On Jun 22, 3:41*am, Scott wrote:
brian whatcott wrote: Since satellite cover has been withdrawn for 121.5 (High false alert rate, poor localization) 406.0 and 406.1 ELTs will be needed, following a recent FCC determination. Brian W I can see the 406 units providing better localization, but how do they lower the high false alert rate? *I assume they still use a "G Switch" to activate? I would think that localization could be good on the 121.5 units if they would be made to accept GPS data and transmit lat/long data when they go off... The 406 MHZ ELT or PLB may not have a GPS or may not be ale to get a GPS fix, the position of the device is then determined by doppler triangulation from the orbiting (non-geostationary) COASPAS-SARSAT satellites. The higher frequency and higher spectral purity specs of the 406 MHz transmitters enable better Doppler triangulation. A relatively accurate Doppler fix takes several passes of these satellites. The reception of the alert and the unique ELT or PLB digital ID is immediate (via geostationary satellites). You get all this by throwing away the crappy old 121.5 Mhz ELTs and replacing them with a modern device. If a 406 MHz PLB or ELT has a GPS unit (many low-cost PLBs do now) then it transmits its GPS position if it has a fix and that is immediately received by the geostationary COSPAS-SARASAT satellites. The old 121.5Mhz devices are analog, 406 Mhz has many advantages over 121.5 MHz. The solution is to throw out the old junk and move to 406 MHz. 121.5MHz PLBs belong in a landfill, and the FCC is on the right path here. Darryl |
Use of 121.5 ELTs to be illegal in U.S. in about 60 days. | Jim Logajan | Piloting | 15 | July 3rd 10 09:23 PM |
Anybody installing tri-band (406MHz) ELTs? | Michelle P | Instrument Flight Rules | 0 | July 4th 05 09:10 PM |
Anybody installing tri-band (406MHz) ELTs? | Michelle P | General Aviation | 0 | July 4th 05 09:10 PM |
406 ELTs: link featuring many models | [email protected] | Soaring | 0 | February 20th 05 09:36 PM |
Airshows should be banned...Now! | Tetherhorne P. Flutterblast | Military Aviation | 28 | June 15th 04 02:43 AM |
