Use of 1201 Transponder Squawk for Salt Lake City TRACON
Old June 7th 10, 05:40 PM posted to rec.aviation.soaring
Tim Taylor
Default Use of 1201 Transponder Squawk for Salt Lake City TRACON
On Jun 7, 9:46*am, Mike the Strike wrote:
Flights from Parowan will transition into SLC's area, but also
others. *This leaves us with the situation where you should apparently
change your squawk code as you complete a cross-country task, a
nonsensical proposition for folks who are not talking to controllers.
This needs clarification.
I almost never use 1200 - we have been allocated 0400 by Tucson.
Mike
Mike,
You are correct, the Parowan contest sits on the boarder between ZLC
and ZLA for the most part. If I had a transponder I would likely set
it on 1200 and leave it. We have not heard if ZLA is ready for the
1201 code. The 1200 code will get the same recognition, they just
won't be sure you are a glider. To be honest most of the area we will
be flying does not get great terminal services from either facility
unless you are very high.
1201 VFR Glider Code - Approved PHL-ABE-NY Tracon RL Soaring 0 April 13th 10 07:47 PM
Chicago Tracon, Glider Code 1201 Herb Soaring 1 April 7th 10 12:06 AM
1. GA books, 2. Salt water Lake? doylflier Piloting 0 May 23rd 07 07:49 PM
OT. Weather in Salt lake City? Eduardo K. Piloting 12 May 13th 06 05:34 PM
I'm looking for a pilotshop near San Francisco, Salt Lake City, or Las Vegas Alfa Bravo Piloting 2 March 20th 06 09:00 PM
