I agree the NavWorx is a good indicator of things to come. There's
another product that's out as an ADSB IN only UAT reciever that's small and ties into an iPhone, iPad, or iPod Touch. The receiver is $1,200. The software is free for 30 days and $39/year. True, it's not a soaring package, but it looks like a good aviation package. Here's a link: http://www.skyscope.net/skyscope-rec...-overview.html. I don't know anything about it except what I've read. One way to interface the UAT In information to the current soaring devices may be to write a device driver to translate the ADSB data stream to the Flarm data stream. I've written several device drivers for PC's nd several Windows CE/Mobile programs. However, I've never written drivers for Windows Mobile. Maybe it's not as easy as I think. Charlie |
On Jul 24, 6:47*am, cfinn wrote:
I agree the NavWorx is a good indicator of things to come. There's another product that's out as an ADSB IN only UAT reciever that's small and ties into an iPhone, iPad, or iPod Touch. The receiver is $1,200. The software is free for 30 days and $39/year. True, it's not a soaring package, but it looks like a good aviation package. Here's a link:http://www.skyscope.net/skyscope-rec...-overview.html. I don't know anything about it except what I've read. One way to interface the UAT In information to the current soaring devices may be to write a device driver to translate the ADSB data stream to the Flarm data stream. I've written several device drivers for PC's nd several Windows CE/Mobile programs. However, I've never written drivers for Windows Mobile. Maybe it's not as easy as I think. Charlie The SkyRadar receiver requires an ADS-B transmitter for its UAT receiver to work properly for traffic (e.g. to receive TIS-B and ADS- R). It is one of the venodors which started emphasizing more the weather reception capability over FIS-B (which does not require you have a ADS-B transmitter). The SkyRadar is one of the more interesting of several UAT receivers for GA applications. I like the iPAD integration for FIS-B for example. I'm aware of an author for a GA aviation magazine evaluating the SkyRadar and I'm interested in how he will find the unit and hope he does a write up on it. To do some actual comparisons for use in gliders... This SkyRadar receiver lists at $1,200 but has a current promotion running that reduces that $120. It specs at drawing about 0.4 A. You need to add an iPhone/iPod Touch or iPad or a Mountain Scope display today. As there is no current stand-along UAT transmitter the likely path to having this in a usable traffic display systems would be something like a Trig TT-21 with 1090ES data-out. I expect many glider pilots would prefer the more expensive but more glider-oriented PowerFLARM at ($1,495 into price in the USA and $1,695 list). So for comparison with what the SkyRadar does not offer: PowerFLARM has a buit-in display, offers serial FLARM protocol support for display on PDAs etc., glider tuned collision warnings, FLARM-to-FLARM radio protocol, built-in audible traffic warnins, PCAS transponder detection, IGC logger up through diamond badge, the option to power off internal batteries. However the PowerFLARM will not receive FIS-B, and won't have TIS-B support until a software update. So that all is not intended to bash the SkyRadar but to show a comparison to products for use in the glider cockpit. The comment of doing a protocol translating device driver could be capable of addressing some of this display compatibility issue. But in some cases there still needs to be a NMEA stream to drive the PDA soaring software or flight computer etc. The commonly used Garmin TIS serial port display protocol does not know anything about GPS data since the old Mode S TIS at its core just transmits relative positions from your aircraft to the threat aircraft. Many devices use the Garmin TIS protocol or a variant for traffic data, but some may be quite different. There may be an issue of running out of serial ports in some PDA/PNA installations if you require separate serial ports for traffic data and NMEA. You could build an outboard hardware box that combines the functions of serial port merging and protocol translation (and I am aware of one person who may well be playing with building their own such box for a similar application). The other issue is the way FLARM works is the the Flarm or PowerFLARM box does the threat assesment and uses glider-optimized algorithms to detect possible collisions and issue warnings. That's likely critically important in avoding a large number of false positive warnings in gaggles and other situations. So just to point out there is likely more work required to do this well than just adding a traffic display. Darryl |
Inspection Authorization | [email protected] | Home Built | 2 | March 29th 07 01:15 AM |
FS: Val Com 760 TSO Transceiver | aieo | Aviation Marketplace | 8 | January 25th 07 04:38 PM |
Getting Authorization For A Medal You Feel You Deserve | Otis Willie | Naval Aviation | 0 | March 3rd 05 04:33 AM |
Getting Authorization For A Medal You Feel You Deserve | Otis Willie | Military Aviation | 0 | February 16th 04 04:40 AM |
Getting Authorization For A Medal You Feel You Deserve | Otis Willie | Naval Aviation | 0 | February 16th 04 04:39 AM |
