On Jul 21, 8:57*pm, John Doe wrote:
How far-fetched is the idea, to use a propeller or jet engine (radio controlled type?) to push an in-line skater? How does aircraft takeoff thrust compare to using a conventional motor and wheel to push oneself along the ground? What sort of incline would be achievable at say a skater weight of about 160 pounds? I think the rolling resistance can be assumed to be zero or maybe the same as a small aircraft. Anybody know about Everglades/marsh air powered boats? Maybe I should do a little research on that one. One thing for sure, if there ever is such a thing as a jetpack, it will very easily push an in-line skater before it will lift a person off of the ground. Thanks. -- (Crossposted, please feel free to remove the other group) One thing is for sure it can't be too high or low relative to center of gravity. |
"David E. Powell" David_Powell3006 msn.com wrote:
One thing is for sure it can't be too high or low relative to center of gravity. That may be less critical than you think. Propeller propulsion would be the freest form since it would not depend on the ground, the full benefit of skating depends on freedom of movement. Push stick based propulsion (a bulky prototype is currently being used here) is stable, even when being pushed from knee level. I get a third wheel effect, and stroking with my legs is not required. Pushing/stroking is a HUGE source of instability while inline street skating. |
Just push the blue button! | Darkwing | Piloting | 71 | October 20th 08 04:12 PM |
PUSH START | stanley adelson | Aviation Photos | 0 | July 15th 08 01:16 AM |
Push to Talk Switch | Jackal24 | Piloting | 23 | December 26th 04 10:01 PM |
Question about center-line push-pull engine configuration | Shin Gou | Home Built | 4 | June 7th 04 05:57 PM |
Young Eagles push (USA) | John H. Campbell | Soaring | 0 | September 22nd 03 03:48 PM |
