On 7/23/2010 8:51 PM, Mike Schumann wrote:
The NavWorx transciever deserves mention as the first new UAT transceiver for the GA market--since the Garmin/UPS product that was really built for the Alaska trials. And the NavWorx has a much better packaging and price point that that, although it still needs TSO approval. And if they get it TSO'ed it will fit a need in the GA market especially for aircraft with older panels and non-Mode S transponders that cannot be upgraded to 1090ES data-out, and for NavWorx I suspect that market is a good target for them. To the extent it shows some movement in the ADS-B market that is good, and worth pointing out on r.a.s to glider pilots, but as a product we would actually use it is just not a good fit. And I'm not just picking on the NavWorx, I've also pointed out the Trig 1090ES receiver product, also an interesting product for the GA market, but has some of the same issues as I've pointed out above for us. Darryl Please explain exactly why the Navworx product is not suitable for gliders? This unit is similar in size and design to the prototypes that MITRE is testing in conjunction with the SSA, AOPA, and the FAA. Is the MITRE unit also unsuitable in your opinion? For me, that 0.8 amps seems like a lot. My current setup, with radio, transponder, vario, gps, mrx, PDA takes 0.8 amps, so this would double it to 1.6 amps. Fly 8 hours, that's 12.8 amp hours. Not so bad for me since I have an 18 ah battery, but I'd need to charge it every day, and be careful in cold weather I don't run out. How many glider pilots are prepared for that kind of drain? Look at all the whining over just 0.4 amps for a transponder. The other thing is the $2500, while people keep talking about $1000 for the Mitre unit being about right. I think that extra $1500 is going to stop a lot of pilots from considering it, or they'll say "shoot, I'll just put in a Trig for $2000, and I don't need to double my battery size; the airliners will see me and so will the big-bucks pilots that put the Navworx in their ship". -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On 7/24/2010 12:04 AM, Eric Greenwell wrote:
On 7/23/2010 8:51 PM, Mike Schumann wrote: The NavWorx transciever deserves mention as the first new UAT transceiver for the GA market--since the Garmin/UPS product that was really built for the Alaska trials. And the NavWorx has a much better packaging and price point that that, although it still needs TSO approval. And if they get it TSO'ed it will fit a need in the GA market especially for aircraft with older panels and non-Mode S transponders that cannot be upgraded to 1090ES data-out, and for NavWorx I suspect that market is a good target for them. To the extent it shows some movement in the ADS-B market that is good, and worth pointing out on r.a.s to glider pilots, but as a product we would actually use it is just not a good fit. And I'm not just picking on the NavWorx, I've also pointed out the Trig 1090ES receiver product, also an interesting product for the GA market, but has some of the same issues as I've pointed out above for us. Darryl Please explain exactly why the Navworx product is not suitable for gliders? This unit is similar in size and design to the prototypes that MITRE is testing in conjunction with the SSA, AOPA, and the FAA. Is the MITRE unit also unsuitable in your opinion? For me, that 0.8 amps seems like a lot. My current setup, with radio, transponder, vario, gps, mrx, PDA takes 0.8 amps, so this would double it to 1.6 amps. Fly 8 hours, that's 12.8 amp hours. Not so bad for me since I have an 18 ah battery, but I'd need to charge it every day, and be careful in cold weather I don't run out. How many glider pilots are prepared for that kind of drain? Look at all the whining over just 0.4 amps for a transponder. The other thing is the $2500, while people keep talking about $1000 for the Mitre unit being about right. I think that extra $1500 is going to stop a lot of pilots from considering it, or they'll say "shoot, I'll just put in a Trig for $2000, and I don't need to double my battery size; the airliners will see me and so will the big-bucks pilots that put the Navworx in their ship". There's no question that a lower price point would help. Hopefully we will see prices come down as there is more competition. As far as power consumption goes, has anyone looked at using solar cells to augment battery power? -- Mike Schumann |
On Jul 23, 10:53*pm, Mike Schumann
wrote: On 7/24/2010 12:04 AM, Eric Greenwell wrote: On 7/23/2010 8:51 PM, Mike Schumann wrote: The NavWorx transciever deserves mention as the first new UAT transceiver for the GA market--since the Garmin/UPS product that was really built for the Alaska trials. And the NavWorx has a much better packaging and price point that that, although it still needs TSO approval. And if they get it TSO'ed it will fit a need in the GA market especially for aircraft with older panels and non-Mode S transponders that cannot be upgraded to 1090ES data-out, and for NavWorx I suspect that market is a good target for them. To the extent it shows some movement in the ADS-B market that is good, and worth pointing out on r.a.s to glider pilots, but as a product we would actually use it is just not a good fit. And I'm not just picking on the NavWorx, I've also pointed out the Trig 1090ES receiver product, also an interesting product for the GA market, but has some of the same issues as I've pointed out