photo landing on SeeYou 3.95
Old June 10th 10, 02:55 PM posted to rec.aviation.soaring
Andy[_1_]
Default photo landing on SeeYou 3.95
On Jun 10, 2:16*am, Bruce Hoult wrote:
On any day that has a CIvil Twilight, for a start.
No, that may be used to define the time at which a task will end even
if the glider has not landed, but it does not define a maximum task
time in the context being discussed. Maximum task time would imply a
maximum allowed duration between the time of starting and the end of
the scoring flight.
Andy
Old June 10th 10, 05:16 PM posted to rec.aviation.soaring
Ron Gleason
the scoring flight.
Andy
Rule 10.1.10
Finish closes - At contest sunset time
therefore task end = Finish close
Contest sunset time defined as
Rule 10.1.8
Contest sunset - the CD shall designate a contest sunset time,
which shall be approximately 10 minutes prior to the earliest time of
sunset at the contest site during the period of the contest.
Old June 10th 10, 05:56 PM posted to rec.aviation.soaring
Andy[_1_]
On Jun 10, 9:16*am, Ron Gleason wrote:
Rule 10.1.10
* *Finish closes - At contest sunset time
Rule 10.1.8
* *Contest sunset - the CD shall designate a contest sunset time,
Sure, but what point are you making. What is under discussion is that
SeeYou ended a flight after 2.5 hours because a max task time of 2.5
hours had been defined. It had nothing to do with sunset.
What I was trying to find out was why SeeYou even has a definition for
maximum task time. To that end I asked what set of rules defined a
maximum task time. So far there is no indication that any does.
Andy
Photo of a Newspaper Photo - 1919 Mail Terry M[_3_] Aviation Photos 0 May 15th 08 04:03 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Lufthansi Piloting 18 July 19th 06 05:13 AM
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 11:38 AM
Photo: An S-3B Viking, comes in for a sunset, arrested landing T. & D. Gregor, Sr. Simulators 0 August 31st 04 10:28 PM
What does 'Photo Landing' mean on SeeYou analysis? Stewart Kissel Soaring 2 June 15th 04 06:36 PM
