L13 Blanik Mandatory Bulletin
Old June 23rd 10, 02:24 PM posted to rec.aviation.soaring
Derek C
Default L13 Blanik Mandatory Bulletin
Provided that the correct weak link is always used, it should not be
easily possible to damage a glider by winch launching it. What
aerobatics had this glider done?
Derek C
On Jun 23, 3:23*am, "BT" wrote:
Reading the MB, It appears that based on the "flight data" of the aircraft,
and high number of launches per flight hour, the concern is overstressing
from repeated winch launches. LET is requesting all users submit flight
statistics for further evaluation plus a one time inspection of the load
bearing aft spar cap in the fuselage carry through structure.
I do not know if the L-23 and the L-13 have the same construction for the
aft spar cap.
"Ernst" wrote in message
After a fatal accident in Austria LET issued a Mandatory Bulletin:
http://www.let.cz/files/bulletines/M...9a_english.pdf
EASA issued an Emergency Airworthiness Directive:
http://www.caa.co.uk/docs/33/easa_ad_2010_0119_E.pdf- Hide quoted text -
- Show quoted text -
Blanik L-23 Super Blanik Manual -F.C.F.S. Joel Flamenbaum Soaring 2 April 14th 10 03:29 PM
Mandatory ELT [email protected] Soaring 9 March 8th 05 03:01 PM
ELT Mandatory ? Jim Culp Soaring 20 June 19th 04 06:40 PM
New security bulletin gatt Piloting 28 June 9th 04 10:33 PM
Grob 103 bulletin becomes AD Mike Borgelt Soaring 0 October 3rd 03 12:47 AM
