Substandard Italian workmanship renders first 787s unsafe
Old June 27th 10, 12:11 AM posted to rec.aviation.piloting,rec.travel.air
Bob Myers
Default Substandard Italian workmanship renders first 787s unsafe
VOR-DME wrote:
\ I certainly hope this laziness does not extend to his piloting
activities, otherwise _bad things_ could happen!
No, nothing bad is ever going to happen there, simply because he
has no actual "piloting activities." Whenever he speaks of "piloting,"
he's actually talking about "flying" Microsoft Flight Simulator. So
nothing remotely like a real aircraft or passengers will ever be in any
danger.
Bob M.
  #33
Old June 27th 10, 12:17 AM posted to rec.aviation.piloting
Bob Myers
In rec.aviation.piloting Mxsmanic wrote:
Tom P writes:
Factory workers make mistakes all the time. It's normal.
The number and magnitude of mistakes they make depend a great deal on
corporate and social culture.
I recall Akio Morita describing such a problem. Sony was building
Trinitrons in both Japan and the USA. In both countries, the tubes
had to meet the same tolerances. Nevertheless, the company found
that the Japanese tubes were always far closer to perfection than
the USA tubes.
Finally, management figure it out. The Japanese always tried to get
things perfect, no matter what the accepted tolerances were, whereas
the Americans didn't care whether it was perfect or not, as long as
it fell within the tolerances.
To fix this, Sony made the tolerances far tighter for the USA tubes.
Their quality then improved significantly.
All of which was stupidity on Sony's part.
All things have a tolerance and tighter tolerances increase costs.
If Sony needed tighter tolerance they should have originally specified
tighter tolerances instead of ****ing and moaning that stuff made to
their specified tolerance wasn't "good enough".
It was all about culture.
Wrong, it is all about getting the specifications to be what is really
needed in the first place.
That is basic engineering.
100% correct. Mxs couldn't have picked a better example, since I
have direct professional experience with the Trinitron design, having
worked very closely with Sony as a monitor supplier a number of
years back. Tightening tolerances beyond what is required for the
design to function to customer expectations and its published
specification is nonsense, and Sony is far too good at engineering to
do that. The story is nonsense, and I seriously doubt that Morita-san
ever said anything of the sort. I have personally tested numerous
Trinitron products from both the Japan and U.S. factories, and found
no significant differences between them. (Actually, since the production
of the Trinitron CRT was essentially 100% automated, there was
absolutely no reason to expect any such differences. They used the
same production equipment, programmed the same, etc., etc..)
So once again, our friend here is speaking of something regarding which
he appears to have precisely zero actual knowledge or experience.
Bob M.
  #34
Old June 27th 10, 12:18 AM posted to rec.aviation.piloting,rec.travel.air
Bob Myers
Mxsmanic wrote:
My experience and training have shown significant cultural
differences that cannot be ignored.
And again - that "experience and training," relevant to this topic,
would be - what, exactly? And is it as extensive as your experience
and training in piloting?
Bob M.
  #36
Old June 27th 10, 12:33 PM posted to rec.aviation.piloting
Mxsmanic
VOR-DME writes:
Seems our in-house expert knows about as much of engineering as he does of
aviation. Quality conciousness IS striving to manufacture to the specified
tolerance.
Then the Americans lacked that, although when I said QC it meant quality
control, which is essentially damage control.
For a manufacturer to modify the tolerance, either more or less
stringent, would be an error and a detriment to quality.
Physical devices tend to drift out of nominal specifications over time. The
tighter the tolerances, the longer they will last without drifting
unacceptably. Thus, a tighter tolerance generally ensures less maintenance
and/or a longer working lifetime. There is no ideal tolerance, but as any
engineer knows, tight manufacturing tolerances improve the quality of the
product by increasing the margin between the original manufacturing tolerance
and the tightest tolerance that will ensure proper operation (which can't
always be determined precisely).
  #37
Old June 27th 10, 04:37 PM posted to rec.aviation.piloting
Mxsmanic wrote:
VOR-DME writes:
tolerance.
The purpose of quality control is to ensure product meets the stated
specifications, which is exactly what happened in your story.
unacceptably.
Some do, some don't, it depends on the device and parameter in question.
However it is up to the original designer of the total system to specify
the tolerances for the individual parts and provide those tolerances to
the makers of piece parts.
The burden on the piece part maker is to make them to the specifications
provided by the designer and the part maker has no obligation nor right to
second guess the original designer.
snip babbling nonsense
Jim Pennino
Remove .spam.sux to reply.
  #40
Old June 27th 10, 05:38 PM posted to rec.aviation.piloting
On Jun 27, 11:22*am, Mxsmanic wrote:
often translates to inspection after the fact,
WRONG
If not, please provide proof / studies that the readership can make
their own judgement.
Let me guess, YOU WON'T.
"Aircraft Unsafe, Do Not Fly" T8 Soaring 2 April 13th 10 08:24 PM
Relief Tube Housing - Unsafe Tim Taylor Soaring 12 June 18th 09 09:30 PM
renders [email protected] Restoration 0 April 25th 04 03:35 AM
Your Italian Consultant, your italian business opportunity Techenquire.com Products 2 January 12th 04 08:08 AM
Your Italian Consultant, your italian business opportunity Techenquire.com Aviation Marketplace 0 January 5th 04 02:10 PM
