121.5 ELTs banned
Old June 22nd 10, 11:53 AM posted to rec.aviation.soaring
Scott[_7_]
Default 121.5 ELTs banned
Peter Hermann wrote:
Darryl Ramm wrote:
For gliders ELT seem very problematic, too hard to mount, antennas
Moreover:
How to test proper functioning of 406 MHz with 118 - 136 MHz radios?
When the FCC bans VHF radio for aircraft use and requires us to move
to UHF, it will solve that problem. Until then, you'll either have to
believe a little LED transmit light or find a ham radio friend with a
UHF handheld radio to listen for you. I will do it for a small fee
Old June 22nd 10, 02:08 PM posted to rec.aviation.soaring
Peter Hermann[_3_]
interesting solution.
remains the question whether UHF has better
physical characteristics of range and quality.
....and what about affordability.
Old June 23rd 10, 12:02 AM posted to rec.aviation.soaring
Scott[_7_]
As a ham radio operator, I have noticed that the 902 MHz band seems to
have vast improvement in conversing via radio over an obstructed path
(trees. leaves, etc.) than at 430 MHz. Unfortunately, the 902 MHz band
is loaded with unlicensed stuff that might interfere...of course, with
satellite detection, obstructions are generally overcome since the
satellite are "overhead" instead of through miles of forest...
Old June 23rd 10, 12:41 AM posted to rec.aviation.soaring
Brian Whatcott
Ouch! That's the hot button: $600 but mostly $1200 on up....
Brian W
Use of 121.5 ELTs to be illegal in U.S. in about 60 days. Jim Logajan Piloting 15 July 3rd 10 09:23 PM
Anybody installing tri-band (406MHz) ELTs? Michelle P Instrument Flight Rules 0 July 4th 05 09:10 PM
Anybody installing tri-band (406MHz) ELTs? Michelle P General Aviation 0 July 4th 05 09:10 PM
406 ELTs: link featuring many models [email protected] Soaring 0 February 20th 05 09:36 PM
Airshows should be banned...Now! Tetherhorne P. Flutterblast Military Aviation 28 June 15th 04 02:43 AM
