#11
On Jun 10, 11:13*am, Andy wrote:
On Jun 10, 7:08*am, Scott Alexander wrote: Sorry for your loss. *I'm glad I got all my diamonds in the days when a camera, barograph, and the word of my observer were all that mattered. Even a person on trial for murder seems to get more "reasonable doubt" than a badge applicant these days. Andy guilty until proven innocent does seem to be the status quo for the FAI. |
On Jun 10, 10:08*am, Scott Alexander
wrote: I received an email stating that my diamond goal flight has been rejected due to a typo on my igc declaration. *Despite the fact that the security was good, all turnpoints rounded ok, and everything else good, it's still rejected. On the IGC declaration where it says "registered ID" *I typed in "SA" because that is my paid-for registered contest ID. *Apparently I should have typed in "N-2429". *So because of this, the flight doesn't count. I was also informed that on page 53 of the March 2010 Soaring magazine, it says (in 8 point font) that you can no longer use your register contest ID. *This really doesn't make a whole lot of sense to me. *The glider type is in question, not the security, date or name even though it's not a handicapped claim! *I only own one aircraft, which can be easily verified through the FAA aircraft registry. So now I am merely trying to figure out the best way to solve this claim. Does anyone have any suggestions of who I might contact to help get this claim to pass? *I would really like to say I did a diamond flight but unfortunately because of this new rule, I can't say I did a diamond flight. As mentioned to Scott offline, there is a formal appeals process that first needs to be followed. More shortly. Cringingly, Erik Mann SSA's FAI B&R Committee |
snip
*Never mind that many igc approved flight recorders do not specifically ask you for this. *My C-302, for instance, prompts one for the "competition ID". *And in competition, this is what the scorer wants in that field (I've asked). There are many in the SSA that would like to see this sorted out. *The obvious place to go is the badge and record committee chairman, who (ahem) is probably reading this and cringing (sorry). *Judy, as you have already guessed, takes the other side of the debate. snip This is a good point, I looked back through the IGC files I have from the 18 meter nationals last year and see a mix of Contest Numbers and N-numbers used in the IGC files. I don't recall any serious issues with this during scoring so I am suspicious that Guy has somehow accounted for this in the Winscore software. I do see most are using the competition ID. I have sent Guy an email for confirmation of if the N number is acceptable in the GLIDERID field and still have the contest number show on the score sheet. If the FAI is going to require the N-number in this field, it only makes sense that we should be either require it be used in our contests or at least allow either to be used so it doesn't need to be change between contest flights and badge flights. Brian C. |
wrote: I received an email stating that my diamond goal flight has been rejected due to a typo on my igc declaration. *Despite the fact that the security was good, all turnpoints rounded ok, and everything else good, it's still rejected. On the IGC declaration where it says "registered ID" *I typed in "SA" because that is my paid-for registered contest ID. *Apparently I should have typed in "N-2429". *So because of this, the flight doesn't count. I was also informed that on page 53 of the March 2010 Soaring magazine, it says (in 8 point font) that you can no longer use your register contest ID. *This really doesn't make a whole lot of sense to me. *The glider type is in question, not the security, date or name even though it's not a handicapped claim! *I only own one aircraft, which can be easily verified through the FAA aircraft registry. So now I am merely trying to figure out the best way to solve this claim. Does anyone have any suggestions of who I might contact to help get this claim to pass? *I would really like to say I did a diamond flight but unfortunately because of this new rule, I can't say I did a diamond flight. Scott It is saddening to see an otherwise valid badge claim rejected because of this IGC/FAI stupidity. But I want to be fair to Judy and others involved in this from the SSA side. And as I've pointed out to Scott before privately, this was not just something buried in fine print in Soaring Magazine. Judy and others have posted on r.a.s about this specific issue (e.g. here http://groups.google.com/group/rec.a...e65a08771f765a) And this is specifically clarified in the latest (2009 revised) Pilot and OO Guide Section 6.3.c. Which unfortunately has the effect of tying Judy's hands on this issue. So your likely most effective line of attack here is to make your next flight count, read the current (i.e. 2009 