Diamond goal flight rejected due to typo
Old June 11th 10, 11:00 AM posted to rec.aviation.soaring
Wojciech Scigala
Default Diamond goal flight rejected due to typo
Użytkownik Grider Pirate napisał:
On top of what Darryl said, why does it matter AT ALL what glider the
flight was made in? The requirements are the same for a 1-26 as for
28 meter, 60/1 glider. I've OO'd a fair number of badge flights in the
last couple years, and don't recall any 'handicap' rating anywhere.
There should be proves that it was a solo flight and no engine has been
used. Identifying the glider also enables to check flight against club logs.
WojtuÅ›.net
Old June 11th 10, 12:52 PM posted to rec.aviation.soaring
Darryl Ramm
flight was made in? Â*The requirements are the same for a 1-26 as for
WojtuÅ›.net
The only "proof" in many cases it is a solo flight is the OO saying
so. Nothing stops a badge being awarded in a two seater by a solo
pilot. And I doubt clubs or FBO in the USA that has any records that
will catch cases of a (non-student) flying dual.
Again everything comes down to the OO. The OO should be allowed to
state a correction after the flight for the aircraft registration. Its
not like a contest ID incorrectly entered in the IGC file is
practically going to get confused with a USA n-number. The current
anal-retentive current treatment of GLIDERID is pointless and the
impact/annoyance of this is harming promoting the sport of soaring in
the USA. And it is not exactly endearing the IGC or SSA to many USA
pilots.
Darryl
Trying for a Diamond Goal tommorow - water ballast question Scott Alexander[_2_] Soaring 27 April 29th 10 09:28 PM
Distance to Goal Flight in Texas ryanglover1969[_2_] Soaring 0 March 10th 10 09:45 PM
Diamond D-Jet First Flight Montblack Piloting 5 April 21st 06 04:00 PM
Diamond Distance flight plan 303SAM Soaring 6 April 4th 06 12:21 AM
PW-5 Diamond Goal Flights Dick Johnson Soaring 2 November 17th 03 01:44 AM
