Co-pilot gets sick, stewardess helps land airplane
Old June 16th 10, 08:43 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Runge121
Default michaelnewport in full form
"Clarence do we have clearance?" a écrit dans le
message de groupe de discussion : ...
Maybe he shouldn't have had the fish. Thank goodness Karen Black was
working the flight!
http://www.chicagobreakingnews.com/2...and-plane.html
Flight attendant helps pilot land plane
June 15, 2010
A flight attendant who has a pilot's license replaced an ill first officer
during a landing at O'Hare International Airport, officials said today.
The co-pilot of an American Airlines plane that departed San Francisco on
Monday fell sick en route to Chicago, said American spokeswoman Mary
Frances Fagan.
"He was unable to continue his duties and he moved to the passenger
cabin," Fagan said, adding that the flight's captain checked to see
whether any off-duty airline pilots were on board the flight.
A female flight attendant advised the captain that she is a commercial
pilot and the captain asked her to sit in the right-hand seat in the
cockpit, Fagan said.
"The flight attendant became the first officer on landing," she said. "The
cockpit crew did an outstanding job handling the situation."
The flight attendant helped the captain by reading off check list of
procedures and she handled other tasks, in addition to providing a second
set of eyes in the cockpit, Fagan said.
The plane, a Boeing 767 with 225 passengers and seven crew members on
board, arrived at O'Hare at 4:24 p.m. Monday. The landing was normal,
officials said.
The condition of the ill first officer was not serious, officials said. He
was met on the ground at O'Hare by paramedics and transported to a local
hospital, where he was treated and released.
The first officer was based in Chicago. He was resting on Tuesday,
officials said.
Old June 16th 10, 09:06 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
mikeos
Default Co-pilot gets sick, stewardess helps land airplane
working the flight!
Not only a trolly-dolly then!
Old June 16th 10, 09:42 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
george
Maybe he shouldn't have had the fish. *Thank goodness Karen Black was
working the flight!
http://www.chicagobreakingnews.com/2...dant-helps-pil...
And with a CPL what's she doing ?
Working her way up ?
Give her a seat she's earned it !
Old June 16th 10, 09:49 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
GrtArtiste
On Jun 16, 9:19*am, "Clarence do we have clearance?"
working the flight!
Given this set of circumstances, what types of assistance would a
commercial-rated pilot be able to offer assuming she is not rated on
this type aircraft? I would guess-communications with ATC primarily.
What else?
GrtArtiste
Old June 16th 10, 10:38 PM posted to rec.aviation.piloting,rec.travel.air
vaughn[_3_]
"GrtArtiste" wrote in message
On Jun 16, 9:19 am, "Clarence do we have clearance?"
working the flight!
What else?
Reading checklists aloud, perhaps setting radios & transponder, another set of
eyes looking for traffic.
Of course, what seems to have been left out of this story is that the Captain
was likely perfectly capable of flying the plane all by himself, but still, 1.5
pilots should be slightly safer than 1; particularly if the Captain and the
Copilot ate the same meal!.
Vaughn
Old June 17th 10, 07:44 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
vaughn writes:
was likely perfectly capable of flying the plane all by himself ...
Not merely likely but certainly, by design. It's a non-event.
Old June 16th 10, 10:43 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
John Gilmer
What else?
She, as mentioned, can help run the radio. She also can read "check
lists."
The pilot knows where the various switches/levers are.
She can also call off speeds when landing.
Depending upon how much skill she has, she can double check whether the
pilot correctly did what the check list recommended. Indeed, that and the
radio are the only two areas where "flight" experience is useful.
Old June 16th 10, 10:51 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Captain Infinity
Once Upon A Time,
What else?
lists."
She can also re-inflate the auto-pilot, Otto, don't forget.
Captain Infinity
Old June 17th 10, 07:44 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Mxsmanic
GrtArtiste writes:
What else?
The same things any non-pilot could do: move levers and buttons when the
captain asks her two, read checklists, communicate with ATC, etc. It helps a
bit if she has piloting experience, but that doesn't mean that she will be
doing anything that _requires_ piloting experience.
Old June 17th 10, 10:10 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Dudley Henriques[_2_]
On Jun 17, 2:44*pm, Mxsmanic wrote:
GrtArtiste writes:
What else?
captain asks her two, read checklists, communicate with ATC, etc. *It helps a
This is absolutely correct. At no time was this attendant actually
flying this aircraft. She came up front and sat down in the right seat
acting as an extra set of hands to select, push, pull, and turn, any
and all switches and levers as asked for by the Captain. She acted as
an "assistant" and that's all.
Not to take anything away from this lady who performed as asked to
perform under trying circumstances, and indeed she personally appeared
on national TV this morning to "set straight" all the hype being
presented about her acting in any other capacity than that I have
stated above.
It helped certainly that this nice lady had flying experience but it
was by NO MEANS essential to what she was asked to do or what she
actually did in the cockpit.
Had the Captain opted to, he most certainly could have completed the
flight to a safe completion from the left seat without assistance. He
might have had to extend his reach a bit at times, but nothing earth
shattering for sure.
All in all, this was a class crew and they did a class job, right down
to the stew who very classily and politely deflated the media hype on
her role in the completion of this flight.
Dudley Henriques
Pilot nearly crashes in IMC, Controller helps pimenthal Piloting 32 September 27th 05 01:06 PM
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather Bill Mulcahy General Aviation 24 August 19th 05 10:48 PM
2 pilot/small airplane CRM Mitty Instrument Flight Rules 35 September 1st 04 11:19 PM
non-pilot lands airplane Cub Driver Piloting 3 August 14th 04 12:08 AM
Home Builders are Sick Sick Puppies pacplyer Home Built 11 March 26th 04 12:39 AM
