington State, USA (netto to net to email me) After doing the math on sink rate versus bank angle I realized that there is a reason why I am always 50-100 feet lower than everyone else - I always circle at 45 degrees of bank. In fact you should bank as shallow as possible while staying in the strong lift. Between 30 degrees of bank and 45 degrees the sink rate goes up a lot so you best be sure that the core is really so small that you need to give up the extra sink rate to circle tight. On the tightening up to go through the core, even if your are racked up tight you can usually bank and yank even tighter if you are willing to accept a little downward acceleration since you won't be able to produce enough lift to maintain steady flight. This may in fact be exactly what you are looking to do if you believe there is a REALLY strong core and strong sink beyond the edge of the lift. Your sink rate will go up to a couple of knots, so the core needs to be worth the extra inefficiency and you have to want to accelerate to scoot through the sink, otherwise it's all a waste of energy. I don't generally do it as I more often find widespread lift at the top of a climb. 9B |
On Jun 8, 2:20*pm, Eric Greenwell wrote:
On 6/6/2010 7:29 PM, Bruce Hoult wrote: On Jun 7, 5:42 am, Gary *wrote: In any event, much of this does run counter to the normal "racing" protocol. E.g., Moffat's final turn at the top of a climb when it is tightened and you accelerate across the thermal core before exiting. I've never understood how you are supposed to do that. I'm *already* circling as tightly as I can at the speed I'm flying! Do you mean you are flying close to stalling? My glider, and many others, climb better if flown about 5 knots above stall, so I can always tighten my turn if I need to reposition my circle, or take evasive action if another glider gets too close. Of course I'm a similar amount over the stall speed, and can tighten a little, but nowhere near the halving of the radius that would be required to go through the center of the existing circle. Flying at 45 knots with a 40 knot stall speed (at that G loading) only gives you scope to increase the lift by 25%, not the 100% needed. OTOH it's true that if you've only got a 30 degree bank angle then rolling to 90 degrees bank without changing the AoA will halve the initial turn radius (before you plummet and speed up). From a 45 degree bank you can only decrease the radius to 70% in this way. Maybe it's enough. Hmm. Rolling from 30 degrees to 60 degrees will decrease the turn radius to 58% (pretty close to 50), but still leave half a G worth of vertical lift. Or rolling from 30 degrees to 53 and also pulling 25% more G would halve the turn radius while only accelerating downward at 0.25 G. Yeah, maybe it's doable. But it will have to be good lift in there and no one just ahead of and below you in the thermal (blind spot!) to hit on the way out! |
Physics Quiz Question | Dallas | Piloting | 28 | August 14th 07 02:02 AM |
Pull up a chair and hear me out: | Vaughn | Aviation Marketplace | 0 | February 2nd 06 02:04 AM |
Physics question | Rich S. | Home Built | 62 | September 14th 05 02:05 PM |
Question about center-line push-pull engine configuration | Shin Gou | Home Built | 4 | June 7th 04 05:57 PM |
Glider pull-up and ballast | M B | Soaring | 0 | September 15th 03 06:29 PM |
