Flaps_50! writes:
The Cirrus pilot doesn't know how to slip ? The 1700-fpm is _with the parachute deployed_, and thus has nothing to do with normal flight. |
Mxsmanic wrote: Flaps_50! writes: The Cirrus pilot doesn't know how to slip ? The 1700-fpm is _with the parachute deployed_, and thus has nothing to do with normal flight. You said: "I read yesterday that the descent rate of a Cirrus with the parachute deployed is around 1700 fpm, far more than a competent pilot could manage by actually flying the aircraft." In short, you directly said that a competent pilot flying the aircraft could not come anywhere close to 1700fpm. This is blatantly wrong. Go on, dodge, I know it's all you can do. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Mike Ash writes:
You said: "I read yesterday that the descent rate of a Cirrus with the parachute deployed is around 1700 fpm, far more than a competent pilot could manage by actually flying the aircraft." In short, you directly said that a competent pilot flying the aircraft could not come anywhere close to 1700fpm. This is blatantly wrong. No, I said that 1700 fpm greatly exceeds what a pilot could limit the descent rate to if he actually flew the aircraft. I thought that would be clear in context. Why would the pilot want to hit the ground at greater than 1700 fpm? |
Mxsmanic wrote: Mike Ash writes: You said: "I read yesterday that the descent rate of a Cirrus with the parachute deployed is around 1700 fpm, far more than a competent pilot could manage by actually flying the aircraft." In short, you directly said that a competent pilot flying the aircraft could not come anywhere close to 1700fpm. This is blatantly wrong. No, I said that 1700 fpm greatly exceeds what a pilot could limit the descent rate to if he actually flew the aircraft. I thought that would be clear in context. Why would the pilot want to hit the ground at greater than 1700 fpm? It was not at all clear. You wouldn't want to hit the ground at greater than that speed. There are many scenarios, however, where you would want to descend at greater than that speed BEFORE arriving at the ground. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Mike Ash writes:
It was not at all clear. Sorry. If it wasn't at all clear, perhaps you should not have been so quick to call it wrong. |
Mxsmanic wrote: Mike Ash writes: It was not at all clear. Sorry. If it wasn't at all clear, perhaps you should not have been so quick to call it wrong. Perhaps *I* wasn't clear. Your message had, as far as I could tell, one single reasonable interpretation. It just happened that the meaning of that single reasonable interpretation doesn't line up with what you meant to say. Thus, it was unclear, but this was only evident after you explained yourself. Maybe YOU shouldn't be so quick to call ME out, huh? No wonder nobody likes you.... Feel free to get in the last word now. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Mike Ash writes:
Perhaps *I* wasn't clear. Your message had, as far as I could tell, one single reasonable interpretation. It just happened that the meaning of that single reasonable interpretation doesn't line up with what you meant to say. Thus, it was unclear, but this was only evident after you explained yourself. But the standard of reasonableness was yours, not mine. Given the context, I felt certain that it would be correctly interpretation, since the interpretation you gave it would make no sense. |
![]() "Mxsmanic" wrote in message ... Mike Ash writes: You said: "I read yesterday that the descent rate of a Cirrus with the parachute deployed is around 1700 fpm, far more than a competent pilot could manage by actually flying the aircraft." In short, you directly said that a competent pilot flying the aircraft could not come anywhere close to 1700fpm. This is blatantly wrong. No, I said that 1700 fpm greatly exceeds what a pilot could limit the descent rate to if he actually flew the aircraft. I thought that would be clear in context. Why would the pilot want to hit the ground at greater than 1700 fpm? Anthony, I took the trouble to read back and, as you know, that is not exactly what you said. I really don't know the minimum power off descent rate of the cirrus, windmilling or idling, and that by itself is not particularly usefull in the successfull landing of either an aircraft or a simulator. You have known that for a long time because the basic numbers and procedures are similar. You also know the circumstance in which stabilization at minimum sink is recommended as the best means to minimize the effect of a crash, because it is just too frequently quoted and published for you to have missed. You also know that the parachute was not added as a fix for a problem; but was part of the original concept and was a reason that spin entry and recovery were not part of the certification process. That subject has been discussed ad nauseam here and elsewhere. So my question to you is this: Whereas you have been doing this far too long to be a grad student and you occasionally change your writing style so that, for a few months at a time, your trolling is dramatically less effective or more effective; who really are you, how many are you, and why? |
Young Eagles + AvWeb | Montblack | Piloting | 28 | April 15th 06 12:07 AM |
Young Eagles Day & Fly-in at 47N | john price | Piloting | 0 | July 1st 04 04:33 AM |
Young Eagles Day & Fly-in at 47N | john price | Aviation Marketplace | 0 | July 1st 04 04:33 AM |
Young Eagles pilots | David Gunter | Piloting | 13 | January 16th 04 02:20 AM |
Young Eagles push (USA) | John H. Campbell | Soaring | 0 | September 22nd 03 03:48 PM |
