Add your own 'lessons learned'
Old July 5th 10, 06:56 PM posted to rec.aviation.piloting
a[_3_]
Default Add your own 'lessons learned'
This one did not break my airplane, but. . .
Landing in a cross wind at an uncontrolled airport -- it might have
been Urbana IL, not sure. Anyhow, there was a large barn not too far
from the centerline on the upwind side of the runway. I pretty much
had most of the rudder in, maybe 5 feet agl, when I got immediately
downwind of the barn. The barn might have even caused a touch of tail
wind -- the airplane ran out of lift right now, and dropped in. I
would have been surprised to see the wheel shafts poking thru the
upper wing surface, but hey, it's a Mooney and they are strong. (I did
not check to see if the dihedral increased.)
The lesson is, if there's any structure upwind and close to the
runway, either fly it on or land long -- otherwise you may be making a
much firmer landing than you intended.
Your turn.
Old July 5th 10, 08:54 PM posted to rec.aviation.piloting
VOR-DME[_3_]
With under 200h in my logbook, I heard a departure clearance just before
mine, but didn’t pay too much attention as it sounded like a helicopter,
and they were generally pretty far away from us at that airport. On
liftoff I got "Skylane Seven Niner Five report visual the AS three five
zero above you at your one o’clock". I looked up, and seeing the
Eurocopter I dutifully replied "Visual the Squirrel" when in no time at
all, still looking up, I was looking at the ground! Due to a really
unhappy wake turbulence incident with a helicopter I had, in zero
seconds flat become almost fully inverted at "maybe" 100AGL! I did the
wrong thing, which turned out to be right in upside-down world, I pulled
sharply, which made me climb rapidly toward the already close ground,
but gave me aileron authority to flip it right and nurse it back into
the sky. At least that’s my best guess as to how I got it righted and
flew away from that one. The fairly decent climb performance of the very
lightly-loaded 182, still in fine pitch probably didn’t hurt. Radio
silence - nobody said a thing.
Lesson learned - mainly don’t come anywhere near those buggers! But also
don’t necessarily count on ATC to manage wake turbulence spacing in a
case like this.
In article
says...
Your turn.
Old July 7th 10, 01:14 AM posted to rec.aviation.piloting
betwys1
Simulation?
Brian W
case like this.
In article
says...
Your turn.
Old July 7th 10, 10:14 PM posted to rec.aviation.piloting
VOR-DME[_3_]
says...
Simulation?
Wrong guy.
Icing tape - lessons learned. Capt. Geoffrey Thorpe Piloting 11 February 10th 07 10:44 AM
Lessons learned from the Oregon tragedy john smith Piloting 100 December 12th 06 04:34 AM
A Week Off the Grid: Lessons learned Vaughn Soaring 5 September 13th 04 01:17 AM
Runway Lights -- Lessons Learned John Clonts Instrument Flight Rules 0 August 29th 03 10:41 PM
Runway Lights -- Lessons Learned John Clonts Piloting 0 August 29th 03 10:41 PM
