On 7/23/2010 3:05 PM, Darryl Ramm wrote:
On Jul 23, 12:01 pm, Mike wrote: On 7/23/2010 11:57 AM, Darryl Ramm wrote: On Jul 23, 8:14 am, Mike wrote: It looks like the low cost ADS-B UAT logjam has been broken: http://www.aopa.org/advocacy/article...x.html?WT.mc_i... While the price is somewhat higher than I would like to see, it's competitive with buying a transponder coupled with a Zaon PCAS XRX. If you are within range of an ADS-B ground station, you get much more accurate and reliable position data for conflicting traffic, free weather, lower power consumption, plus you are visible to ATC!!!! The down sides: No TSO, so the unit will not currently meet the 2020 ADS-B mandates; Not visible to TCAS systems. Check them out at Oshkosh or on the web atwww.navworx.com. -- Mike Schumann While it is great to see ADS-B products appearing for the GA market I do not see this being a practical ADS-B product for glider applications. It does not support FLARM serial protocol so there is no way of getting traffic display or audible alerts via most popular soaring software or flight computers. My understanding from the manufacturer is they don't have any interest in supporting this. Has they changed their minds on that? None of the third party traffic warning systems that it interfaces to are tuned/optimized for glider-on-glider situations. Low power consumption? Are their published specs wrong? Those specs state a power draw of 0.7A @ 14VDC. If that is accurate then lets guess 0.8 A at 12 V, plus most installations will need to add the power requirements for a dedicated traffic display. That power draw is just not practical for many glider installations. Yet again I am dissapointed to see you position ADS-B as a replacement for a transponder. If there were no other issues with this device, many glider pilots in high density airline/fast-jet traffic areas will want/need to keep using a transponder. So I am not sure about the point of comparing the price to a transponder based system, those owners (who presumably are the ones buying transponders today) would want to add the price to a transponder to this system. The $2,500 price point plus the cost of whatever display system is needed to make this work, plus in some case where needed, the cost of a trasnponder, will disappoint many people. Unfortunately there are just no "low-cost" (well not as low as many people seem to have been expecting) ADS-B solutions for gliders now from any vendors. I am not sure of the point of conparing the cost of a transponder plus Zaon XRX (which nobody uses in gliders - I am aware of one test install). Did you mean MRX? The more interesting comparison for many reasons, not just cost, is to a PowerFLARM (with 1090ES data-in) + Trig TT21. That combination will be in the rough same cost range as the NavWorx ADS-B system plus the seperate display needed to make that work. But at least there you get full transponder functionality, integrated traffic display, FLARMs glider-on-glider optimized traffic warnings (as noted elsewhere you have to wait a while for TIS-B traffic support) and FLARM-FLARM radio compatibly with other PowerFLARM devices should they become popular in the USA. But this 1090ES based system would not provide FIS-B (weather etc.) data. Maybe all these prices will fall some over time but I'd not expect that to happen soon. And as a reminder to other folks gliders currently do not need to meet the 2020 ADS-B mandate. I am hoping that does not change. Darryl I am not discouraging people from investing in transponders. On the other hand, FLARM is a huge distraction for people in the US. It's never going to be a viable collision avoidance technology, given its virtually zero adoption rate in this country. ADS-B, on the other hand, does have promise in those areas where you are within range of a ground station. TCAS equipped jets will not see you, but ADS-B In equipped jets will. So will ATC. TCAS was always meant to be a last line of defense against mid-airs. Instead, it is being used as a 1st line. What we need is a change in attitude in the FAA to actively vector IFR traffic around all visible GA targets, whether transponder or ADS-B UAT equipped. This should be something that is at the top of the SSA and AOPA's priority list. Interfacing the Navworx or other ADS-B units to glide computers is something that should not be a big issue if we can generate the necessary interest in the soaring community to make this worth the vendors' time. This can either be done by NAVWORX emulating FLARM or the glide computer vendors supporting the ADS-B / Mode S TIS formats that all of the other GPS displays that are supported by ZAON and Navworx implement. The problem with PowerFLARM and Zaon, is that both of these technologies rely on other users (TCAS equipped aircraft or ground radars) to initiate the interogation of transponders. If that doesn't happen, you won't see the traffic. As a result, you are getting a false sense of security when you are flying in remote areas. The only solution to this is for all low altitude aircraft (gliders, etc.) to standardize on ADS-B UAT. If we end up with a mixture of PowerFLARM Zaon PCAS, 1090ES, etc., we will never solve this issue. -- Mike Schumann If you do not want to discouraging people to adopt transponders maybe you could stop leading discussions on UAT devices by comparing them price and otherwise to transponders. As for Flarm (specifically PowerFLARM in the USA) being a distraction. I'm not sure how the only system that really effectively offers a solution for glider-on-glider collision avoidance is a distraction. If somebody was pushing Flarm at the expense of ADS-B products I'd be worried but again as has