On Jun 13, 4:10*pm, Andy wrote:
On Jun 13, 8:44*am, Darryl Ramm wrote: This post repeatedly implies the SSA issues contest IDs to gliders. Can we please get the basic facts right -- Nor once in my post do I make any reference to SSA issuing contest ID's to gliders.. Please read it more carefully before you post comment! Your post was largely about contest numbers *for gliders*, you stated that you are worried about bringing a glider here because the SSA could have issued the same contest number and therefore your glider's contest number won't be unique. It's painful to keep saying this, but I will -- the SSA does not issue contest numbers to gliders. None nada zilch. So, even if cross NAC uniqueness might every be an issue, which it is not, it just does not make sense to talk about a conflict between unique NAC assigned Contest IDs for gliders since the SSA does not issue Contest IDs for gliders. An SSA issued Contest ID is invalid as a Glider ID for any badge or record flight claim. I believe you do understanding this, but your writing about in a way that is not clear and implies to a reader that the SSA does issues contest IDs to gliders. And the root issue here is that many people don't get the subtle issue around Glider ID and Contest ID so yes I'm being overly picky on that clarity. --- And recapping the real issue, again, I'm fine with a rule that says the SSA issued Contest ID is not to be used when a Glider ID is required (because well, it is just not a Glider ID, no argument from me there) - but we need some common sense approach here with the IGC agreeing to allow something like just letting the OO have a way of noting a correction from an incorrect Contest ID or pilot name entered into an electronic flight recorder. The OO witnessed what glider the pilot flew, simply allow the Glider ID (and pilot name if also messed up) header data to be overridden (but obviously not any declared turn points) post flight by a note from the OO -- that solves this problem and others and introduces no additional practical issues. For world records etc. I have less sympathy for pilots who do not read and understand the rules in minute details, but at least for badges, time for some sanity. Darryl |
Trying for a Diamond Goal tommorow - water ballast question | Scott Alexander[_2_] | Soaring | 27 | April 29th 10 09:28 PM |
Distance to Goal Flight in Texas | ryanglover1969[_2_] | Soaring | 0 | March 10th 10 09:45 PM |
Diamond D-Jet First Flight | Montblack | Piloting | 5 | April 21st 06 04:00 PM |
Diamond Distance flight plan | 303SAM | Soaring | 6 | April 4th 06 12:21 AM |
PW-5 Diamond Goal Flights | Dick Johnson | Soaring | 2 | November 17th 03 01:44 AM |
