On Jul 28, 7:37*am, Bob Kuykendall wrote:
I think that carbon sleeve over EPS or EPP rod would indeed do the trick for the arm. If you were serious about it, you'd have a high- pressure female mold, and mold the part by inflating a plastic bladder inside the sleeve material, but the male molded part would be almost as stiff and easier and cheaper to make for just one or two. All far too complicated! When I built my wing wheel I prototyped the legs with 3/4 inch schedule 40 pvc pipe. The idea was to get the geometry right then make to final legs from aluminium square tube. It turned out the sched 40 pvc was perfect for the job. It is dimensionally stable, has just the right amount of spring, and does no damage anything it bangs or rubs against. The protype legs have lasted 8 years. They will be changed this winter for a design that allows height adjustment but I'll use the same material. Andy (GY) |
On Jul 28, 10:35*am, Andy wrote:
On Jul 28, 7:37*am, Bob Kuykendall wrote: I think that carbon sleeve over EPS or EPP rod would indeed do the trick for the arm. If you were serious about it, you'd have a high- pressure female mold, and mold the part by inflating a plastic bladder inside the sleeve material, but the male molded part would be almost as stiff and easier and cheaper to make for just one or two. All far too complicated! When I built my wing wheel I prototyped the legs with 3/4 inch schedule 40 pvc pipe. *The idea was to get the geometry right then make to final legs from aluminium square tube. It turned out the sched 40 pvc was perfect for the job. *It is dimensionally stable, has just the right amount of spring, and does no damage anything it bangs or rubs against. *The protype legs have lasted 8 years. *They will be changed this winter for a design that allows height adjustment but I'll use the same material. Andy (GY) How about pictures Andy, Any place you could post them for others to view? |
Windward performance makes a wing wheel for the Sparrowhawk that uses
two skate wheels. It's really neat and has a natural spring arc made out of carbon fiber and fiberglass with two skate wheels on the bottom. It pivots 360 deg for which every way you drag the sailplane. Yes the wing is only 42 lbs so it might not scale up to full weighted sailplanes. Sorry I have no photos but I thought it might be an interesting idea out there for those entrepreneurs. It does not fold but stores well as it is small. Just an idea that you don't have to use a bike tire like every one else. JOhn |
On Jul 28, 7:12*pm, flyingmr2 wrote:
Windward performance makes a wing wheel *for the Sparrowhawk that uses two skate wheels. *It's really neat and has a natural spring arc made out of carbon fiber and fiberglass with two skate wheels on the bottom. *It pivots 360 deg for which every way you drag the sailplane. *Yes the wing is only 42 lbs so it might not scale up to full weighted sailplanes. * Sorry I have no photos but I thought it might be an interesting idea out there for those entrepreneurs. It does not fold but stores well as it is small. *Just an idea that you don't have to use a bike tire like every one else. JOhn I love the Windward wing wheel setup. I saw it at Mountain Valley (Tehachapi) and it handled the gopher holes just fine! |
Windward performance makes a wing wheel *for the Sparrowhawk that uses two skate wheels. *It's really neat and has a natural spring arc made out of carbon fiber and fiberglass with two skate wheels on the bottom. *It pivots 360 deg for which every way you drag the sailplane. *Yes the wing is only 42 lbs so it might not scale up to full weighted sailplanes. * Sorry I have no photos but I thought it might be an interesting idea out there for those entrepreneurs. It does not fold but stores well as it is small. *Just an idea that you don't have to use a bike tire like every one else. JOhn But like Tom says, there's a problem when it's too light. I "kludge" repaired a Sparrowhawk wing wheel. Owner added weight to top of wing to keep it down. This caused composite to slowly grind away near radius and further weaken. At least for moving the glider on pavement in stronger conditions, the composite spring isn't strong enough to allow adding the needed weight, bumper MKIV & QV Minden |
On Jul 28, 12:32*pm, SoaringXCellence wrote:
How about pictures Andy, *Any place you could post them for others to view? I dug out a couple of photos and will send them to you if you email me. My RAS address is valid. I don't have a photo sharing account. Andy |
On Jul 29, 9:58*am, Andy wrote:
On Jul 28, 12:32*pm, SoaringXCellence wrote: How about pictures Andy, *Any place you could post them for others to view? I dug out a couple of photos and will send them to you if you email me. *My RAS address is valid. I don't have a photo sharing account. Andy I'd love to see some pictures, too. Unfortunately, I don't have anywhere to post them either. Last year at Cordele the guy parked next to me had a homemade wing wheel. He'd used a couple of pieces of copper tubing bent into a U-shape and flattened at the ends so he could run the bicycle wheel axle through them. He attached the bottom part of the U's to an old skateboard. The whole contraption got put on the wing with some bungy cords. It worked fine for him, although it didn't hold the plane level. That would have been a problem if he wasn't flying club class (no ballast). -- Matt |
On Jul 29, 9:01*am, mattm wrote:
I'd love to see some pictures, too. * I posted them to SSA where they can be seen by non members as well as members. Go to SSA home page http://www.ssa.org/ then select "About Soaring" / "Photo Gallery" They currently show at the top of the page. Members can find me and then go to my gallery One photo is a duplicate. I have not yet found out how to delete a photo I posted or how to edit the text after posting. Andy |
Andy...it's been a few years now.... did you redesign the wing wheel to allow height adjustment? If so, please post pics on SSA as before..
Mike V N171XX |
Duo Discus Wing Wheel -- not Dolly | [email protected] | Soaring | 0 | November 1st 07 03:57 AM |
Carbon fiber shortage? | [email protected] | Home Built | 3 | December 11th 05 07:24 AM |
Composite & Carbon Fiber | NW_PILOT | Home Built | 11 | September 21st 04 06:21 PM |
carbon fiber | dutchpilot | Home Built | 0 | June 16th 04 12:20 PM |
Carbon fiber vs. antennas | [email protected] | Owning | 2 | January 2nd 04 01:40 PM |
