Parowan midair?
Old June 18th 10, 06:45 PM posted to rec.aviation.soaring
Jip
Default Parowan midair?
"Brian" wrote in message
1) If you have a midair, you should be scored for a landout at that
point. We need to take the temptation to continue the flight and score
points off the table. Even the best pilots can be tempted to do silly
things when points are on the table.
I agree this sounds like a rule that should be implemented.
2) If we need pilots to abandon the task and help with a serious and
ongoing safety issue, the CD needs to call the day off.
Just thinking out loud on this issue, perhaps the rules should allow
for any pilot involved in a potential and/or emergency situation to
request one other glider to abandon the task and assist the pilot in
safely landing the glider. The assisting pilot would at the
descression of the CD be awarded enough points to maintain his
position on the score sheet, But not more than a 3rd place finish for
the day.
This way the assisting pilot is not significantly penalized for
assisting, However the assisting pilot can not use this rule to
maintain a leading position in the race.
Of course the other scenerio as you mentioned is just calling off the
day.
Brian Case
You could give pilots that stay and help 1000 points for the day.
I always think the best of people....... but something tells me that the
spot of the accident will stay overcrowded for several hours ;-)
Old June 18th 10, 07:45 PM posted to rec.aviation.soaring
drbdanieli
In yacht racing, a competitor can ask for and be given redress for
assisting another vessel that needs assistance. If memory serves me
correctly, it's usally an average of the daily score that the
assisting vessel obtained during the regatta.
Although I haven't any idea how this mid-air occured, there are blind
spots that people should be aware of. I had a near miss years ago at
a nationals when I was ahead and below another glider. Obviously, I
couldn't see above and behind me and he couldn't see "under his
feet". When I got a thermal and zoomed up, my tail missed his cockpit
by a few feet! The increased numbers of sailplanes in a contest,
following the same line of cloud streets or ridges, a moment of in
attention with your head in the panel, messing with your computer can
all add up to a statistic.
I think what we need to focus on is what can be learned from this
accident and what can be done to minimize the chances of it happening
to someone else. Personally, I think situations like this make a case
for getting Flarm or an equivalent system established here in the US.
Barry
Old June 18th 10, 08:46 PM posted to rec.aviation.soaring
Mike Schumann
Barry
We don't need FLARM, we need MITRE's low cost ADS-B transceiver. The
SSA needs to send a letter to Randy Babbitt using this accident as an
example of why we need a green light to get this unit certified ASAP.
Mike Schumann
Old June 21st 10, 01:23 AM posted to rec.aviation.soaring
Andreas Maurer
On Fri, 18 Jun 2010 15:46:15 -0400, Mike Schumann
Mike, believe me:
If you have ever flown half a year with FLARM with lots of gliders
around (e.g contest), you are going to want one NOW - and you are not
going to have the patience to wait for the better solution that it
possibly available in 2012.
FLARM isnt't going to solve all of the problems, but I am pretty sure
that it would have prevented the incident we are talking about.
Andreas
Old June 21st 10, 07:04 AM posted to rec.aviation.soaring
Derek C
We don't need FLARM, we need MITRE's low cost ADS-B transceiver. *The
Mike, believe me:
around (e.g contest), you are going to want one NOW *- and you are not
Andreas
I have flown with FLARM in a UK competition. It tells you that there
are other FLARM equipped gliders nearby and in a crowded thermal the
collision warning goes off quite frequently, even though you can see
the other gliders and there is no chance of collisions. If you get a
warning from another glider you haven't seen, it can be quite
difficult to work out where it is, especially in a circling situation.
It is not a substitute for keeping a good look out!
Derek C
Old June 21st 10, 10:02 AM posted to rec.aviation.soaring
Cats
On Jun 21, 7:04*am, Derek C wrote:
snip
FLARM that is. Of course not, and the Flarm website is very clear
about that, but it can be a useful aid. I certainly appreciated
having it on the South Downs Ridge earlier this year.
Old June 21st 10, 01:27 PM posted to rec.aviation.soaring
Bob
Flarm saved my a$$ 2 weeks ago north of Samadan (just southwest from
Innsbruck). Snowline at 2000 meters,we were at 2300 meters flying
under the edge of a cloud Flarm warning goes off. Couldn't see
anything but rolled into a tight climbing turn. Directly in front,
backdrop of snow, was a Duo on the nose going for the same thermal. As
soon as we pulled up and turned the Duo rolled the other direction. No
harm no foul, no Flarm?????
2 sailplanes at the same altitude, snow on the rocks in the
background, we were doing 170KMH and he was probably moving pretty
fast also. Within seconds of the Flarm warning we would have been
turning and climbing into the thermal. Would we have seen the Dou? I
would like to think so! Should my family rely on that happening? That
is one to think about.
I know Flarm is probably not the answer in the US, not enough planes
have Flarm already to get critical mass. Here in the Alps and Germany
most XC planes are now equipped but there are still enough without to
cause some problems.
Please, keep a good lookout!
Bob
Old June 21st 10, 03:27 PM posted to rec.aviation.soaring
Mike Schumann
Mike, believe me:
Andreas
FLARM is useless unless everyone is equipped. That is NOT going to
happen in the US. Low cost ADS-B could be available tomorrow if the FAA
would certify the units. NAVWORX and MITRE have working prototypes that
could go into production overnight if we can get the FAA to get off
their but.
We need to get people to send letters to Randy Babbitt to get some top
level attention to this. It also wouldn't hurt to copy Craig Fuller at
AOPA. They should be pushing this a LOT more agresively than they have.
Mike Schumann
Old June 21st 10, 04:18 PM posted to rec.aviation.soaring
"Mike Schumann" wrote in message ...
.... Snip ...
their but.
Mike Schumann
Just courious, what do you consider "Low Cost." Us guys with old inexpensive sailplanes would like to know.
Old June 21st 10, 04:41 PM posted to rec.aviation.soaring
Bob 7U
I suppose the term 'low cost' is relative and depends upon whether you
compare it to the cost of your sailplane or your life.
Bob 7U
On Jun 21, 11:18*am, "Wayne Paul" wrote:
"Mike Schumann" wrote in ...
... Snip ...
FLARM is useless unless everyone is equipped. *That is NOT going to
happen in the US. *Low cost ADS-B could be available tomorrow if the FAA
would certify the units. *NAVWORX and MITRE have working prototypes that
their but.
level attention to this. *It also wouldn't hurt to copy Craig Fuller at
AOPA. *They should be pushing this a LOT more agresively than they have.
Mike Schumann
Just courious, what do you consider "Low Cost." *Us guys with old inexpensive sailplanes would like to know.
Midair near Minden Fred Soaring 52 September 1st 06 11:41 AM
Midair near Minden Jim Culp Soaring 0 August 29th 06 05:52 PM
Another midair! tango4 Soaring 3 April 27th 04 06:14 PM
Pix of two midair F-18s Pechs1 Naval Aviation 9 January 8th 04 02:40 PM
Midair in RI Martin Piloting 3 November 18th 03 10:29 PM
