"Steven P. McNicoll" wrote
"BUFDRVR" wrote I was making the point that the BUFF has an FAA waiver when taking off, but not landing. Trying to show how these military waivers are not always as clear cut as a blanket coverage. What is the waiver for and why was it issued? Most waivers are for safety. Probably a B-52 with a good load needs all the speed it can get on climbout. |
![]() "S. Sampson" wrote in message news:gOAQb.6579$ce2.98@okepread03... Most waivers are for safety. Probably a B-52 with a good load needs all the speed it can get on climbout. But a waiver isn't needed for safety. The regulation permits an aircraft, civil or military, to be operated at the minimum safe airspeed if the minimum safe airspeed for any particular operation is greater than the maximum speed otherwise permitted. § 91.117 Aircraft speed. (a) Unless otherwise authorized by the Administrator, no person may operate an aircraft below 10,000 feet MSL at an indicated airspeed of more than 250 knots (288 m.p.h.). (b) Unless otherwise authorized or required by ATC, no person may operate an aircraft at or below 2,500 feet above the surface within 4 nautical miles of the primary airport of a Class C or Class D airspace area at an indicated airspeed of more than 200 knots (230 mph.). This paragraph (b) does not apply to any operations within a Class B airspace area. Such operations shall comply with paragraph (a) of this section. (c) No person may operate an aircraft in the airspace underlying a Class B airspace area designated for an airport or in a VFR corridor designated through such a Class B airspace area, at an indicated airspeed of more than 200 knots (230 mph). (d) If the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed in this section, the aircraft may be operated at that minimum speed. |
True. But normally 250 is adhered to for civilian types in the U.S. until
ATC is advised of the necessary speed and authorizes it. I currently teach the MD-80 and on those that can go up to 159,500# for Take Off the minimum maneuvering speed for a clean wing is 260 KIAS. We teach to set 250 in the autothrottle window for takeoff. Bank angle 15 is also set for takeoff. 250 is OK with 15 degrees of bank. When ATC agrees to the higher speed (for aircraft separation purposes), we set the higher speed and then increase bank angle to 30 degrees. If an immediate turn is mandatory for safety we can extend leading edge slats (which reduces maneuvering speed by about 40 knots) and go to 30 degrees of bank at 250. B-58 Hustler History: http://members.cox.net/dschmidt1/ - " Most waivers are for safety. Probably a B-52 with a good load needs all the speed it can get on climbout. But a waiver isn't needed for safety. The regulation permits an aircraft, civil or military, to be operated at the minimum safe airspeed if the minimum safe airspeed for any particular operation is greater than the maximum speed otherwise permitted. § 91.117 Aircraft speed. (a) Unless otherwise authorized by the Administrator, no person may operate an aircraft below 10,000 feet MSL at an indicated airspeed of more than 250 knots (288 m.p.h.). (b) Unless otherwise authorized or required by ATC, no person may operate an aircraft at or below 2,500 feet above the surface within 4 nautical miles of the primary airport of a Class C or Class D airspace area at an indicated airspeed of more than 200 knots (230 mph.). This paragraph (b) does not apply to any operations within a Class B airspace area. Such operations shall comply with paragraph (a) of this section. (c) No person may operate an aircraft in the airspace underlying a Class B airspace area designated for an airport or in a VFR corridor designated through such a Class B airspace area, at an indicated airspeed of more than 200 knots (230 mph). (d) If the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed in this section, the aircraft may be operated at that minimum speed. |
![]() "Darrell" wrote in message news:qGBQb.65209$XD5.36267@fed1read06... True. But normally 250 is adhered to for civilian types in the U.S. until ATC is advised of the necessary speed and authorizes it. I currently teach the MD-80 and on those that can go up to 159,500# for Take Off the minimum maneuvering speed for a clean wing is 260 KIAS. We teach to set 250 in the autothrottle window for takeoff. Bank angle 15 is also set for takeoff. 250 is OK with 15 degrees of bank. When ATC agrees to the higher speed (for aircraft separation purposes), we set the higher speed and then increase bank angle to 30 degrees. If an immediate turn is mandatory for safety we can extend leading edge slats (which reduces maneuvering speed by about 40 knots) and go to 30 degrees of bank at 250. ATC cannot authorize or require deviation from the 250 KIAS speed limitation below 10,000 MSL, except within airspace delegated to Houston approach control, and then only for departing aircraft. |
"Steven P. McNicoll" wrote...
