I have SZD-48-3 and use Cobra one-man rigger. I assemble the glider
every time I fly, and put it back in the box after landing. The tool is fantastic. I could not get by without it. No helpers needed when rigging and de-rigging, although I would recommend some assistance at the beginning. You need a decent stand to support the wing half already placed in the fuselage. Depending on available fore-aft adjustment on your rigger, you might have to pay a little extra attention to align the wings correctly. Typically the balance point of the wing is couple of inches outboard from the edge of the spoiler box on the lower wing surface. Although Jantar wings are a little bit on the heavy side, you will not tell the difference when properly balanced on the rigger. At a leisurely pace it takes about 40 minutes to have the glider ready to fly from the arrival to the airport. Takes less to disassemble. Strongly recommend Robert On Jul 7, 6:33*am, John wrote: I am considering a one-man to assist in the assembly - I figure it will work but since the wings are a bit bigger than other gliders I assist with assembly, I'm curious if other jantar-drivers use a one- man and comments on how it works if they do. Thanks in advance, John |
Jantar Standard Canopy | jmarc | Soaring | 9 | August 22nd 17 04:13 AM |
WTB: Standard Jantar or ASW-19 | Kevin Christner | Soaring | 2 | January 9th 11 05:51 PM |
Airworthiness Directives for Jantar Standard 3 | Miguel Lavalle | Soaring | 5 | January 24th 04 10:55 AM |
Cockpit sizes of standard Jantar | goneill | Soaring | 2 | December 28th 03 11:29 AM |
Jantar Standard 3 | Miguel Lavalle | Soaring | 9 | November 19th 03 12:01 AM |