revised) sporting code and guide carefully and do what Judy has advised clearly in the past -- *always* do a paper declaration after you make the electronic one so that paper declaration will override the electronic one. Doing that will normally cure this and several other common declaration problems. I've recently helped one pilot with advice through to his diamonds and he had gone through all sorts of similar frustrations before, but he was recently saved by doing just that paper declaration. And just so I don't look like I am defending the IGC on this... If the goal of the IGC/FAI was to marginalize soaring badges, to make them look like petty bureaucratic bull****, they are doing a bang-up job. The role of badges will continue to wane, lots of local pilots seem to have little interest in dealing with this anymore. And having a set of badges to your name as proof of skill or accomplishment is replaced for many people by a decent OLC ranking or at least some great OLC flights. There is no proof that the pilot in the cockpit is who is described in the IGC file header, and there is no proof that the logger was installed in the glider claimed in the header, it all relies on the OO being honest. So given that I cannot fathom why IGC bureaucrats care whether the GLIDERID field in the header contains the glider registration or a pilot specific contest ID. If they want to be pedantic for world records then fine, but for badges this is just mind- numbingly stupid bureaucracy. Darryl |
On Jun 10, 10:51*am, Darryl Ramm wrote:
On Jun 10, 7:08*am, Scott Alexander wrote: I received an email stating that my diamond goal flight has been rejected due to a typo on my igc declaration. *Despite the fact that the security was good, all turnpoints rounded ok, and everything else good, it's still rejected. On the IGC declaration where it says "registered ID" *I typed in "SA" because that is my paid-for registered contest ID. *Apparently I should have typed in "N-2429". *So because of this, the flight doesn't count. I was also informed that on page 53 of the March 2010 Soaring magazine, it says (in 8 point font) that you can no longer use your register contest ID. *This really doesn't make a whole lot of sense to me. *The glider type is in question, not the security, date or name even though it's not a handicapped claim! *I only own one aircraft, which can be easily verified through the FAA aircraft registry. So now I am merely trying to figure out the best way to solve this claim. Does anyone have any suggestions of who I might contact to help get this claim to pass? *I would really like to say I did a diamond flight but unfortunately because of this new rule, I can't say I did a diamond flight. Scott It is saddening to see an otherwise valid badge claim rejected because of this IGC/FAI stupidity. But I want to be fair to Judy and others involved in this from the SSA side. And as I've pointed out to Scott before privately, this was not just something buried in fine print in Soaring Magazine. Judy and others have posted on r.a.s about this specific issue (e.g. herehttp://groups.google.com/group/rec.aviation.soaring/browse_frm/thread...) And this is specifically clarified in the latest (2009 revised) Pilot and OO Guide Section 6.3.c. Which unfortunately has the effect of tying Judy's hands on this issue. So your likely most effective line of attack here is to make your next flight count, read the current (i.e. 2009 revised) sporting code and guide carefully and do what Judy has advised clearly in the past -- *always* do a paper declaration after you make the electronic one so that paper declaration will override the electronic one. Doing that will normally cure this and several other common declaration problems. I've recently helped one pilot with advice through to his diamonds and he had gone through all sorts of similar frustrations before, but he was recently saved by doing just that paper declaration. And just so I don't look like I am defending the IGC on this... If the goal of the IGC/FAI was to marginalize soaring badges, to make them look like petty bureaucratic bull****, they are doing a bang-up job. The role of badges will continue to wane, lots of local pilots seem to have little interest in dealing with this anymore. And having a set of badges to your name as proof of skill or accomplishment is replaced for many people by a decent OLC ranking or at least some great OLC flights. There is no proof that the pilot in the cockpit is who is described in the IGC file header, and there is no proof that the logger was installed in the glider claimed in the header, it all relies on the OO being honest. So given that I cannot fathom why IGC bureaucrats care whether the GLIDERID field in the header contains the glider registration or a pilot specific contest ID. If they want to be pedantic for world records then fine, but for badges this is just mind- numbingly stupid bureaucracy. Darryl- Hide quoted text - - Show quoted text - On top of what Darryl said, why does it matter AT ALL what glider the flight was made in? The requirements are the same for a 1-26 as for 28 meter, 60/1 glider. I've OO'd a fair number of badge flights in the last couple years, and don't recall any 'handicap' rating anywhere. |
