On Jul 30, 1:03*pm, Herb wrote:
What a completely senseless and preventable accident. *Go back and look at the vicious comments that were made here when BB suggested all line finishes should be abolished in favor of the 500' and 1 mile cylinder. *Mr. Larson's death should have been enough to quiet the fans of low and fast. *Gliders have no business flying close to the ground, same for other aircraft. * You and JJ seem to be under the impression that the Szeged accident resulted from a low altitude high speed approach. Reports from the site indicate the glider, like some others finishing that day, was low energy. Do you have new information that conflicts with those reports? If not, can you please explain how the finish type was a factor in the accident. Andy (GY) |
![]() You and JJ seem to be under the impression that the Szeged accident resulted from a low altitude high speed approach. *Reports from the site indicate the glider, like some others finishing that day, was low energy. Do you have new information that conflicts with those reports? If not, can you please explain how the finish type was a factor in the accident. Andy (GY) Low energy becomes evident at the end of your finish. The guy who can't make the 500'/1mile cylinder calls for a straight-in landing. The guy that finds himself with low energy while trying to make a 50' finish line eats the fence/ hits a truck! JJ |
On Jul 30, 2:47*pm, JJ Sinclair wrote:
Low energy becomes evident at the end of your finish. The guy who can't make the 500'/1mile cylinder calls for a straight-in landing. The guy that finds himself with low energy while trying to make a 50' finish line eats the fence/ hits a truck! JJ A low energy final glide should be evident long before reaching either the finish cylinder or one mile from a finish line. If there is no lift and a marginal glide to the airport the choice is to either land out or try to get over the fence. The pilot who passed through the finish cylinder at best L/D and 200 ft is in exactly the same situation as the guy at best L/D and 200ft and a mile out going for a line finish or a rolling finish. The finish type makes no difference when there is insufficient energy to make the airport but the pilot continues to try for the airport. The argument that the finish cylinder would increase safety in this scenario may be valid if the pilot has the option to stop and work lift to get up to minimum finish altitude. It may also be true that there is an increase in safety if pilot choses to landout after making the cylinder finish. That requires landable areas between the cylinder circumference and the airport. As a result of the accident WGC has changed from a line finish to a cylinder finish. The Friday task sheet defines the finish as cylinder R=3.0 km with a 140M QNH min finish altitude. According to the turnpoints database Szeged is at 80M. Unless my calculations are wrong the required L/D from a valid finish to the airport is 50:1. The same choce remains - try to clear the fence or landout. The points penalty for landing out is gone though, and maybe that's enough to make it safer. Let's hope so. Andy |
On Fri, 30 Jul 2010 15:50:47 -0700 (PDT), Andy
wrote: A low energy final glide should be evident long before reaching either the finish cylinder or one mile from a finish line. If there is no lift and a marginal glide to the airport the choice is to either land out or try to get over the fence. Sounds simple in theory, but seems to be harder in reality. A typical accident report can be found he http://www.bfu-web.de/cln_005/nn_223...tar3_Sdier.pdf Even for the non-German speaking readers of this newsgroup the flightpath plot should make fascinating reading - the pilot tried to follow his team mates who happened to be 100 ft higher. Fortunately in this case the pilot was only slightly injured. Cheers Andreas |
On Jul 30, 6:50*pm, Andy wrote:
On Jul 30, 2:47*pm, JJ Sinclair wrote: Low energy becomes evident at the end of your finish. The guy who can't make the 500'/1mile cylinder calls for a straight-in landing. The guy that finds himself with low energy while trying to make a 50' finish line eats the fence/ hits a truck! JJ A low energy final glide should be evident long before reaching either the finish cylinder or one mile from a finish line. *If there is no lift and a marginal glide to the airport the choice is to either land out or try to get over the fence. *The pilot who passed through the finish cylinder at best L/D and 200 ft is in exactly the same situation as the guy at best L/D and 200ft *and a mile out going for a line finish or a