L13 Blanik Mandatory Bulletin
Old June 24th 10, 04:23 AM posted to rec.aviation.soaring
Judah Milgram
Default L13 Blanik Mandatory Bulletin
On Jun 23, 9:31*pm, harold wrote:
On Wed, 23 Jun 2010 16:35:56 -0700 (PDT), Judah Milgram
snip
Most modern gliders are stressed to take at least +5.3/-2 g without
damage. A winch launch comes nowhere near this as long as the correct
weak link is fitted, which will break well before the glider does. I
believe that the glider that failed had being doing aerobatics
immediately before, which is a more likely cause of any
overstressing.
Derek C
If I recall correctly, the concern was with fatigue damage
accumulating at loads below the limit load. If fatigue cracks do form,
you could get a static failure below limit load - and not necessarily
during a winch launch. How serious this concern should be in the case
of the L-13 I couldn't say but given that they think it might have
been a fatigue crack, the AD seems pretty reasonable.
JM.
Actually and AD has not been issued by the FAA. *A mandatory bulletin
from the manufacture has been issued. *There is a huge difference. *An
AD is mandatory in the US. *A mandatory bulletin by the manufacture is
optional.
You're right, the subject AD was issued by EASA, not FAA. But given
that a wing just failed due to a possible fatigue crack, most US
owners will probably want to comply anyway (just guessing here).
Judah Milgram
Old June 25th 10, 07:07 PM posted to rec.aviation.soaring
Sandy Stevenson
snip
overstressing.
Derek C
JM.
optional.
Judah Milgram
- Hide quoted text -
- Show quoted text -
You may be right for the U.S., but I don't believe you are correct for
Canada.
I haven't had a chance to check the precise regulation, but a
mandatory bulletin from a
manufacturer or EASA becomes mandatory in Canada due to cooperation
agreements.
Canadian L-13's are therefore grounded until the AD is complied with.
Blanik L-23 Super Blanik Manual -F.C.F.S. Joel Flamenbaum Soaring 2 April 14th 10 03:29 PM
Mandatory ELT [email protected] Soaring 9 March 8th 05 03:01 PM
ELT Mandatory ? Jim Culp Soaring 20 June 19th 04 06:40 PM
New security bulletin gatt Piloting 28 June 9th 04 10:33 PM
Grob 103 bulletin becomes AD Mike Borgelt Soaring 0 October 3rd 03 12:47 AM
