On Mon, 21 Jun 2010 11:26:29 +0200, Mxsmanic
wrote: Hatunen writes: Cessna makes or made (I don't recall the current structure of the personal aircraft inudstry) some heavier aircraft than the 150s I used to fly. Including some Jets (the Citation line). Yes. I fly a Citation X on my trusty sim all the time. But flying jets is expensive, What ae you saying? That you an't afford the jet software for the sim? and one need not do so for a CPL. Indeed, it might well be the other way around: CPL, then jets. I'm not sure. I've forgotten. Is a commercial rating required before you can qualify for an ATR? By the way, you don't need an ATR to fly a jet. I wonder if John Travolta has an ATR...? -- ************* DAVE HATUNEN ) ************* * Tucson Arizona, out where the cacti grow * * My typos & mispellings are intentional copyright traps * |
On Sun, 20 Jun 2010 05:01:37 -0700, Dudley Henriques wrote:
On Jun 20, 4:30Â*am, Wingnut wrote: On Fri, 18 Jun 2010 16:11:10 -0700, Dudley Henriques wrote: All this is just a fancy way of saying that prior experience in a Cessna 150 might not matter in a 767 Who said anything about a Cessna? The original post said she had experience as a *commercial* pilot. That tends to mean something a bit bigger than just a personal aircraft. I believe the lady herself said during a TV interview that her experience was restricted to light aircraft. The type "Cessna" was mentioned. This statement, if true, remains irrelevant. Learning curves are monotonic increasing. She cannot be actually worse than someone with zero piloting experience and is probably at least slightly better. Furthermore, the original post to this thread did not state anything of the sort, only that she had a commercial pilot's license, which as another person pointed out normally includes non-zero experience with larger craft. |
![]() "Wingnut" wrote in message ... Who said anything about a Cessna? The original post said she had experience as a *commercial* pilot. That tends to mean something a bit bigger than just a personal aircraft. Not so. The training and testing for the Commercial certificate is normally done in single engine aircraft; often very simple single engine aircraft. To take a step down from that, I hold a Commercial glider pilot certificate and have taken hundreds of paying passengers up in sailplanes. Vaughn |
![]() "vaughn" wrote Not so. The training and testing for the Commercial certificate is normally done in single engine aircraft; often very simple single engine aircraft. To take a step down from that, I hold a Commercial glider pilot certificate and have taken hundreds of paying passengers up in sailplanes. Best to ignore this wingnut, as the knowledge of aviation is only slightly above MX. 'Nuff said. -- Jim in NC |
On Sun, 20 Jun 2010 08:30:23 +0000 (UTC), Wingnut
wrote: On Fri, 18 Jun 2010 16:11:10 -0700, Dudley Henriques wrote: All this is just a fancy way of saying that prior experience in a Cessna 150 might not matter in a 767 Who said anything about a Cessna? The original post said she had experience as a *commercial* pilot. That tends to mean something a bit bigger than just a personal aircraft. I got my commercial in a Cessna 120 with a coffeegrinder radio. You got a problem with that? Jim |
Pilot nearly crashes in IMC, Controller helps | pimenthal | Piloting | 32 | September 27th 05 01:06 PM |
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather | Bill Mulcahy | General Aviation | 24 | August 19th 05 10:48 PM |
2 pilot/small airplane CRM | Mitty | Instrument Flight Rules | 35 | September 1st 04 11:19 PM |
non-pilot lands airplane | Cub Driver | Piloting | 3 | August 14th 04 12:08 AM |
Home Builders are Sick Sick Puppies | pacplyer | Home Built | 11 | March 26th 04 12:39 AM |
