There's several words to describe that - "competitor" and "big brass
ones". -John On Jun 16, 3:08 pm, Andy wrote: What about completing a contest task, and winning it, with unknown damage to the fuselage? Andy |
On Jun 16, 12:34*pm, jcarlyle wrote:
There's several words to describe that - "competitor" and "big brass Actually, I'd call it pretty irresponsible. That glider could, at any moment have a system failure due to weakened structure. The only smart response is to land IMMEDIATELY, and definitely avoid overflying any people on the ground. Just checked the rules, and there's nothing in there regarding a pilot's responsibility after a collision. But several years ago, at a national contest, there was some heated debate at the mandatory meeting about what a pilot should do in such a case. If I recall correctly, an immediate landing for inspection was mandated, with one or two vocal "I'm here to WIN!!!" dissents. Nothing bad happened this time. But what if someone had been hurt or killed due to a system failure while the pilot continued to soar? What would be reported in the media? What would the NTSB response be? -Tom |
On 6/16/2010 10:20 PM, 5Z wrote:
On Jun 16, 12:34 pm, wrote: There's several words to describe that - "competitor" and "big brass Actually, I'd call it pretty irresponsible. That glider could, at any moment have a system failure due to weakened structure. The only smart response is to land IMMEDIATELY, and definitely avoid overflying any people on the ground. Just checked the rules, and there's nothing in there regarding a pilot's responsibility after a collision. But several years ago, at a national contest, there was some heated debate at the mandatory meeting about what a pilot should do in such a case. If I recall correctly, an immediate landing for inspection was mandated, with one or two vocal "I'm here to WIN!!!" dissents. Nothing bad happened this time. But what if someone had been hurt or killed due to a system failure while the pilot continued to soar? What would be reported in the media? What would the NTSB response be? -Tom Not only was this irresponsible, but it was most likely a violation of the FARs: 49CFR § 830.5 Immediate notification. The operator of any civil aircraft, or any public aircraft not operated by the Armed Forces or an intelligence agency of the United States, or any foreign aircraft shall immediately, and by the most expeditious means available, notify the nearest National Transportation Safety Board (Board) field office when: (a) An aircraft accident or any of the following listed incidents occur: (1) Flight control system malfunction or failure; (2) Inability of any required flight crewmember to perform normal flight duties as a result of injury or illness; (3) Failure of structural components of a turbine engine excluding compressor and turbine blades and vanes; (4) In-flight fire; or (5) Aircraft collide in flight. (6) Damage to property, other than the aircraft, estimated to exceed $25,000 for repair (including materials and labor) or fair market value in the event of total loss, whichever is less. (7) For large multiengine aircraft (more than 12,500 pounds maximum certificated takeoff weight): (i) In-flight failure of electrical systems which requires the sustained use of an emergency bus powered by a back-up source such as a battery, auxiliary power unit, or air-driven generator to retain flight control or essential instruments; (ii) In-flight failure of hydraulic systems that results in sustained reliance on the sole remaining hydraulic or mechanical system for movement of flight control surfaces; (iii) Sustained loss of the power or thrust produced by two or more engines; and (iv) An evacuation of an aircraft in which an emergency egress system is utilized. (b) An aircraft is overdue and is believed to have been involved in an accident. It is hard to see how you could meet the requirements of this section if you 1st finish flying the contest. -- Mike Schumann |
the FARs: 49CFR § 830.5 Immediate notification. The operator of any civil aircraft, or any public aircraft not operated by the Armed Forces or an intelligence agency of the United States, or any foreign aircraft shall immediately, and by the most expeditious means available, notify the nearest National Transportation Safety Board (Board) field office when: (a) An aircraft accident or any of the following listed incidents occur: [....] (5) Aircraft collide in flight. [....] It is hard to see how you could meet the requirements of this section if you 1st finish flying the contest. By using your radio to ask your ground crew to phone the nearest NTSB office? One could even argue that this IS the "most expeditious means available." B. |
On 6/17/2010 2:22 PM, Bart wrote:
Not only was this irresponsible, but it was most likely a violation of the FARs: 49CFR § 830.5 Immediate notification. The operator of any civil aircraft, or any public aircraft not operated by the Armed Forces or an intelligence agency of the United States, or any foreign aircraft shall immediately, and by the most expeditious means available, notify the nearest National Transportation Safety Board (Board) field office when: (a) An aircraft accident or any of the following listed incidents occur: [....] (5) Aircraft collide in flight. [....] It is hard to see how you could meet the requirements of this section if you 1st finish flying the contest. By using your radio to ask your ground crew to phone the nearest NTSB office? One could even argue that this IS the "most expeditious means available." B. B. It will be interesting to see if that's what actually happened. -- Mike Schumann |
On 6/21/2010 8:32 PM, Stephen! wrote:
Mike wrote in news:ByoSn.73380 : Not only was this irresponsible, but it was most likely a violation of the FARs: 49CFR õ 830.5 Immediate notification. What is the FAA's definition of "immediate"? I think 49CFR830.5 is pretty clear. Logic would say that you are OK if you are delayed because you are dealing with the accident, helping victims, etc. I suspect that delaying the notification because you were busy being interviewed by a TV reporter would probably be frowned on. A delay caused by your desire to finish a race would probably rank significantly lower than that. Not to say that you might be able to get around the reporting problem if you had someone else make the call for you while you were otherwise distracted. You'd still have to deal with the issue of whether your actions were reckless. -- Mike Schumann |
It's the NTSB's rule, it would need to be their definition. Jim |
jcarlyle wrote:
There's several words to describe that - "competitor" and "big brass ones". -John On Jun 16, 3:08 pm, Andy wrote: What about completing a contest task, and winning it, with unknown damage to the fuselage? Andy I imagine an accident investigator would have called it reckless operation. Brian W |
Midair near Minden | Fred | Soaring | 52 | September 1st 06 11:41 AM |
Midair near Minden | Jim Culp | Soaring | 0 | August 29th 06 05:52 PM |
Another midair! | tango4 | Soaring | 3 | April 27th 04 06:14 PM |
Pix of two midair F-18s | Pechs1 | Naval Aviation | 9 | January 8th 04 02:40 PM |
Midair in RI | Martin | Piloting | 3 | November 18th 03 10:29 PM |