been pointed out here before, Flarm or their distributors are not encouraging adoption of a FLARM protocol only device in the USA market. They are promoting a PowerFLARM device with PCAS and 1090ES ADS-B data-in support which at least in my mind provides a pretty good roadmap for future ADS-B usage. I expect the PowerFLARM product to get significant traction in the glider market in the USA and at least to do so more rapildy than any stand-alone ADS-B product. Especially since it is the only product (in the USA market) that really is capable of addressing glider-on-glider collisions avoidance and is actually practical to install in glider cockpits. There just is not a single other ADS-B data-in (or data-out/ in) product available or likely to be available soon that is practical for our cockpits so I simply just do not see anything new happening here except PowerFLARM adoption. And I'd like to see competing products appear, I just don't see any ones coming for a significant time. I know I am mixing issues of glide-on-glider and fast-jet/ airliner scenarios but here with PowerFLARM is a product that helps do both (when used with a transponder, especially a Mode-S transponder with 1090ES data-out) and that dual purpose I suspect will appeal to many purchasers. Costs for ADS-B via PowerFLARM+transponder or other ADS-B systems will likely keep many people from installing those. However I would not be surprised to see many contest pilots thinking about installing PowerFLARM for its FLARM-FLARM protocol capability given recent mid- air collisions in contests in the USA and overseas. And that it has a 1090ES capability for future is a nice thing. With World contests heading this way I hope there is a plan underway to encourage use of FLARM-FLARM devices in gliders flying those contests, where a significant number of pilots will already be FLARM users, whether they would use their own FLARM (adjusted for USA frequencies) or PowerFLARM devices. The PCAS part of PowerFLARM relies on external transponder interrogations. The TIS-B part (when supported by their software) will not. However TIS-B only provides traffic coverage where there is currently SSR radar (or in some cases multilateration) coverage. This means that even with TIS-B a PCAS capability may be the only warning a glider pilots would get of a transponder equipped aircraft where there is no SSR coverage but there is enough transponder interrogation for PCAS. So even with TIS-B coverage that PCAS capability is kind of a nice feature to have, not at the top of my list, but nice. And of course in addition to being in an area of SSR coverage you also need ADS-B ground station coverage to receive the TIS-B and ADS-R data for any of these ADS-B devices. There is not going to be any standardization on UAT for low-altitude/ GA traffic and hoping for that is really a waste of time. The FAA finally got it's ADS-B mandate out, it's been a painful process. Discussion over, there is no low-altitude standardization on UAT. As I've pointed out before many GA aircraft will likely deploy 1090ES data-out as its an easy upgrade to many Mode S transponders like the Garmin GTX-33/330 family. Adding UAT data-out (and data-in) may be appealing in other cases. So there will be a mix of nothing, Mode C, Mode S, PCAS, UAT, 1090ES and Flarm (via PowerFLARM) in our USA glider fleet and we all need to focus on how to deal with that reality. Darryl The majority of glider pilots in the US are not flying in contests. Their primary collision threats are powered GA aircraft and airliners. FLARM is never going to take hold in those markets in the US. The idea that 1090ES is the only ADS-B option available for gliders may have been true last week. The Navworx ADS-B UAT transceiver now provides another option. The only hangup is that they don't currently interface to the most popular glide computers. Rather than bash the Navworx option, it would be much more productive to make the glide computer vendors aware of this unit so they can interface with it. I suspect that in the US, future ADS-B in devices (UAT and 1090ES) will use the Navworx interface, not FLARM, so that would be in everyone's long term interest. -- Mike Schumann |
On Jul 23, 7:19*pm, Mike Schumann
wrote: On 7/23/2010 3:05 PM, Darryl Ramm wrote: On Jul 23, 12:01 pm, Mike wrote: On 7/23/2010 11:57 AM, Darryl Ramm wrote: On Jul 23, 8:14 am, Mike wrote: It looks like the low cost ADS-B UAT logjam has been broken: http://www.aopa.org/advocacy/article...x.html?WT.mc_i.... While the price is somewhat higher than I would like to see, it's competitive with buying a transponder coupled with a Zaon PCAS XRX. *If you are within range of an ADS-B ground station, you get much more accurate and reliable position data for conflicting traffic, free weather, lower power consumption, plus you are visible to ATC!!!! The down sides: *No TSO, so the unit will not currently meet the 2020 ADS-B mandates; *Not visible to TCAS systems. Check them out at Oshkosh or on the web atwww.navworx.com. -- Mike Schumann While it is great to see ADS-B products appearing for the GA market I do not see this being a practical ADS-B product for glider applications. It does not support FLARM serial protocol so there is no way of getting traffic display or audible alerts via most popular soaring software or flight computers. My understanding from the manufacturer is they don't have any interest in supporting this. Has they changed their minds on that? None of the third party traffic warning systems that it interfaces to are tuned/optimized for glider-on-glider situations. Low power consumption? Are their published specs wrong? Those specs state a power draw of 0.7A @ 14VDC. If