Guy just got back to me and as usually he is pretty much on top of
this from the contest scoring side. IGC files can have either a a GLIDERID field or a COMPETITIONID feild. The Winscore software checks both for the competition ID. The issue appears to be with some loggers. In looking at a selection of files I have seen either field and some have both. The problem would only occur if the logger only stores a GLIDERID field. It would be interesting to know what what loggers do this but do not store the COMPETITIONID. This would force the pilot to use the GLIDERID for the COMPETITIONID. Brian |
I check the IGC files I had and found of the ones I could check the
C302 and Clearnav and my EW-model D seemed to be the only Loggers that did not have a competion ID. It looked like perhap only the older Cambridge, I am unsure what model did not have a GliderID. This doesn't meant that they can't be configured to have both, I just didn't see them in the IGC files I looked at. here are my results: GLIDERID COMPETITIONID Clearnav X Volkslogger X X Cambridige? X C302 X EW-MR X X EW-mod D X Flarm X X Winpilot X X Zander GP940 X X Brian |
On Jun 10, 10:02Â*am, Wojciech Scigala wrote:
Użytkownik Scott Alexander napisaÅ‚: I want this time to count. Â*Glad you got it approved Evan....anyone else have any suggestions? SC3 (valid 2009 AL0 edition), para 4.2.1.c (declaration content): - glider type, and its registration _or_ serial number _or_ unique NAC-assigned contest number. Are SSA contest IDs unique? Also, SC3 Annex C, para 1.2: "OOs and National Claim Officers are encouraged to take the position that, ensuring the rules are met, their goal is to make awards, not turn them down for minor errors or oversights that do not affect the proof of a soaring performance." An OO's special statement about the glider flown should be enough to solve the case IMHO. -- WojtuÅ›.net SSA contest numbers are unique but they are assigned to a person not a sailplane. Maybe that is the rub. |
![]() SSA contest numbers are unique but they are assigned to a person not a sailplane. Maybe that is the rub.- Hide quoted text - - Show quoted text - Yes I own the rights to SA my contest ID. But suppose my friend let me use his Discus to do the flight, it wouldn't have made a flip of difference of the validity of the flight. Again, the only problem here is that I typed in SA vs. N-2429. So therefor it makes the whole entire claim Invalid. I appreciate the fact that we have dedicated people in this sport who are going provide checks and balances to badges and record claims. I really do appreciate them. It would take the fun out of soaring if somebody set a record using an engine. But this is overkill. I got a few emails today on an appeal process. Hopefully this will get overturned. Diamonds don't grow on trees down here in Memphis....doing the flight again in a club class glider would call for some more good luck. |
On Jun 10, 4:43*pm, Scott Alexander
wrote: SSA contest numbers are unique but they are assigned to a person not a sailplane. Maybe that is the rub.- Hide quoted text - - Show quoted text - Yes I own the rights to SA my contest ID. *But suppose my friend let me use his Discus to do the flight, it wouldn't have made a flip of difference of the validity of the flight. *Again, the only problem here is that I typed in SA vs. N-2429. *So therefor it makes the whole entire claim Invalid. I appreciate the fact that we have dedicated people in this sport who are going provide checks and balances to badges and record claims. *I really do appreciate them. *It would take the fun out of soaring if somebody set a record using an engine. *But this is overkill. I got a few emails today on an appeal process. *Hopefully this will get overturned. *Diamonds don't grow on trees down here in Memphis....doing the flight again in a club class glider would call for some more good luck. I feel your pain Scott. I lost a 500K flight last year, due to a faulty way point file in my logger, that did not show up on the PDA while flying. |
Trying for a Diamond Goal tommorow - water ballast question | Scott Alexander[_2_] | Soaring | 27 | April 29th 10 09:28 PM |
Distance to Goal Flight in Texas | ryanglover1969[_2_] | Soaring | 0 | March 10th 10 09:45 PM |
Diamond D-Jet First Flight | Montblack | Piloting | 5 | April 21st 06 04:00 PM |
Diamond Distance flight plan | 303SAM | Soaring | 6 | April 4th 06 12:21 AM |
PW-5 Diamond Goal Flights | Dick Johnson | Soaring | 2 | November 17th 03 01:44 AM |
