On 6/9/2010 8:24 AM, Andy wrote:
Why is that people cannot design software to ignore the ENL record when the glider is not a motor glider? I am often irritated by having to adjust my start time on OLC because it uses the noise level even though I am not a motor glider. When I asked OLC for ENL to be ignored I was asked "how shall we determine your start of soaring flight". I responded "same as for logs that have no ENL record". Nothing changed, it still uses ENL for pure gliders. Andy OLC may use noise level to help determine when you are on tow. On SeeYou, the noise level on my flights drops noticably when I retract the gear, as you would expect. However, it also drops when I get off tow. I suspect that the recorder can pick up the noise of the towplane. Or the slower speed off tow reduces wind noise, though the noise level on tow still is noticably higher than on a final glide flown at towing speed. I am looking at my most recent flight. When I got off tow, the noise went from 60 to 40 on the y axis of the SeeYou noise graph (it went from 250 to 60 when I retracted the gear). |
I checked my last flight, too. It's from my LS8.
When I select "Engine Noise Level" in SeeYou V3.95 all that appears to be shown is a green trace. Close inspection of the barograph trace under high zoom does show a 4 second red dash and a 4 second yellow dash when the tow plane revs up and a 16 second red dash during landing roll out on grass. The tow portion of the trace may have a slightly yellower color, but it's really hard to say. However, when I select "GPS Status" I see a purple trace (which SeeYou labels "Engine/Tow") during the period I was on tow, another purple trace during the period I was thermalling with my gear down (during a low save), but a green trace during the period my gear was down and the spoilers were out just prior to landing. There is no level shown in "GPS Status" - just "GPS Bad", "Engine/Tow", GPS OK", "Circ. Left and "Circ. Right". Seems to be curious behavior, especially if OLC is counting on it for scoring. It's unclear whether it's due to SeeYou or my Volkslogger. -John OLC may use noise level to help determine when you are on tow. On SeeYou, the noise level on my flights drops noticably when I retract the gear, as you would expect. However, it also drops when I get off tow. I suspect that the recorder can pick up the noise of the towplane. Or the slower speed off tow reduces wind noise, though the noise level on tow still is noticably higher than on a final glide flown at towing speed. I am looking at my most recent flight. When I got off tow, the noise went from 60 to 40 on the y axis of the SeeYou noise graph (it went from 250 to 60 when I retracted the gear). |
Bring up the graph of altitudes in SeeYou, and click on "engine noise
level." It will plot sound on a graph. Much easier to read. On 6/9/2010 9:58 AM, jcarlyle wrote: I checked my last flight, too. It's from my LS8. When I select "Engine Noise Level" in SeeYou V3.95 all that appears to be shown is a green trace. Close inspection of the barograph trace under high zoom does show a 4 second red dash and a 4 second yellow dash when the tow plane revs up and a 16 second red dash during landing roll out on grass. The tow portion of the tracemay have a slightly yellower color, but it's really hard to say. However, when I select "GPS Status" I see a purple trace (which SeeYou labels "Engine/Tow") during the period I was on tow, another purple trace during the period I was thermalling with my gear down (during a low save), but a green trace during the period my gear was down and the spoilers were out just prior to landing. There is no level shown in "GPS Status" - just "GPS Bad", "Engine/Tow", GPS OK", "Circ. Left and "Circ. Right". Seems to be curious behavior, especially if OLC is counting on it for scoring. It's unclear whether it's due to SeeYou or my Volkslogger. -John OLC may use noise level to help determine when you are on tow. On SeeYou, the noise level on my flights drops noticably when I retract the gear, as you would expect. However, it also drops when I get off tow. I suspect that the recorder can pick up the noise of the towplane. Or the slower speed off tow reduces wind noise, though the noise level on tow still is noticably higher than on a final glide flown at towing speed. I am looking at my most recent flight. When I got off tow, the noise went from 60 to 40 on the y axis of the SeeYou noise graph (it went from 250 to 60 when I retracted the gear). |
Thanks, Greg. I got to the plot by using View|Graph|Engine Noise