ATC cannot authorize or require deviation from the 250 KIAS speed limitation below 10,000 MSL, except within airspace delegated to Houston approach control, and then only for departing aircraft. ....and the Houston experiment is about to end: ALPA OPERATIONS BULLETIN 2004-01 SUBJECT: Houston (IAH) High Speed Departure Test Program BACKGROUND: In December 1997 the FAA began a field test at Houston Intercontinental Airport (IAH) to determine whether the 250-knot speed restriction for aircraft operating below 10,000 MSL within Class B airspace could be increased or eliminated. Shortly after this test began, ALPA identified to FAA and industry representatives numerous safety concerns including Class B Airspace excursions, increased mid-air collision risk, and increased potential for catastrophic bird strikes. Our concerns were highlighted by the damage sustained by a Delta 727 on departure from IAH on January 9, 1998. After lengthy discussions and some valid scientific analysis, FAA Flight Standards, in July 2003, determined that it couldn't quantify the risk presented by birds. Based on the data from the test, the FAA is unable to design a risk analysis that will prove the safety of the operation. The well-documented increase in the wildlife populations of large flocking birds was a determining factor in this finding. The FAA has decided to discontinue the test. Once internal FAA coordination is complete, ATC will no longer be authorized to allow aircraft to exceed 250 KIAS below 10,000 feet MSL. However, this internal coordination must not delay pilots from immediately discontinuing participation. RECOMMENDATION: Therefore, effective immediately, pilots should not accept an ATC clearance for, or request ATC authorization to, exceed 250 knots below 10,000 feet in Houston Class B Airspace. Contact the ALPA Engineering and Air Safety Department at 800-424-2470 with questions and comments. Captain John Cox Executive Air Safety Chairman January 16, 2004 |
Most waivers are for safety. Probably a B-52 with a good load needs all the speed it can get on climbout. Exactly. A BUFF at 488,000 pounds GW, below 250 KIAS would be a handful. BUFDRVR "Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips everyone on Bear Creek" |
![]() "BUFDRVR" wrote in message ... Exactly. A BUFF at 488,000 pounds GW, below 250 KIAS would be a handful. A waiver for safety serves no useful purpose. |
"BUFDRVR" wrote Exactly. A BUFF at 488,000 pounds GW, below 250 KIAS would be a handful. A waiver for safety serves no useful purpose. So what's your point? That regulations should be written, and you should follow them, even if it kills you, or makes the operation dangerous? |
![]() "S. Sampson" wrote in message news:j3CQb.6582$ce2.6307@okepread03... So what's your point? That regulations should be written, and you should follow them, even if it kills you, or makes the operation dangerous? The point is a waiver of the 250 KIAS maximum speed below 10,000 MSL specified in FAR 91.117(a) for safety reasons accomplishes nothing because FAR 91.117(d) permits an aircraft to be operated at the minimum safe airspeed if the minimum safe airspeed for any particular operation is greater than the maximum speed otherwise permitted. It would be waiving a rule that didn't have to be followed anyway. |
It would be waiving a rule that didn't have to be followed anyway. I see. You're trying to bring logic into a tort arena. Good for you... |
FA: Flying Aviation Videos - Concorde - Just Planes - Military - B-52, F/A-18, Etc | Robert | Aviation Marketplace | 0 | August 29th 04 08:27 PM |
Updated List of Military Information-Exchange Forums | Otis Willie | Military Aviation | 0 | December 29th 03 02:20 AM |
List of News, Discussion and Info Exchange forums | Otis Willie | Military Aviation | 0 | November 14th 03 05:01 AM |
08 Nov 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | November 9th 03 01:51 AM |
RUSSIAN WAR PLANES IN ASIA | James | Military Aviation | 2 | October 1st 03 11:25 PM |
