On Jun 23, 6:45*pm, Bob Kuykendall wrote:
On Jun 23, 8:17*am, Derek C wrote: Actually the maximum bending load on the wingspar during a winch is equivalent to about 3 g, due to the point loading on the fuselage and the lack of g unloading on the wings, but that still shouldn't cause a failure... I think that 3g equivalent load is a large enough percentage of the limit load to constitute a fatigue concern. If I were assessing service histories, I would definitely want to know the cycle count on activities likely to cause that kind of load. Thanks, Bob K. Most modern gliders are stressed to take at least +5.3/-2 g without damage. A winch launch comes nowhere near this as long as the correct weak link is fitted, which will break well before the glider does. I believe that the glider that failed had being doing aerobatics immediately before, which is a more likely cause of any overstressing. Derek C |
On Jun 23, 6:51*pm, Derek C wrote:
On Jun 23, 6:45*pm, Bob Kuykendall wrote: On Jun 23, 8:17*am, Derek C wrote: Actually the maximum bending load on the wingspar during a winch is equivalent to about 3 g, due to the point loading on the fuselage and the lack of g unloading on the wings, but that still shouldn't cause a failure... I think that 3g equivalent load is a large enough percentage of the limit load to constitute a fatigue concern. If I were assessing service histories, I would definitely want to know the cycle count on activities likely to cause that kind of load. Thanks, Bob K. Most modern gliders are stressed to take at least +5.3/-2 g without damage. A winch launch comes nowhere near this as long as the correct weak link is fitted, which will break well before the glider does. I believe that the glider that failed had being doing aerobatics immediately before, which is a more likely cause of any overstressing. Derek C If I recall correctly, the concern was with fatigue damage accumulating at loads below the limit load. If fatigue cracks do form, you could get a static failure below limit load - and not necessarily during a winch launch. How serious this concern should be in the case of the L-13 I couldn't say but given that they think it might have been a fatigue crack, the AD seems pretty reasonable. JM. |
On Wed, 23 Jun 2010 16:35:56 -0700 (PDT), Judah Milgram
wrote: snip Most modern gliders are stressed to take at least +5.3/-2 g without damage. A winch launch comes nowhere near this as long as the correct weak link is fitted, which will break well before the glider does. I believe that the glider that failed had being doing aerobatics immediately before, which is a more likely cause of any overstressing. Derek C If I recall correctly, the concern was with fatigue damage accumulating at loads below the limit load. If fatigue cracks do form, you could get a static failure below limit load - and not necessarily during a winch launch. How serious this concern should be in the case of the L-13 I couldn't say but given that they think it might have been a fatigue crack, the AD seems pretty reasonable. JM. Actually and AD has not been issued by the FAA. A mandatory bulletin from the manufacture has been issued. There is a huge difference. An AD is mandatory in the US. A mandatory bulletin by the manufacture is optional. |
On Jun 23, 9:31*pm, harold wrote:
On Wed, 23 Jun 2010 16:35:56 -0700 (PDT), Judah Milgram wrote: snip Most modern gliders are stressed to take at least +5.3/-2 g without damage. A winch launch comes nowhere near this as long as the correct weak link is fitted, which will break well before the glider does. I believe that the glider that failed had being doing aerobatics immediately before, which is a more likely cause of any overstressing. Derek C If I recall correctly, the concern was with fatigue damage accumulating at loads below the limit load. If fatigue cracks do form, you could get a static failure below limit load - and not necessarily during a winch launch. How serious this concern should be in the case of the L-13 I couldn't say but given that they think it might have been a fatigue crack, the AD seems pretty reasonable. JM. Actually and AD has not been issued by the FAA. *A mandatory bulletin from the manufacture has been issued. *There is a huge difference. *An AD is mandatory in the US. *A mandatory bulletin by the manufacture is optional. You're right, the subject AD was issued by EASA, not FAA. But given that a wing just failed due to a possible fatigue crack, most US owners will probably want to comply anyway (just guessing here). Judah Milgram |
On Jun 23, 9:23*pm, Judah Milgram wrote:
On Jun 23, 9:31*pm, harold wrote: On Wed, 23 Jun 2010 16:35:56 -0700 (PDT), Judah Milgram wrote: snip Most modern gliders are stressed to take at least +5.3/-2 g without damage. A winch launch comes nowhere near this as long as the correct weak link is fitted, which will break well before the glider does. I believe that the glider that failed had being doing aerobatics immediately before, which is a more likely cause of any overstressing. Derek C If I recall correctly, the concern was with fatigue damage accumulating at loads below the limit load. If fatigue cracks do form, you could get a static failure below limit load - and not necessarily during a winch launch. How serious this concern should be in the case of the L-13 I couldn't say but given that they think it might have been a fatigue crack, the AD seems pretty reasonable. JM. Actually and AD has not been issued by the FAA. *A mandatory bulletin from the manufacture has been issued. *There is a huge difference. *An AD is mandatory in the US. *A mandatory bulletin by the manufacture is optional. You're right, the subject AD was issued by EASA, not FAA. But given that a wing just failed due to a possible fatigue crack, most US owners will probably want to comply anyway (just guessing here). Judah Milgram - Hide quoted text - - Show quoted text - You may be right for the U.S., but I don't believe you are correct for Canada. I haven't had a chance to check the precise regulation, but a mandatory bulletin from a manufacturer or EASA becomes mandatory in Canada due to cooperation agreements. Canadian L-13's are therefore grounded until the AD is complied with. |
On Jun 23, 3:51*pm, Derek C wrote:
Most modern gliders are stressed to take at least +5.3/-2 g without damage... It is true that operation within the limit load should not cause any damage in the sense of bent, stretched, or torn structure that precludes continued operation. However, at the same time every single load cycle causes the accumulation of fatigue that, given a long enough service life, will eventually cause failure. Aluminum structures require careful consideration of fatigue and service life, since there is no level of stress below which fatigue does not accumulate. If you take an aluminum wing designed to a 5.3g limit load and load cycle it from 0g to 1g and back a relatively large number of times, it will eventually break without ever having been stressed over 1g. That is one of the reasons that there is some margin (usually 50%) between limit load and ultimate load. The key, question, of course, is how many cycles does it take? The extreme example I cite above will probably take many, many times the number of cycles equivalent to the flight hours in the planned service life. Given greater loads, the number of cycles to failure is reduced. And of course, given lower loads, the number of cycles is increased. But the important thing is that, for aluminum at least, there is no level of loading at which the cycle count goes to infinity. An infinitesimal loading, repeated enough times, will result in eventual failure. Thanks, Bob K. |
Blanik L-23 Super Blanik Manual -F.C.F.S. | Joel Flamenbaum | Soaring | 2 | April 14th 10 03:29 PM |
Mandatory ELT | [email protected] | Soaring | 9 | March 8th 05 03:01 PM |
ELT Mandatory ? | Jim Culp | Soaring | 20 | June 19th 04 06:40 PM |
New security bulletin | gatt | Piloting | 28 | June 9th 04 10:33 PM |
Grob 103 bulletin becomes AD | Mike Borgelt | Soaring | 0 | October 3rd 03 12:47 AM |