that is accurate then lets guess 0.8 A at 12 V, plus most installations will need to add the power requirements for a dedicated traffic display. That power draw is just not practical for many glider installations. Yet again I am dissapointed to see you position ADS-B as a replacement for a transponder. *If there were no other issues with this device, many glider pilots in high density airline/fast-jet traffic areas will want/need to keep using a transponder. So I am not sure about the point of comparing the price to a transponder based system, those owners (who presumably are the ones buying transponders today) would want to add the price to a transponder to this system. The $2,500 price point plus the cost of whatever display system is needed to make this work, plus in some case where needed, the cost of a trasnponder, will disappoint many people. Unfortunately there are just no "low-cost" (well not as low as many people seem to have been expecting) ADS-B solutions for gliders now from any vendors. I am not sure of the point of conparing the cost of a transponder plus Zaon XRX (which nobody uses in gliders - I am aware of one test install). Did you mean MRX? *The more interesting comparison for many reasons, not just cost, is to a PowerFLARM (with 1090ES data-in) + Trig TT21. That combination will be in the rough same cost range as the NavWorx ADS-B system plus the seperate display needed to make that work. But at least there you get full transponder functionality, integrated traffic display, FLARMs glider-on-glider optimized traffic warnings (as noted elsewhere you have to wait a while for TIS-B traffic support) and FLARM-FLARM radio compatibly with other PowerFLARM devices should they become popular in the USA. But this 1090ES based system would not provide FIS-B (weather etc.) data. Maybe all these prices will fall some over time but I'd not expect that to happen soon. And as a reminder to other folks gliders currently do not need to meet the 2020 ADS-B mandate. I am hoping that does not change. Darryl I am not discouraging people from investing in transponders. *On the other hand, FLARM is a huge distraction for people in the US. *It's never going to be a viable collision avoidance technology, given its virtually zero adoption rate in this country. ADS-B, on the other hand, does have promise in those areas where you are within range of a ground station. *TCAS equipped jets will not see you, but ADS-B In equipped jets will. *So will ATC. *TCAS was always meant to be a last line of defense against mid-airs. *Instead, it is being used as a 1st line. *What we need is a change in attitude in the FAA to actively vector IFR traffic around all visible GA targets, whether transponder or ADS-B UAT equipped. *This should be something that is at the top of the SSA and AOPA's priority list. Interfacing the Navworx or other ADS-B units to glide computers is something that should not be a big issue if we can generate the necessary interest in the soaring community to make this worth the vendors' time. This can either be done by NAVWORX emulating FLARM or the glide computer vendors supporting the ADS-B / Mode S TIS formats that all of the other GPS displays that are supported by ZAON and Navworx implement. The problem with PowerFLARM and Zaon, is that both of these technologies rely on other users (TCAS equipped aircraft or ground radars) to initiate the interogation of transponders. *If that doesn't happen, you won't see the traffic. *As a result, you are getting a false sense of security when you are flying in remote areas. *The only solution to this is for all low altitude aircraft (gliders, etc.) to standardize on ADS-B UAT. *If we end up with a mixture of PowerFLARM Zaon PCAS, 1090ES, etc., we will never solve this issue. -- Mike Schumann If you do not want to discouraging people to adopt transponders maybe you could stop leading discussions on UAT devices by comparing them price and otherwise to transponders. As for Flarm (specifically PowerFLARM in the USA) being a distraction. I'm not sure how the only system that really effectively offers a solution for glider-on-glider collision avoidance is a distraction. If somebody was pushing Flarm at the expense of ADS-B products I'd be worried but again as has been pointed out here before, Flarm or their distributors are not encouraging adoption of a FLARM protocol only device in the USA market. They are promoting a PowerFLARM device with PCAS and 1090ES ADS-B data-in support which at least in my mind provides a pretty good roadmap for future ADS-B usage. I expect the PowerFLARM product to get significant traction in the glider market in the USA and at least to do so more rapildy than any stand-alone ADS-B product. Especially since it is the only product (in the USA market) that really is capable of addressing glider-on-glider collisions avoidance and is actually practical to install in glider cockpits. There just is not a single other ADS-B data-in (or data-out/ in) product available or likely to be available soon that is practical for our cockpits so I simply just do not see anything new happening here except PowerFLARM adoption. And I'd like to see competing products appear, I just don't see any ones coming for a significant time. I know I am mixing issues of glide-on-glider and fast-jet/ airliner scenarios but here with PowerFLARM is a product that helps do both (when used with a transponder, especially a Mode-S transponder with 1090ES data-out) and that dual purpose I suspect will appeal to many purchasers. Costs for ADS-B via PowerFLARM+transponder or other ADS-B systems will likely keep many people from installing those. However I would not be surprised to see