Level. It is certainly easier to read, but it brings up a new question. On tow I have an average noise level of 200. Off tow the noise level goes to 30. Then I lowered the gear, and the noise level rose to 100. The tow and the gear lowered sections are colored purple (meaning Engine/Tow) if you select "GPS Status" for coloring. This is all fine. However, just prior to landing I lower the gear and starting using spoilers. The average noise is now 150 - but this section is colored green, not purple, if you select "GPS Status" for coloring. Something is inconsistent. -John On Jun 9, 1:28 pm, Greg Arnold wrote: Bring up the graph of altitudes in SeeYou, and click on "engine noise level." It will plot sound on a graph. Much easier to read. On 6/9/2010 9:58 AM, jcarlyle wrote: I checked my last flight, too. It's from my LS8. When I select "Engine Noise Level" in SeeYou V3.95 all that appears to be shown is a green trace. Close inspection of the barograph trace under high zoom does show a 4 second red dash and a 4 second yellow dash when the tow plane revs up and a 16 second red dash during landing roll out on grass. The tow portion of the tracemay have a slightly yellower color, but it's really hard to say. However, when I select "GPS Status" I see a purple trace (which SeeYou labels "Engine/Tow") during the period I was on tow, another purple trace during the period I was thermalling with my gear down (during a low save), but a green trace during the period my gear was down and the spoilers were out just prior to landing. There is no level shown in "GPS Status" - just "GPS Bad", "Engine/Tow", GPS OK", "Circ. Left and "Circ. Right". Seems to be curious behavior, especially if OLC is counting on it for scoring. It's unclear whether it's due to SeeYou or my Volkslogger. -John OLC may use noise level to help determine when you are on tow. On SeeYou, the noise level on my flights drops noticably when I retract the gear, as you would expect. However, it also drops when I get off tow. I suspect that the recorder can pick up the noise of the towplane. Or the slower speed off tow reduces wind noise, though the noise level on tow still is noticably higher than on a final glide flown at towing speed. I am looking at my most recent flight. When I got off tow, the noise went from 60 to 40 on the y axis of the SeeYou noise graph (it went from 250 to 60 when I retracted the gear). |
On 2010/06/09 11:56 PM, jcarlyle wrote:
Thanks, Greg. I got to the plot by using View|Graph|Engine Noise Level. It is certainly easier to read, but it brings up a new question. On tow I have an average noise level of 200. Off tow the noise level goes to 30. Then I lowered the gear, and the noise level rose to 100. The tow and the gear lowered sections are colored purple (meaning Engine/Tow) if you select "GPS Status" for coloring. This is all fine. However, just prior to landing I lower the gear and starting using spoilers. The average noise is now 150 - but this section is colored green, not purple, if you select "GPS Status" for coloring. Something is inconsistent. -John On Jun 9, 1:28 pm, Greg wrote: Bring up the graph of altitudes in SeeYou, and click on "engine noise level." It will plot sound on a graph. Much easier to read. On 6/9/2010 9:58 AM, jcarlyle wrote: I checked my last flight, too. It's from my LS8. When I select "Engine Noise Level" in SeeYou V3.95 all that appears to be shown is a green trace. Close inspection of the barograph trace under high zoom does show a 4 second red dash and a 4 second yellow dash when the tow plane revs up and a 16 second red dash during landing roll out on grass. The tow portion of the tracemay have a slightly yellower color, but it's really hard to say. However, when I select "GPS Status" I see a purple trace (which SeeYou labels "Engine/Tow") during the period I was on tow, another purple trace during the period I was thermalling with my gear down (during a low save), but a green trace during the period my gear was down and the spoilers were out just prior to landing. There is no level shown in "GPS Status" - just "GPS Bad", "Engine/Tow", GPS OK", "Circ. Left and "Circ. Right". Seems to be curious behavior, especially if OLC is counting on it for scoring. It's unclear whether it's due to SeeYou or my Volkslogger. -John OLC may use noise level to help determine when you are on tow. On SeeYou, the noise level on my flights drops noticably when I retract the gear, as you would expect. However, it also drops when I get off tow. I suspect that the recorder can pick up the noise of the towplane. Or the slower speed off tow reduces wind noise, though the noise level on tow still is noticably higher than on a final glide flown at towing speed. I am looking at my most recent flight. When I got off tow, the noise went from 60 to 40 on the y axis of the SeeYou noise graph (it went from 250 to 60 when I retracted the gear). Possibly SeeYou is using the descent rate to say - noise is high but I am descending - that's OK. And conversely noise level high and ascending (thermalling with the gear down etc. ) that looks like an engine? Not sure - someone should ask Erazem or Andrej. Bruce --- news://freenews.netfront.net/ - complaints: --- |
Photo of a Newspaper Photo - 1919 Mail | Terry M[_3_] | Aviation Photos | 0 | May 15th 08 04:03 AM |
A Jet Blue Aircraft Landing with Sideway Landing-Gear | Lufthansi | Piloting | 18 | July 19th 06 05:13 AM |
Seeyou NMEA to Winpilot/Seeyou | Jean | Soaring | 4 | June 3rd 06 11:38 AM |
Photo: An S-3B Viking, comes in for a sunset, arrested landing | T. & D. Gregor, Sr. | Simulators | 0 | August 31st 04 10:28 PM |
What does 'Photo Landing' mean on SeeYou analysis? | Stewart Kissel | Soaring | 2 | June 15th 04 06:36 PM |