above for us. Darryl Please explain exactly why the Navworx product is not suitable for gliders? This unit is similar in size and design to the prototypes that MITRE is testing in conjunction with the SSA, AOPA, and the FAA. Is the MITRE unit also unsuitable in your opinion? For me, that 0.8 amps seems like a lot. My current setup, with radio, transponder, vario, gps, mrx, PDA takes 0.8 amps, so this would double it to 1.6 amps. Fly 8 hours, that's 12.8 amp hours. Not so bad for me since I have an 18 ah battery, but I'd need to charge it every day, and be careful in cold weather I don't run out. How many glider pilots are prepared for that kind of drain? Look at all the whining over just 0.4 amps for a transponder. The other thing is the $2500, while people keep talking about $1000 for the Mitre unit being about right. I think that extra $1500 is going to stop a lot of pilots from considering it, or they'll say "shoot, I'll just put in a Trig for $2000, and I don't need to double my battery size; the airliners will see me and so will the big-bucks pilots that put the Navworx in their ship". There's no question that a lower price point would help. *Hopefully we will see prices come down as there is more competition. As far as power consumption goes, has anyone looked at using solar cells to augment battery power? -- Mike Schumann For several more thousand dollars more you can install a 30 W Strobl solar panel on your glider and given typical efficiency this will help with some installations. (I have the largest panels Strobl make installed one my motorglider). But you can't rely on the solar always working. You will still need a large battery (likely at least 12Ah and likely more for folks with long flights and other equipment). Now we are somewhere around $5k for the UAT installation and we still don't have a traffic display usable in a glider cockpit. (c'mon it's so awful somebody just tell me this power spec is just plain wrong). But don't surrender now. Your defense of this UAT box is entertaining. Darryl |
On 7/24/2010 1:46 AM, Darryl Ramm wrote:
On Jul 23, 10:53 pm, Mike wrote: On 7/24/2010 12:04 AM, Eric Greenwell wrote: On 7/23/2010 8:51 PM, Mike Schumann wrote: The NavWorx transciever deserves mention as the first new UAT transceiver for the GA market--since the Garmin/UPS product that was really built for the Alaska trials. And the NavWorx has a much better packaging and price point that that, although it still needs TSO approval. And if they get it TSO'ed it will fit a need in the GA market especially for aircraft with older panels and non-Mode S transponders that cannot be upgraded to 1090ES data-out, and for NavWorx I suspect that market is a good target for them. To the extent it shows some movement in the ADS-B market that is good, and worth pointing out on r.a.s to glider pilots, but as a product we would actually use it is just not a good fit. And I'm not just picking on the NavWorx, I've also pointed out the Trig 1090ES receiver product, also an interesting product for the GA market, but has some of the same issues as I've pointed out above for us. Darryl Please explain exactly why the Navworx product is not suitable for gliders? This unit is similar in size and design to the prototypes that MITRE is testing in conjunction with the SSA, AOPA, and the FAA. Is the MITRE unit also unsuitable in your opinion? For me, that 0.8 amps seems like a lot. My current setup, with radio, transponder, vario, gps, mrx, PDA takes 0.8 amps, so this would double it to 1.6 amps. Fly 8 hours, that's 12.8 amp hours. Not so bad for me since I have an 18 ah battery, but I'd need to charge it every day, and be careful in cold weather I don't run out. How many glider pilots are prepared for that kind of drain? Look at all the whining over just 0.4 amps for a transponder. The other thing is the $2500, while people keep talking about $1000 for the Mitre unit being about right. I think that extra $1500 is going to stop a lot of pilots from considering it, or they'll say "shoot, I'll just put in a Trig for $2000, and I don't need to double my battery size; the airliners will see me and so will the big-bucks pilots that put the Navworx in their ship". There's no question that a lower price point would help. Hopefully we will see prices come down as there is more competition. As far as power consumption goes, has anyone looked at using solar cells to augment battery power? -- Mike Schumann For several more thousand dollars more you can install a 30 W Strobl solar panel on your glider and given typical efficiency this will help with some installations. (I have the largest panels Strobl make installed one my motorglider). But you can't rely on the solar always working. You will still need a large battery (likely at least 12Ah and likely more for folks with long flights and other equipment). Now we are somewhere around $5k for the UAT installation and we still don't have a traffic display usable in a glider cockpit. (c'mon it's so awful somebody just tell me this power spec is just plain wrong). But don't surrender now. Your defense of this UAT box is entertaining. Darryl I am baffled by your negativism. The Navworx unit may not be perfect. What is significant is not necessarily this box, but the fact that this unit has been FCC approved, which will hopefully permit other, competitive units to also be commercialized. Now that these types of units are starting to come to the market, there will be a reason for See-You Mobile and other glide computers to provide the necessary interfaces. This is just a question of time and user demand. -- Mike Schumann |