many contest pilots thinking about installing PowerFLARM for its FLARM-FLARM protocol capability given recent mid- air collisions in contests in the USA and overseas. And that it has a 1090ES capability for future is a nice thing. With World contests heading this way I hope there is a plan underway to encourage use of FLARM-FLARM devices in gliders flying those contests, where a significant number of pilots will already be FLARM users, whether they would use their own FLARM (adjusted for USA frequencies) or PowerFLARM devices. The PCAS part of PowerFLARM relies on external transponder interrogations. The TIS-B part (when supported by their software) will not. However TIS-B only provides traffic coverage where there is currently SSR radar (or in some cases multilateration) coverage. This means that even with TIS-B a PCAS capability may be the only warning a glider pilots would get of a transponder equipped aircraft where there is no SSR coverage but there is enough transponder interrogation for PCAS. So even with TIS-B coverage that PCAS capability is kind of a nice feature to have, not at the top of my list, but nice. And of course in addition to being in an area of SSR coverage you also need ADS-B ground station coverage to receive the TIS-B and ADS-R data for any of these ADS-B devices. There is not going to be any standardization on UAT for low-altitude/ GA traffic and hoping for that is really a waste of time. The FAA finally got it's ADS-B mandate out, it's been a painful process. Discussion over, there is no low-altitude standardization on UAT. As I've pointed out before many GA aircraft will likely deploy 1090ES data-out as its an easy upgrade to many Mode S transponders like the Garmin GTX-33/330 family. Adding UAT data-out (and data-in) may be appealing in other cases. *So there will be a mix of nothing, Mode C, Mode S, PCAS, UAT, 1090ES and Flarm (via PowerFLARM) in our USA glider fleet and we all need to focus on how to deal with that reality. Darryl The majority of glider pilots in the US are not flying in contests. Their primary collision threats are powered GA aircraft and airliners. FLARM is never going to take hold in those markets in the US. The idea that 1090ES is the only ADS-B option available for gliders may have been true last week. The Navworx ADS-B UAT transceiver now provides another option. *The only hangup is that they don't currently interface to the most popular glide computers. Rather than bash the Navworx option, it would be much more productive to make the glide computer vendors aware of this unit so they can interface with it. *I suspect that in the US, future ADS-B in devices (UAT and 1090ES) will use the Navworx interface, not FLARM, so that would be in everyone's long term interest. -- Mike Schumann The NavWorx just does not seem a viable option for gliders and I'm just not following why you keep trying to position it as one. If you did not try to hard to position it as one I guess I'd not be trying to point out the issues with it... And it is not just a single issue or display support... $2,500 without a display, No FLARM serial display support, no glider-optimized collision warning, what seems like 0.8 A (!) power consumption @ 12V, and a vendor who seems to have decided the glider market is not interesting. I've tried to encourage some of the soaring product vendors to support Garmin TIS protocol and similar in future for ADS-B data-in. I've worked to connect soaring software and hardware vendors in that space. I've tried to see whether NavWorx has any interesting in adding Flarm protocol support. So I'm not exactly naive about what needs to happen here to get something to be usable. I'd love to see ADS-B products (UAT and/or 1090ES) that fit our needs but this just ain't one of them. The NavWorx transciever deserves mention as the first new UAT transceiver for the GA market--since the Garmin/UPS product that was really built for the Alaska trials. And the NavWorx has a much better packaging and price point that that, although it still needs TSO approval. And if they get it TSO'ed it will fit a need in the GA market especially for aircraft with older panels and non-Mode S transponders that cannot be upgraded to 1090ES data-out, and for NavWorx I suspect that market is a good target for them. To the extent it shows some movement in the ADS-B market that is good, and worth pointing out on r.a.s to glider pilots, but as a product we would actually use it is just not a good fit. And I'm not just picking on the NavWorx, I've also pointed out the Trig 1090ES receiver product, also an interesting product for the GA market, but has some of the same issues as I've pointed out above for us. Darryl |
On 7/23/2010 10:42 PM, Darryl Ramm wrote:
On Jul 23, 7:19 pm, Mike wrote: On 7/23/2010 3:05 PM, Darryl Ramm wrote: On Jul 23, 12:01 pm, Mike wrote: On 7/23/2010 11:57 AM, Darryl Ramm wrote: On Jul 23, 8:14 am, Mike wrote: It looks like the low cost ADS-B UAT logjam has been broken: http://www.aopa.org/advocacy/article...x.html?WT.mc_i... While the price is somewhat higher than I would like to see, it's competitive with buying a transponder coupled with a Zaon PCAS XRX. If you are within range of an ADS-B ground station, you get much more accurate and reliable position data for conflicting traffic, free weather, lower power consumption, plus you are visible to ATC!!!! The down sides: No TSO, so the unit will not currently meet the 2020 ADS-B mandates; Not visible to TCAS systems. Check them out at Oshkosh or on the web atwww.navworx.com. -- Mike Schumann While it is great to see ADS-B products appearing for the GA market I do not see this being a practical ADS-B product for glider