Heading Hold Gyro.
Old June 15th 10, 06:05 PM posted to rec.aviation.homebuilt
Peter Dohm
Default Heading Hold Gyro.
"brian whatcott" wrote in message
I expect, like me, you thought you knew what heading hold gyros were all
about? If you haven't been around model helicopter enthusiasts lately, you
have no idea! Try googling 'heading hold gyro'.
It turns out, that radio control modelers stick a heading hold gyro on
their model helicopter and hook it to a fast servo that modulates the tail
rotor pitch. The device takes over when a rotate ("pirouette') command
stops, and stops the tail dead on that heading - fast, and holds it
against wind-drift and weather cock effects.
The HH gyro runs $40 to $150 and a fast (digital) servo might add another
$40 on it.
Think of the possibilities for a heading stabilize function in a
homebuilt!
A HH gyro driving a big servo, controlling a servo tab on the rudder.
Something similar could be arranged for pitch hold (a sort of super cheap
altitude hold/augment?)
Brian W
One of the avionics makers, Bendix IIRC, had a system available about 25 or
so years ago that used an air stream across a pair of resistance elements,
or two pairs of resistance elements for a two axis autopilot. Basically,
each pair of elements was an uninsulated resistor on each side of the
airstream for heading hold and top and bottom for pitch hold--not really the
same thing as altitude hold but possibly usefull in smooth VFR conditions.
AFAIK, the system worked because the resistance of each element (for most
materials) tends to increase with rising temperature and decrease with
falling temperature--so that the system can work by comparing the
resistances with little regard for the actual resistance values. My best
recollection is that the device could also maintain a standard rate turn.
I only vaguely recall that there may have been an article in one of the
homebuilding magazines--possibly in the early 1980s.
Peter
Old June 15th 10, 06:26 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
$40 on it.
homebuilt!
Brian W
Peter
Electro-Fluidic Autopilot.
Sport Aviation -
May '78
Preliminary Report-Development of a Poor Man's VFR Autopilot/Don Hewes
March '79
Update On The Poorman's Autopilot... by Donald E. Hewes
February '80
Autopilot System For Homebuilt Airplanes... by Don Hewes
August '80
Fine Tuning The Electro-Fluidic Autopilot.. . by Doug Garner
April '81
Muscle For Your Homebuilt Autopilot... by Don Hewes
November '81
A Magnetic Heading Reference For The Electro Fluidic Autopilot,Part I
by Doug Garner
December '81
Magnetic Heading Performance For The Electro Fluidic Autopilot
Part 11 . . , by Doug Garner
Richard Lamb
Old June 16th 10, 11:36 PM posted to rec.aviation.homebuilt
Peter Dohm
"cavelamb" wrote in message
m...
you have no idea! Try googling 'heading hold gyro'.
tail rotor pitch. The device takes over when a rotate ("pirouette')
command stops, and stops the tail dead on that heading - fast, and holds
it against wind-drift and weather cock effects.
another $40 on it.
homebuilt!
cheap altitude hold/augment?)
Brian W
or so years ago that used an air stream across a pair of resistance
elements, or two pairs of resistance elements for a two axis autopilot.
Basically, each pair of elements was an uninsulated resistor on each side
of the airstream for heading hold and top and bottom for pitch hold--not
really the same thing as altitude hold but possibly usefull in smooth VFR
conditions. AFAIK, the system worked because the resistance of each
element (for most materials) tends to increase with rising temperature
and decrease with falling temperature--so that the system can work by
comparing the resistances with little regard for the actual resistance
values. My best recollection is that the device could also maintain a
standard rate turn.
Peter
Sport Aviation -
May '78
March '79
February '80
August '80
April '81
November '81
by Doug Garner
December '81
Richard Lamb
Thanks, Richard, I had forgotten where I saw it--and completely forgotten
that there were really a series of articles!
Peter
Old June 16th 10, 01:23 AM posted to rec.aviation.homebuilt
Brian Whatcott
$40 on it.
homebuilt!
Brian W
Peter
I remember this project well, it was the brainchild of a research
engineer at one of the NASA labs - NASA Ames, if I remember.
I was so intrigued, I called him up to talk about it.
A few people scratch built the device, the "gyros" were four thermistors
on a circle, with a little tube blowing air into the center of the
circle. Rotation in either axis shielded one from the air jet, and
ventilated the other, of each pair. Thermistors generate a little heat,
and their resistance varies dramatically with temperature. Each pair fed
an operational amplifier as differential inputs.
A weakness of the design was the little motor and fan involved.
These days, a two axis (piezo) gyro is more stable, more sensitive and
more reliable, not to mention using much less power. And you can buy it
off the shelf!
Regards
Brian W
Old June 16th 10, 11:44 PM posted to rec.aviation.homebuilt
Peter Dohm
another $40 on it.
homebuilt!
Brian W
standard rate turn.
Peter
I remember this project well, it was the brainchild of a research engineer
on a circle, with a little tube blowing air into the center of the circle.
Rotation in either axis shielded one from the air jet, and ventilated the
off the shelf!
Regards
Brian W
Some very good points there, especially regarding the advances in some of
the components that are now available, which also remind me of a problem
that could be either general or local in nature.
Most of the sources that I used to know about have dissappeared from the
local business landscape--so I not not sure were one would buy solid state
gyros, abolute pressure sensors, mass flow sensors, thermistors, or any of
the resistors and SSI and LSI components that used to be so common.
Peter
Old June 17th 10, 12:19 PM posted to rec.aviation.homebuilt
Brian Whatcott
Peter Dohm wrote:
...regarding the advances in some of
Peter
Sad but true. The source these days is the Internet via Google, and
originating usually in China or Taiwan.
Brian W
Clearance on hold, hold for release Hap[_2_] Piloting 17 June 28th 09 01:46 AM
Heading to Oshkosh Harry[_2_] Piloting 46 May 4th 07 10:51 PM
DC3 heading avionics Blue Simulators 2 July 31st 06 11:06 PM
The Euro's Heading Down Mike the Strike Soaring 10 June 5th 05 06:19 PM
HSI Heading Flag - Help Victor J. Osborne, Jr. Owning 4 July 6th 03 02:41 PM