I agree the NavWorx is a good indicator of things to come. There's
another product that's out as an ADSB IN only UAT reciever that's small and ties into an iPhone, iPad, or iPod Touch. The receiver is $1,200. The software is free for 30 days and $39/year. True, it's not a soaring package, but it looks like a good aviation package. Here's a link: http://www.skyscope.net/skyscope-rec...-overview.html. I don't know anything about it except what I've read. One way to interface the UAT In information to the current soaring devices may be to write a device driver to translate the ADSB data stream to the Flarm data stream. I've written several device drivers for PC's nd several Windows CE/Mobile programs. However, I've never written drivers for Windows Mobile. Maybe it's not as easy as I think. Charlie |
On Jul 24, 6:47*am, cfinn wrote:
I agree the NavWorx is a good indicator of things to come. There's another product that's out as an ADSB IN only UAT reciever that's small and ties into an iPhone, iPad, or iPod Touch. The receiver is $1,200. The software is free for 30 days and $39/year. True, it's not a soaring package, but it looks like a good aviation package. Here's a link:http://www.skyscope.net/skyscope-rec...-overview.html. I don't know anything about it except what I've read. One way to interface the UAT In information to the current soaring devices may be to write a device driver to translate the ADSB data stream to the Flarm data stream. I've written several device drivers for PC's nd several Windows CE/Mobile programs. However, I've never written drivers for Windows Mobile. Maybe it's not as easy as I think. Charlie The SkyRadar receiver requires an ADS-B transmitter for its UAT receiver to work properly for traffic (e.g. to receive TIS-B and ADS- R). It is one of the venodors which started emphasizing more the weather reception capability over FIS-B (which does not require you have a ADS-B transmitter). The SkyRadar is one of the more interesting of several UAT receivers for GA applications. I like the iPAD integration for FIS-B for example. I'm aware of an author for a GA aviation magazine evaluating the SkyRadar and I'm interested in how he will find the unit and hope he does a write up on it. To do some actual comparisons for use in gliders... This SkyRadar receiver lists at $1,200 but has a current promotion running that reduces that $120. It specs at drawing about 0.4 A. You need to add an iPhone/iPod Touch or iPad or a Mountain Scope display today. As there is no current stand-along UAT transmitter the likely path to having this in a usable traffic display systems would be something like a Trig TT-21 with 1090ES data-out. I expect many glider pilots would prefer the more expensive but more glider-oriented PowerFLARM at ($1,495 into price in the USA and $1,695 list). So for comparison with what the SkyRadar does not offer: PowerFLARM has a buit-in display, offers serial FLARM protocol support for display on PDAs etc., glider tuned collision warnings, FLARM-to-FLARM radio protocol, built-in audible traffic warnins, PCAS transponder detection, IGC logger up through diamond badge, the option to power off internal batteries. However the PowerFLARM will not receive FIS-B, and won't have TIS-B support until a software update. So that all is not intended to bash the SkyRadar but to show a comparison to products for use in the glider cockpit. The comment of doing a protocol translating device driver could be capable of addressing some of this display compatibility issue. But in some cases there still needs to be a NMEA stream to drive the PDA soaring software or flight computer etc. The commonly used Garmin TIS serial port display protocol does not know anything about GPS data since the old Mode S TIS at its core just transmits relative positions from your aircraft to the threat aircraft. Many devices use the Garmin TIS protocol or a variant for traffic data, but some may be quite different. There may be an issue of running out of serial ports in some PDA/PNA installations if you require separate serial ports for traffic data and NMEA. You could build an outboard hardware box that combines the functions of serial port merging and protocol translation (and I am aware of one person who may well be playing with building their own such box for a similar application). The other issue is the way FLARM works is the the Flarm or PowerFLARM box does the threat assesment and uses glider-optimized algorithms to detect possible collisions and issue warnings. That's likely critically important in avoding a large number of false positive warnings in gaggles and other situations. So just to point out there is likely more work required to do this well than just adding a traffic display. Darryl |
Inspection Authorization | [email protected] | Home Built | 2 | March 29th 07 01:15 AM |
FS: Val Com 760 TSO Transceiver | aieo | Aviation Marketplace | 8 | January 25th 07 04:38 PM |
Getting Authorization For A Medal You Feel You Deserve | Otis Willie | Naval Aviation | 0 | March 3rd 05 04:33 AM |
Getting Authorization For A Medal You Feel You Deserve | Otis Willie | Military Aviation | 0 | February 16th 04 04:40 AM |
Getting Authorization For A Medal You Feel You Deserve | Otis Willie | Naval Aviation | 0 | February 16th 04 04:39 AM |