applications. It does not support FLARM serial protocol so there is no way of getting traffic display or audible alerts via most popular soaring software or flight computers. My understanding from the manufacturer is they don't have any interest in supporting this. Has they changed their minds on that? None of the third party traffic warning systems that it interfaces to are tuned/optimized for glider-on-glider situations. Low power consumption? Are their published specs wrong? Those specs state a power draw of 0.7A @ 14VDC. If that is accurate then lets guess 0.8 A at 12 V, plus most installations will need to add the power requirements for a dedicated traffic display. That power draw is just not practical for many glider installations. Yet again I am dissapointed to see you position ADS-B as a replacement for a transponder. If there were no other issues with this device, many glider pilots in high density airline/fast-jet traffic areas will want/need to keep using a transponder. So I am not sure about the point of comparing the price to a transponder based system, those owners (who presumably are the ones buying transponders today) would want to add the price to a transponder to this system. The $2,500 price point plus the cost of whatever display system is needed to make this work, plus in some case where needed, the cost of a trasnponder, will disappoint many people. Unfortunately there are just no "low-cost" (well not as low as many people seem to have been expecting) ADS-B solutions for gliders now from any vendors. I am not sure of the point of conparing the cost of a transponder plus Zaon XRX (which nobody uses in gliders - I am aware of one test install). Did you mean MRX? The more interesting comparison for many reasons, not just cost, is to a PowerFLARM (with 1090ES data-in) + Trig TT21. That combination will be in the rough same cost range as the NavWorx ADS-B system plus the seperate display needed to make that work. But at least there you get full transponder functionality, integrated traffic display, FLARMs glider-on-glider optimized traffic warnings (as noted elsewhere you have to wait a while for TIS-B traffic support) and FLARM-FLARM radio compatibly with other PowerFLARM devices should they become popular in the USA. But this 1090ES based system would not provide FIS-B (weather etc.) data. Maybe all these prices will fall some over time but I'd not expect that to happen soon. And as a reminder to other folks gliders currently do not need to meet the 2020 ADS-B mandate. I am hoping that does not change. Darryl I am not discouraging people from investing in transponders. On the other hand, FLARM is a huge distraction for people in the US. It's never going to be a viable collision avoidance technology, given its virtually zero adoption rate in this country. ADS-B, on the other hand, does have promise in those areas where you are within range of a ground station. TCAS equipped jets will not see you, but ADS-B In equipped jets will. So will ATC. TCAS was always meant to be a last line of defense against mid-airs. Instead, it is being used as a 1st line. What we need is a change in attitude in the FAA to actively vector IFR traffic around all visible GA targets, whether transponder or ADS-B UAT equipped. This should be something that is at the top of the SSA and AOPA's priority list. Interfacing the Navworx or other ADS-B units to glide computers is something that should not be a big issue if we can generate the necessary interest in the soaring community to make this worth the vendors' time. This can either be done by NAVWORX emulating FLARM or the glide computer vendors supporting the ADS-B / Mode S TIS formats that all of the other GPS displays that are supported by ZAON and Navworx implement. The problem with PowerFLARM and Zaon, is that both of these technologies rely on other users (TCAS equipped aircraft or ground radars) to initiate the interogation of transponders. If that doesn't happen, you won't see the traffic. As a result, you are getting a false sense of security when you are flying in remote areas. The only solution to this is for all low altitude aircraft (gliders, etc.) to standardize on ADS-B UAT. If we end up with a mixture of PowerFLARM Zaon PCAS, 1090ES, etc., we will never solve this issue. -- Mike Schumann If you do not want to discouraging people to adopt transponders maybe you could stop leading discussions on UAT devices by comparing them price and otherwise to transponders. As for Flarm (specifically PowerFLARM in the USA) being a distraction. I'm not sure how the only system that really effectively offers a solution for glider-on-glider collision avoidance is a distraction. If somebody was pushing Flarm at the expense of ADS-B products I'd be worried but again as has been pointed out here before, Flarm or their distributors are not encouraging adoption of a FLARM protocol only device in the USA market. They are promoting a PowerFLARM device with PCAS and 1090ES ADS-B data-in support which at least in my mind provides a pretty good roadmap for future ADS-B usage. I expect the PowerFLARM product to get significant traction in the glider market in the USA and at least to do so more rapildy than any stand-alone ADS-B product. Especially since it is the only product (in the USA market) that really is capable of addressing glider-on-glider collisions avoidance and is actually practical to install in glider cockpits. There just is not a single other ADS-B data-in (or data-out/ in) product available or likely to be available soon that is practical for our cockpits so I simply just do not see anything new happening here except PowerFLARM adoption. And I'd like to see competing products