"Dudley Henriques" wrote:
[snipped for brevity] There's something about this report some of us don't quite get, and it concerns the zero set on the altimeters. The TB fly a zero set altimeter for a show. It's not only basic for low altitude acro work, but it's specified in the regulations for the Thunderbird mission and procedures What puzzles me isn't whether or not he zeroed the altimeter prior to launch or was attempting to convert AGL elevations to MSL altitudes, but rather why he failed to recognize via outside visual cues that he was simply too low to the ground to even THINK about initiating a Split-S maneuver. Clearly, he knew that something was wrong early on since he reportedly exerted "maximum back stick pressure and rolled slightly left to ensure the aircraft would impact away from the crowd should he have to eject." Despite his exceedingly close proximity to the ground the fact that he managed to eject successfully is another indication that he realized quite early on that he done screwed up! If you look at the cockpit video it's obvious that his head is tilted way back watching the horizon while he was inverted prior to initating the Split-S. My primary question is why he didn't abort the Split-S and simply continue the roll at the top of the maneuver and perform an Immelmann instead of pressing on with the Split-S? |
![]() "Mike Marron" wrote in message ... "Dudley Henriques" wrote: [snipped for brevity] There's something about this report some of us don't quite get, and it concerns the zero set on the altimeters. The TB fly a zero set altimeter for a show. It's not only basic for low altitude acro work, but it's specified in the regulations for the Thunderbird mission and procedures What puzzles me isn't whether or not he zeroed the altimeter prior to launch or was attempting to convert AGL elevations to MSL altitudes, but rather why he failed to recognize via outside visual cues that he was simply too low to the ground to even THINK about initiating a Split-S maneuver. Clearly, he knew that something was wrong early on since he reportedly exerted "maximum back stick pressure and rolled slightly left to ensure the aircraft would impact away from the crowd should he have to eject." Despite his exceedingly close proximity to the ground the fact that he managed to eject successfully is another indication that he realized quite early on that he done screwed up! If you look at the cockpit video it's obvious that his head is tilted way back watching the horizon while he was inverted prior to initating the Split-S. My primary question is why he didn't abort the Split-S and simply continue the roll at the top of the maneuver and perform an Immelmann instead of pressing on with the Split-S? This is our observation exactly! Pilots who survive low altitude demo work are NOT one cue pilots, but respond to multiple cues, many peripheral. All of us discussing this back channel are in complete agreement with your observation about visual cues. The g line required to put the Viper in reverse at 1600 was higher than that which would have been normal. This should have been a physical cue. The horizon is different at 1600 than at 2500. This is a visual cue. The inverted ground area showing past the canopy bow edge is wider (more detailed ground area meets the eye) at 1600 than at 2500. This is a peripheral visual cue. The inverted pull is escapable in roll until just before exact vertical. The shortest way out using roll must allow for snatch factor and roll rate and this occurs in an airplane with the Viper's roll capability in this maneuver profile at just before 90 degrees nose down. From then on it's a straight pull commit. The Viper can be flown into a pitch rate defeat on the limiter and that's where he put it apparently. I make it a dead airplane from 90 degrees nose down in the pull and a dead pilot except for the seat capability. The altimeter reference however, remains a puzzle for us. Dudley |
"Mike Marron" wrote
My primary question is why he didn't abort the Split-S and simply continue the roll at the top of the maneuver and perform an Immelmann instead of pressing on with the Split-S? He would have had to buy the first round at the club for missing the maneuver, and everyone would have bought him a round if he somehow pulled it out of his ***. Ah well, no one went to the club that day... |
Video?? There's video and I missed it??? Drat! Anybody have a link to it?
Please? ![]() Steve R. "Mike Marron" wrote in message ... If you look at the cockpit video it's obvious that his head is tilted way back watching the horizon while he was inverted prior to initating the Split-S. My primary question is why he didn't abort the Split-S and simply continue the roll at the top of the maneuver and perform an Immelmann instead of pressing on with the Split-S? |
"Steve R." wrote:
"Mike Marron" wrote: If you look at the cockpit video it's obvious that his head is tilted way back watching the horizon while he was inverted prior to initating the Split-S. My primary question is why he didn't abort the Split-S and simply continue the roll at the top of the maneuver and perform an Immelmann instead of pressing on with the Split-S? Video?? There's video and I missed it??? Drat! Anybody have a link to it? Please? ![]() Steve R. Subject: Thunderbird pilot found at fault in Mountain Home AFB crash Newsgroups: rec.aviation.military Date: 2004-01-25 22:59:09 PST http://www.avweb.com/eletter/archive...ll.html#186582 |
Ummm.... nevermind. I saw the link later while i was reading a different
thread. Thanks though! ![]() Steve R. "Mike Marron" wrote in message ... "Dudley Henriques" wrote: [snipped for brevity] There's something about this report some of us don't quite get, and it concerns the zero set on the altimeters. The TB fly a zero set altimeter for a show. It's not only basic for low altitude acro work, but it's specified in the regulations for the Thunderbird mission and procedures What puzzles me isn't whether or not he zeroed the altimeter prior to launch or was attempting to convert AGL elevations to MSL altitudes, but rather why he failed to recognize via outside visual cues that he was simply too low to the ground to even THINK about initiating a Split-S maneuver. Clearly, he knew that something was wrong early on since he reportedly exerted "maximum back stick pressure and rolled slightly left to ensure the aircraft would impact away from the crowd should he have to eject." Despite his exceedingly close proximity to the ground the fact that he managed to eject successfully is another indication that he realized quite early on that he done screwed up! If you look at the cockpit video it's obvious that his head is tilted way back watching the horizon while he was inverted prior to initating the Split-S. My primary question is why he didn't abort the Split-S and simply continue the roll at the top of the maneuver and perform an Immelmann instead of pressing on with the Split-S? |
