On Jun 10, 7:55*am, Andy wrote:
On Jun 10, 2:16*am, Bruce Hoult wrote: On any day that has a CIvil Twilight, for a start. No, that may be used to define the time at which a task will end even if the glider has not landed, but it does not define a maximum task time in the context being discussed. Maximum task time would imply a maximum allowed duration between the time of starting and the end of the scoring flight. Andy Rule 10.1.10 Finish closes - At contest sunset time therefore task end = Finish close Contest sunset time defined as Rule 10.1.8 Contest sunset - the CD shall designate a contest sunset time, which shall be approximately 10 minutes prior to the earliest time of sunset at the contest site during the period of the contest. |
On Jun 10, 9:16*am, Ron Gleason wrote:
Rule 10.1.10 * *Finish closes - At contest sunset time therefore task end = Finish close Contest sunset time defined as Rule 10.1.8 * *Contest sunset - the CD shall designate a contest sunset time, which shall be approximately 10 minutes prior to the earliest time of sunset at the contest site during the period of the contest. Sure, but what point are you making. What is under discussion is that SeeYou ended a flight after 2.5 hours because a max task time of 2.5 hours had been defined. It had nothing to do with sunset. What I was trying to find out was why SeeYou even has a definition for maximum task time. To that end I asked what set of rules defined a maximum task time. So far there is no indication that any does. Andy |
Photo of a Newspaper Photo - 1919 Mail | Terry M[_3_] | Aviation Photos | 0 | May 15th 08 04:03 AM |
A Jet Blue Aircraft Landing with Sideway Landing-Gear | Lufthansi | Piloting | 18 | July 19th 06 05:13 AM |
Seeyou NMEA to Winpilot/Seeyou | Jean | Soaring | 4 | June 3rd 06 11:38 AM |
Photo: An S-3B Viking, comes in for a sunset, arrested landing | T. & D. Gregor, Sr. | Simulators | 0 | August 31st 04 10:28 PM |
What does 'Photo Landing' mean on SeeYou analysis? | Stewart Kissel | Soaring | 2 | June 15th 04 06:36 PM |