appear, I just don't see any ones coming for a significant time. I know I am mixing issues of glide-on-glider and fast-jet/ airliner scenarios but here with PowerFLARM is a product that helps do both (when used with a transponder, especially a Mode-S transponder with 1090ES data-out) and that dual purpose I suspect will appeal to many purchasers. Costs for ADS-B via PowerFLARM+transponder or other ADS-B systems will likely keep many people from installing those. However I would not be surprised to see many contest pilots thinking about installing PowerFLARM for its FLARM-FLARM protocol capability given recent mid- air collisions in contests in the USA and overseas. And that it has a 1090ES capability for future is a nice thing. With World contests heading this way I hope there is a plan underway to encourage use of FLARM-FLARM devices in gliders flying those contests, where a significant number of pilots will already be FLARM users, whether they would use their own FLARM (adjusted for USA frequencies) or PowerFLARM devices. The PCAS part of PowerFLARM relies on external transponder interrogations. The TIS-B part (when supported by their software) will not. However TIS-B only provides traffic coverage where there is currently SSR radar (or in some cases multilateration) coverage. This means that even with TIS-B a PCAS capability may be the only warning a glider pilots would get of a transponder equipped aircraft where there is no SSR coverage but there is enough transponder interrogation for PCAS. So even with TIS-B coverage that PCAS capability is kind of a nice feature to have, not at the top of my list, but nice. And of course in addition to being in an area of SSR coverage you also need ADS-B ground station coverage to receive the TIS-B and ADS-R data for any of these ADS-B devices. There is not going to be any standardization on UAT for low-altitude/ GA traffic and hoping for that is really a waste of time. The FAA finally got it's ADS-B mandate out, it's been a painful process. Discussion over, there is no low-altitude standardization on UAT. As I've pointed out before many GA aircraft will likely deploy 1090ES data-out as its an easy upgrade to many Mode S transponders like the Garmin GTX-33/330 family. Adding UAT data-out (and data-in) may be appealing in other cases. So there will be a mix of nothing, Mode C, Mode S, PCAS, UAT, 1090ES and Flarm (via PowerFLARM) in our USA glider fleet and we all need to focus on how to deal with that reality. Darryl The majority of glider pilots in the US are not flying in contests. Their primary collision threats are powered GA aircraft and airliners. FLARM is never going to take hold in those markets in the US. The idea that 1090ES is the only ADS-B option available for gliders may have been true last week. The Navworx ADS-B UAT transceiver now provides another option. The only hangup is that they don't currently interface to the most popular glide computers. Rather than bash the Navworx option, it would be much more productive to make the glide computer vendors aware of this unit so they can interface with it. I suspect that in the US, future ADS-B in devices (UAT and 1090ES) will use the Navworx interface, not FLARM, so that would be in everyone's long term interest. -- Mike Schumann The NavWorx just does not seem a viable option for gliders and I'm just not following why you keep trying to position it as one. If you did not try to hard to position it as one I guess I'd not be trying to point out the issues with it... And it is not just a single issue or display support... $2,500 without a display, No FLARM serial display support, no glider-optimized collision warning, what seems like 0.8 A (!) power consumption @ 12V, and a vendor who seems to have decided the glider market is not interesting. I've tried to encourage some of the soaring product vendors to support Garmin TIS protocol and similar in future for ADS-B data-in. I've worked to connect soaring software and hardware vendors in that space. I've tried to see whether NavWorx has any interesting in adding Flarm protocol support. So I'm not exactly naive about what needs to happen here to get something to be usable. I'd love to see ADS-B products (UAT and/or 1090ES) that fit our needs but this just ain't one of them. The NavWorx transciever deserves mention as the first new UAT transceiver for the GA market--since the Garmin/UPS product that was really built for the Alaska trials. And the NavWorx has a much better packaging and price point that that, although it still needs TSO approval. And if they get it TSO'ed it will fit a need in the GA market especially for aircraft with older panels and non-Mode S transponders that cannot be upgraded to 1090ES data-out, and for NavWorx I suspect that market is a good target for them. To the extent it shows some movement in the ADS-B market that is good, and worth pointing out on r.a.s to glider pilots, but as a product we would actually use it is just not a good fit. And I'm not just picking on the NavWorx, I've also pointed out the Trig 1090ES receiver product, also an interesting product for the GA market, but has some of the same issues as I've pointed out above for us. Darryl Please explain exactly why the Navworx product is not suitable for gliders? This unit is similar in size and design to the prototypes that MITRE is testing in conjunction with the SSA, AOPA, and the FAA. Is the MITRE unit also unsuitable in your opinion? -- Mike Schumann |
On 7/23/2010 8:51 PM, Mike Schumann wrote:
