Giles Ayling giles tvp.ltd.uk wrote:
Keith Willshaw wrote: "John Doe" wrote in message .... I get the impression that propeller power is nowhere near efficient as conventional motor and wheel on the ground propulsion. That is the question. No that is the answer. Jet / Propellor / rubber band. It doesnt mallet what the power supply is. Are you using speech recognition? Or were you drunk? Just curious. Work out where the center of thrust/pull is - Probably if on a skater approx 1.2metres up. When the skater hit a bump to large for the front to quickly rise over, the skater kisses the ground. Skating is extremely flexible. One way to cope is to step over the obstacle. Another way is by keeping your weight on your rear wheels. And yet another way to cope with larger obstacles is called "scissoring". And of course you can do stuff in combination. If none of the above works, when you hit a bump that radically slows one skate, you can quickly put all of your weight on the other skate and simultaneously steer inwards with that good skate to maintain your balance. You learn to do that stuff without thinking. But, coincidentally, large unexpected obstacles is exactly why I made big front wheel skates, a 140 mm front wheel with 80 mm trailing wheels. Love them and use them for rough street skating regularly. http://www.flickr.com/photos/27532210@N04/3056505603/ http://www.flickr.com/photos/27532210 N04/3056505603/ By the way... If anyone here (young enough to run or at least to remember doing fun things) has never heard of "powered paragliding", check it out! It is (lighter than) ultra light powered flight. Amazing stuff IMO. Dozens of videos on YouTube. -- Think water skiing - It is a challenge to get up o the skiis, and then the second you relax, and let the ski dig it, you are in the water |
Just push the blue button! | Darkwing | Piloting | 71 | October 20th 08 04:12 PM |
PUSH START | stanley adelson | Aviation Photos | 0 | July 15th 08 01:16 AM |
Push to Talk Switch | Jackal24 | Piloting | 23 | December 26th 04 10:01 PM |
Question about center-line push-pull engine configuration | Shin Gou | Home Built | 4 | June 7th 04 05:57 PM |
Young Eagles push (USA) | John H. Campbell | Soaring | 0 | September 22nd 03 03:48 PM |
