jb92563 wrote:
/snip/ Something that depicts airfields well, that needs no setup... Thanks for any clues... Brian W Your last sentence is the killer ......"Something that depicts airfields well, that needs no setup"... Thanks for this response, despite my misleading spec. The setup I had in mind was the operational setup when preparing to fly. I can accept the need to specify a destination airport in the other Garmin - how else would I get course, distance and time en route? I like the hands off map display from the APIC. Just wondering if there are more splendid displays I'm missing! Brian W There are good flying tools like the Garmin Airmap type units that depict airfield layouts, that comes loaded ready to go...however I think you had low price as part of your criteria? You might want to check the Oudie, but its basically like the unit you bought but preloaded with the software. I have been using XCSoar in the motor glider and now even better the LK8000 spinoff of XCSoar on a 4.3" iPAQ 310...... works great and gets improvements to the LK8000 software monthly. Takes abotu 5 minutes to do an update and is simply a copy of the latest software on top of the old stuff on the SD chip. I have simply made copies of the 2mb chip and loaded their local area maps for those that are not gadget geeks and they are up and running instantly. LK8000 is free and I believe you can load/attach auxilliary info for airfields, although I have personally not tried that yet. The existing airfield information includes coordinates, airspace frequencies, runway numbers and occasionally comments so I dont find the need to see an airport map since I dont fly in to anything more complex that Class D airspace. It would take some work however to gather the extra airport info and load it up yourself if you wanted more details ....ie setup.... Perhaps we need a couple guru's to offer combos preloaded and configured like the Oudie marketers are doing. Ray |
On Jun 30, 4:56*pm, brian whatcott wrote:
jb92563 wrote: */snip/ Something that depicts airfields well, that needs no setup... Thanks for any clues... Brian W Your last sentence is the killer *......"Something that depicts airfields well, that needs no setup"... Thanks for this response, despite my misleading spec. The setup I had in mind was the operational setup when preparing to fly. I can accept the need to specify a destination airport in the other Garmin - how else would I get course, distance and time en route? I like the hands off map display from the APIC. Just wondering if there are more splendid displays I'm missing! Brian W There are good flying tools like the Garmin Airmap type units that depict airfield layouts, that comes loaded ready to go...however I think you had low price as part of your criteria? You might want to check the Oudie, but its basically like the unit you bought but preloaded with the software. I have been using XCSoar in the motor glider and now even better the LK8000 spinoff of XCSoar on a 4.3" iPAQ 310...... works great and gets improvements to the LK8000 software monthly. Takes abotu 5 minutes to do an update and is simply a copy of the latest software on top of the old stuff on the SD chip. I have simply made copies of the 2mb chip and loaded their local area maps for those that are not gadget geeks and they are up and running instantly. LK8000 is free and I believe you can load/attach auxilliary info for airfields, although I have personally not tried that yet. The existing airfield information includes coordinates, airspace frequencies, runway numbers and occasionally comments so I dont find the need to see an airport map since I dont fly in to anything more complex that Class D airspace. It would take some work however to gather the extra airport info and load it up yourself if you wanted more details ....ie setup.... Perhaps we need a couple guru's to offer combos preloaded and configured like the Oudie marketers are doing. Ray- Hide quoted text - - Show quoted text - If you have not seen LK8000 you should check it out if low cost with lots of funtionality is your goal. It even has stuff like FLARM etc showing targets in your vicinity on the moving map. Then there are the weather files that you can load in advance, along with the airfields info that I will have to try out next. My recent trip with it had about 12 waypoints over 400 miles and the only finger (not stylus) input needed was to skip a waypoint or two that I decided to bypass, and took only a couple seconds to do. And this was in rough bouncy air in the Ownes Valley, CA. in the afternoon in a motorglider moving at 90 kts. I really appreciated the design not requiring precise finger pointing ability on the touch screen as it would have been impossible to use a stylus in the bumpy air. I also like the iPhone type gestures for turning pages etc and the touch screen zones (as opposed to points) that are used to make selections. The thermalling auto zoom is fantastic with the colored trails indicating lift or sink to help you move into the strongest part of the lift. I only wish that the gps would take readings faster than 1 sec intervals so it can be more precise and have less lag, but you get used to it and learn how to anticipate quickly since the seat of the pants gives you instantaineous feedback. I found that making adjustments about 45 degress early in the circle seemed to be the proper method for my circling speed. Ray |
"VideO Madness" ( Soldiers...) "GoD Hates FAGS!!! (He sO righteOusly DoES)" | Colonel Jake | Naval Aviation | 0 | March 1st 10 12:14 AM |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Piloting | 168 | February 5th 08 05:32 PM |
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 07:48 AM |