The NavWorx transciever deserves mention as the first new UAT transceiver for the GA market--since the Garmin/UPS product that was really built for the Alaska trials. And the NavWorx has a much better packaging and price point that that, although it still needs TSO approval. And if they get it TSO'ed it will fit a need in the GA market especially for aircraft with older panels and non-Mode S transponders that cannot be upgraded to 1090ES data-out, and for NavWorx I suspect that market is a good target for them. To the extent it shows some movement in the ADS-B market that is good, and worth pointing out on r.a.s to glider pilots, but as a product we would actually use it is just not a good fit. And I'm not just picking on the NavWorx, I've also pointed out the Trig 1090ES receiver product, also an interesting product for the GA market, but has some of the same issues as I've pointed out above for us. Darryl Please explain exactly why the Navworx product is not suitable for gliders? This unit is similar in size and design to the prototypes that MITRE is testing in conjunction with the SSA, AOPA, and the FAA. Is the MITRE unit also unsuitable in your opinion? For me, that 0.8 amps seems like a lot. My current setup, with radio, transponder, vario, gps, mrx, PDA takes 0.8 amps, so this would double it to 1.6 amps. Fly 8 hours, that's 12.8 amp hours. Not so bad for me since I have an 18 ah battery, but I'd need to charge it every day, and be careful in cold weather I don't run out. How many glider pilots are prepared for that kind of drain? Look at all the whining over just 0.4 amps for a transponder. The other thing is the $2500, while people keep talking about $1000 for the Mitre unit being about right. I think that extra $1500 is going to stop a lot of pilots from considering it, or they'll say "shoot, I'll just put in a Trig for $2000, and I don't need to double my battery size; the airliners will see me and so will the big-bucks pilots that put the Navworx in their ship". -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On 7/24/2010 12:04 AM, Eric Greenwell wrote:
On 7/23/2010 8:51 PM, Mike Schumann wrote: The NavWorx transciever deserves mention as the first new UAT transceiver for the GA market--since the Garmin/UPS product that was really built for the Alaska trials. And the NavWorx has a much better packaging and price point that that, although it still needs TSO approval. And if they get it TSO'ed it will fit a need in the GA market especially for aircraft with older panels and non-Mode S transponders that cannot be upgraded to 1090ES data-out, and for NavWorx I suspect that market is a good target for them. To the extent it shows some movement in the ADS-B market that is good, and worth pointing out on r.a.s to glider pilots, but as a product we would actually use it is just not a good fit. And I'm not just picking on the NavWorx, I've also pointed out the Trig 1090ES receiver product, also an interesting product for the GA market, but has some of the same issues as I've pointed out above for us. Darryl Please explain exactly why the Navworx product is not suitable for gliders? This unit is similar in size and design to the prototypes that MITRE is testing in conjunction with the SSA, AOPA, and the FAA. Is the MITRE unit also unsuitable in your opinion? For me, that 0.8 amps seems like a lot. My current setup, with radio, transponder, vario, gps, mrx, PDA takes 0.8 amps, so this would double it to 1.6 amps. Fly 8 hours, that's 12.8 amp hours. Not so bad for me since I have an 18 ah battery, but I'd need to charge it every day, and be careful in cold weather I don't run out. How many glider pilots are prepared for that kind of drain? Look at all the whining over just 0.4 amps for a transponder. The other thing is the $2500, while people keep talking about $1000 for the Mitre unit being about right. I think that extra $1500 is going to stop a lot of pilots from considering it, or they'll say "shoot, I'll just put in a Trig for $2000, and I don't need to double my battery size; the airliners will see me and so will the big-bucks pilots that put the Navworx in their ship". There's no question that a lower price point would help. Hopefully we will see prices come down as there is more competition. As far as power consumption goes, has anyone looked at using solar cells to augment battery power? -- Mike Schumann |
On Jul 23, 10:53*pm, Mike Schumann
wrote: On 7/24/2010 12:04 AM, Eric Greenwell wrote: On 7/23/2010 8:51 PM, Mike Schumann wrote: The NavWorx transciever deserves mention as the first new UAT transceiver for the GA market--since the Garmin/UPS product that was really built for the Alaska trials. And the NavWorx has a much better packaging and price point that that, although it still needs TSO approval. And if they get it TSO'ed it will fit a need in the GA market especially for aircraft with older panels and non-Mode S transponders that cannot be upgraded to 1090ES data-out, and for NavWorx I suspect that market is a good target for them. To the extent it shows some movement in the ADS-B market that is good, and worth pointing out on r.a.s to glider pilots, but as a product we would actually use it is just not a good fit. And I'm not just picking on the NavWorx, I've also pointed out the Trig 1090ES receiver product, also an interesting product for the GA market, but has some of the same issues as I've pointed out above for us. Darryl Please explain exactly why the Navworx product is not suitable for gliders? This unit is similar in size and design to the prototypes that MITRE is testing in conjunction with the SSA, AOPA, and the FAA. Is the MITRE unit also unsuitable in your opinion? For me, that 0.8 amps seems like a lot. My current setup, with radio, transponder, vario, gps, mrx, PDA takes 0.8 amps, so this would double it to 1.6 amps. Fly 8 hours, that's 12.8 amp