"Dudley Henriques" wrote...
The Kollsman range, which is also the basic baro range in the Viper's CADC which drives the Viper's altimeter in both ELECT and PNEU backup, is aprox 22.00 inches on the low side and 32.00 inches on the high side. This gives you, even figuring the 1 inch per thousand rule, an elevation reset capability to a zero reset before takeoff of 10, 000 feet. This basically allows a zero reset anywhere in the U.S. at least, allowing for a standard atmosphere. Not quite... You have a 10,000' nominal range using that rule of thumb, but from the 29.92" standard you only have 7,920' of 'low' correction available at sea level, and 2080' of 'high' correction. That gives you QFE capability up to an airport elevation of 7,920'. Still, as you say, adequate for most US airports in most conditions. It also illustrates the complexity in attempting to fly IFR using QFE (0' runway altitude) at high-altitude airports. If you use the wrong setting, misinterpret a controller's QFE / QNH call, or use the wrong minimums on a chart, it can be deadly. Those errors are all too easy to make, especially if you are not used to using QFE at all. |
![]() "John R Weiss" wrote in message news:eHbRb.152481$I06.1538887@attbi_s01... "Dudley Henriques" wrote... The Kollsman range, which is also the basic baro range in the Viper's CADC which drives the Viper's altimeter in both ELECT and PNEU backup, is aprox 22.00 inches on the low side and 32.00 inches on the high side. This gives you, even figuring the 1 inch per thousand rule, an elevation reset capability to a zero reset before takeoff of 10, 000 feet. This basically allows a zero reset anywhere in the U.S. at least, allowing for a standard atmosphere. Not quite... You have a 10,000' nominal range using that rule of thumb, but from the 29.92" standard you only have 7,920' of 'low' correction available at sea level, and 2080' of 'high' correction. That gives you QFE capability up to an airport elevation of 7,920'. Still, as you say, adequate for most US airports in most conditions. Yeah, that's right JW. There's a positive/negative factor in there above that 29.92 that splits that 10K. It also illustrates the complexity in attempting to fly IFR using QFE (0' runway altitude) at high-altitude airports. If you use the wrong setting, misinterpret a controller's QFE / QNH call, or use the wrong minimums on a chart, it can be deadly. Those errors are all too easy to make, especially if you are not used to using QFE at all. This really points out why a zero setting should ONLY be used for aerobatic work, and even then, only for LOCAL aerobatic work!! Dudley |
![]() "Dudley Henriques" wrote in message link.net... "John R Weiss" wrote in message news:eHbRb.152481$I06.1538887@attbi_s01... "Dudley Henriques" wrote... Yeah, that's right JW. There's a positive/negative factor in there above that 29.92 that splits that 10K. That should be above AND below 29.92!!! :-) D |
