Parowan midair?
Old June 16th 10, 11:29 PM posted to rec.aviation.soaring
Andy[_1_]
Default Parowan midair?
On Jun 16, 1:20*pm, jb92563 wrote:
At the very least I think the competitors should be scratched on that
flight just for allowing a collision, no matter who's fault it was, as
a deterent to flying or allowing someone else to fly too close.
On the other hand why should a pilot who was hit through no fault of
his own be eliminated from a contest if he is able to determine,
perhaps by an inspection by another pilot and a controllability check,
that the glider is still safe to fly?
I know nothing of the circumstances of this incident but I know for
sure it is possible to be hit by another glider without being at
fault. The concept of "allowing" another, probably unseen, glider to
fly too close is nonsense.
Andy
Old June 17th 10, 04:55 AM posted to rec.aviation.soaring
5Z
fault. *The concept of "allowing" another, probably unseen, glider to
SH!T happens. Worse nonsense is is allowing a possibly unairworthy
glider to continue on task. By mandating an immediate landing and
scoring to the point of collision, there's no question about what
needs to be done.
-Tom
Old June 17th 10, 12:25 PM posted to rec.aviation.soaring
Brian Whatcott
Andy wrote:
... why should a pilot who was hit through no fault of
that the glider is still safe to fly?..
Andy
Using his X-ray vision, and on-board non-destructive testing
instrumentation, of course.
Brian W
Old June 17th 10, 12:36 PM posted to rec.aviation.soaring
stephanevdv
This is the rule as laid out by IGC in Annex A (international
competition rules) to the Sporting Code, Gliding section:
4.1.4 A competitor involved in a collision in the air shall not
continue the flight but land as soon as practicable. Both pilots will
be scored as having landed at the position at which the collision
occurred.
Seems a sensible rule to me...
Old June 17th 10, 04:04 PM posted to rec.aviation.soaring
jb92563
I totally agree that this rule is very sensible and should apply.
Besides, after two aircraft colide with enough force to tear a wing
tip off you
can bet your life that the FAA will ground both gliders until detailed
examination
is perfromed to prove that either is considered airworthy.
So.....your going to miss the rest of the contest in any case, so why
further risk your life
and more importantly those of others with a potentially damaged glider
that could loose control
at the worst possible time, like when your at the top of a gaggle in a
thermal.
I understand that the pilot in the Ventus probably felt his glider
suffered no signifigant damage, but would you not
want to take responsibility and at the very least escort the damaged
plane home so that you could radio for help if his
glider went down somewhere.
Even if a radio communication between the two pilots revealed that the
clipped wing glider thought he was OK to make it home, I think
escorting him to a safe landing would have been the most admiral thing
the other pilot could do and would gain him much more respect
and notatiaty than winning a contest day that nobody in the rest of
the world gives a crap about.
Sorry for sounding so harsh but winning a contest day is not even
close to winning the respect of your peers.
I guess under this kind of stress it is difficult to make the best
decissions.
Its always easier to see it clearly sitting on the ground typing at a
keyboard, but following your gut in this case might have been better
than striving to win.
Soap box dismounted!
Ray
occurred.
Old June 17th 10, 11:45 PM posted to rec.aviation.soaring
Bruce Hoult
Do you actually know that they weren't, for example, on the last leg
of the task, with Parowan the closest practical landing point?
Old June 18th 10, 05:15 PM posted to rec.aviation.soaring
jeplane
We have 2 morons.
One for flying 75 miles with a un-airworthy aircraft, when closer
airports were available, and the other one, for trying to finish a
task after colliding.
Both should have FAA violations waiting at home, for reckless and
unsafe operations.
And if the CD declares the Ventus a winner that day, he probably
should get a spanking as well for encouraging flying in this
condition...
Sigh... Idiots!!!!
Old June 18th 10, 07:52 PM posted to rec.aviation.soaring
Bob Kuykendall
On Jun 18, 9:15*am, jeplane wrote:
We have 2 morons...
Sigh... Idiots!!!!
So says the anonymous one.
Old June 18th 10, 08:02 PM posted to rec.aviation.soaring
Ramy
We have 2 morons.
unsafe operations.
condition...
Sigh... Idiots!!!!
I see the same reactions in every thread about an accident. You can
devide the reactions to 3 groups:
1 - Inteligent people trying to analyze the situation and learn
lessons without pointing fingers.
2 - Those who point fingers and calling names without knowing what
they are talking about.
3 - The "wait for the NTSB report" crowd, who must have never seen an
NTSB report otherwise they would know that NTSB reports are usually
useless and often published so late no one remembers the details.
Better say "wait for pilot reports" or a report in "Safety Corner"
although since Thelen stopped writing those reports himself, no one
seems to dare writing about accidents anymore.
BTW, at least one trace is available on OLC, but I could not find
anything that could suggest where the midair happened...
Ramy
Old June 18th 10, 09:04 PM posted to rec.aviation.soaring
Gary Evans[_2_]
I've flown Parowan on several occasions and if I were in that
predicament with 6 feet of missing wing and questionable spoilers but
the plane was stable in flight I would go to the longest runway at
which I knew there would be people to help. That would be Parowan. IMO
following rules would not be the most important objective. The goal
would be survival.
Midair near Minden Fred Soaring 52 September 1st 06 11:41 AM
Midair near Minden Jim Culp Soaring 0 August 29th 06 05:52 PM
Another midair! tango4 Soaring 3 April 27th 04 06:14 PM
Pix of two midair F-18s Pechs1 Naval Aviation 9 January 8th 04 02:40 PM
Midair in RI Martin Piloting 3 November 18th 03 10:29 PM