hours. Not so bad for me since I have an 18 ah battery, but I'd need to charge it every day, and be careful in cold weather I don't run out. How many glider pilots are prepared for that kind of drain? Look at all the whining over just 0.4 amps for a transponder. The other thing is the $2500, while people keep talking about $1000 for the Mitre unit being about right. I think that extra $1500 is going to stop a lot of pilots from considering it, or they'll say "shoot, I'll just put in a Trig for $2000, and I don't need to double my battery size; the airliners will see me and so will the big-bucks pilots that put the Navworx in their ship". There's no question that a lower price point would help. *Hopefully we will see prices come down as there is more competition. As far as power consumption goes, has anyone looked at using solar cells to augment battery power? -- Mike Schumann For several more thousand dollars more you can install a 30 W Strobl solar panel on your glider and given typical efficiency this will help with some installations. (I have the largest panels Strobl make installed one my motorglider). But you can't rely on the solar always working. You will still need a large battery (likely at least 12Ah and likely more for folks with long flights and other equipment). Now we are somewhere around $5k for the UAT installation and we still don't have a traffic display usable in a glider cockpit. (c'mon it's so awful somebody just tell me this power spec is just plain wrong). But don't surrender now. Your defense of this UAT box is entertaining. Darryl |
On 7/24/2010 1:46 AM, Darryl Ramm wrote:
On Jul 23, 10:53 pm, Mike wrote: On 7/24/2010 12:04 AM, Eric Greenwell wrote: On 7/23/2010 8:51 PM, Mike Schumann wrote: The NavWorx transciever deserves mention as the first new UAT transceiver for the GA market--since the Garmin/UPS product that was really built for the Alaska trials. And the NavWorx has a much better packaging and price point that that, although it still needs TSO approval. And if they get it TSO'ed it will fit a need in the GA market especially for aircraft with older panels and non-Mode S transponders that cannot be upgraded to 1090ES data-out, and for NavWorx I suspect that market is a good target for them. To the extent it shows some movement in the ADS-B market that is good, and worth pointing out on r.a.s to glider pilots, but as a product we would actually use it is just not a good fit. And I'm not just picking on the NavWorx, I've also pointed out the Trig 1090ES receiver product, also an interesting product for the GA market, but has some of the same issues as I've pointed out above for us. Darryl Please explain exactly why the Navworx product is not suitable for gliders? This unit is similar in size and design to the prototypes that MITRE is testing in conjunction with the SSA, AOPA, and the FAA. Is the MITRE unit also unsuitable in your opinion? For me, that 0.8 amps seems like a lot. My current setup, with radio, transponder, vario, gps, mrx, PDA takes 0.8 amps, so this would double it to 1.6 amps. Fly 8 hours, that's 12.8 amp hours. Not so bad for me since I have an 18 ah battery, but I'd need to charge it every day, and be careful in cold weather I don't run out. How many glider pilots are prepared for that kind of drain? Look at all the whining over just 0.4 amps for a transponder. The other thing is the $2500, while people keep talking about $1000 for the Mitre unit being about right. I think that extra $1500 is going to stop a lot of pilots from considering it, or they'll say "shoot, I'll just put in a Trig for $2000, and I don't need to double my battery size; the airliners will see me and so will the big-bucks pilots that put the Navworx in their ship". There's no question that a lower price point would help. Hopefully we will see prices come down as there is more competition. As far as power consumption goes, has anyone looked at using solar cells to augment battery power? -- Mike Schumann For several more thousand dollars more you can install a 30 W Strobl solar panel on your glider and given typical efficiency this will help with some installations. (I have the largest panels Strobl make installed one my motorglider). But you can't rely on the solar always working. You will still need a large battery (likely at least 12Ah and likely more for folks with long flights and other equipment). Now we are somewhere around $5k for the UAT installation and we still don't have a traffic display usable in a glider cockpit. (c'mon it's so awful somebody just tell me this power spec is just plain wrong). But don't surrender now. Your defense of this UAT box is entertaining. Darryl I am baffled by your negativism. The Navworx unit may not be perfect. What is significant is not necessarily this box, but the fact that this unit has been FCC approved, which will hopefully permit other, competitive units to also be commercialized. Now that these types of units are starting to come to the market, there will be a reason for See-You Mobile and other glide computers to provide the necessary interfaces. This is just a question of time and user demand. -- Mike Schumann |
Inspection Authorization | [email protected] | Home Built | 2 | March 29th 07 01:15 AM |
FS: Val Com 760 TSO Transceiver | aieo | Aviation Marketplace | 8 | January 25th 07 04:38 PM |
Getting Authorization For A Medal You Feel You Deserve | Otis Willie | Naval Aviation | 0 | March 3rd 05 04:33 AM |
Getting Authorization For A Medal You Feel You Deserve | Otis Willie | Military Aviation | 0 | February 16th 04 04:40 AM |
Getting Authorization For A Medal You Feel You Deserve | Otis Willie | Naval Aviation | 0 | February 16th 04 04:39 AM |