rolling finish. *The finish type makes no difference when there is insufficient energy to make the airport but the pilot continues to try for the airport. The argument that the finish cylinder would increase safety in this scenario may be valid if the pilot has the option to stop and work lift to get up to minimum finish altitude. *It may also be true that there is an increase in safety if pilot choses to landout after making the cylinder finish. *That requires landable areas between the cylinder circumference and the airport. As a result of the accident WGC has changed from a line finish to a cylinder finish. The Friday task sheet defines the finish as cylinder R=3.0 km with a 140M QNH min finish altitude. *According to the turnpoints database Szeged is at 80M. *Unless my calculations are wrong the required L/D from a valid finish to the airport is 50:1. The same choce remains - try to clear the fence or landout. *The points penalty for landing out is gone though, and maybe that's enough to make it safer. Let's hope so. Andy It's actually pretty straightforward. The accident happened 20km or 30km out. The impact with the truck was just the final act. Here's the deal. If you have 500 feet dialed in for your final glide because that's the competition finish floor with a point penalty for coming in low,, what are you gonna do when you take that last climb 30km out? If you're a smart racer, you're gonna put 500 feet plus maybe another 200 feet of cushion in your arrival height and climb accordingly. Then, you'll monitor your glide against that 500 foot floor, not against a 0 foot arrival. If you're losing against that 500 foot floor, you might even stop to pick up an extra 100ft if you hit a bump. Worst case, you blow the glide by 100ft and get a 40pt penalty. You've still got 300 feet over the road and can easily make the airport. Worst case if you're aiming for 0 ft arrival, you take out an innocent bystander and/or yourself. Hey, it can still go all pear-shaped, and you end up with a very marginal glide. But, by moving the floor to 500, you're simply re- defining the combat arena and giving pilots an incentive to take risks for points, not their lives. Erik Mann LS8-18 (P3) |
Andy,
Your 50:1 math is right and wrong at the same time. What is missing is the fact the the centre of the 3 km finish cylinder is located at the opposite end of the 4000 ft landing runway. This means that when you cross the finish line at about 200 ft agl you are about 1.8 km from the touchdown point (and 3 km from the other end of the runway). This gives L/D of 30:1 to touchdown which is sufficient for the ships flying in the 15/18/ Open Classes. |
On Aug 2, 7:43*pm, Dave Springford wrote:
Andy, Your 50:1 math is right and wrong at the same time. *What is missing is the fact the the centre of the 3 km finish cylinder is located at the opposite end of the 4000 ft landing runway. *This means that when you cross the finish line at about 200 ft agl you are about 1.8 km from the touchdown point (and 3 km from the other end of the runway). This gives L/D of 30:1 to touchdown which is sufficient for the ships flying in the 15/18/ Open Classes. .... and also add that the glider will probably be flying faster when reaching the finish ring, so will have a bit more energy to spare or if it doesn't, it can land short if necessary |
On Aug 2, 11:43*am, Dave Springford wrote:
Andy, Your 50:1 math is right and wrong at the same time. *What is missing is the fact the the centre of the 3 km finish cylinder is located at the opposite end of the 4000 ft landing runway. *This means that when you cross the finish line at about 200 ft agl you are about 1.8 km from the touchdown point (and 3 km from the other end of the runway). This gives L/D of 30:1 to touchdown which is sufficient for the ships flying in the 15/18/ Open Classes. Thanks for the correction Dave. I went back and looked at the last 3 days task sheets and now see that when 16 is the landing runway then Szeged34 is the finish centre, and when 36 is active Szeged16 defines the centre. I had missed that. Andy (GY) |
On Jul 30, 5:17*pm, Andy wrote:
On Jul 30, 1:03*pm, Herb wrote: What a completely senseless and preventable accident. *Go back and look at the vicious comments that were made here when BB suggested all line finishes should be abolished in favor of the 500' and 1 mile cylinder. *Mr. Larson's death should have been enough to quiet the fans of low and fast. *Gliders have no business flying close to the ground, same for other aircraft. * You and JJ seem to be under the impression that the Szeged accident resulted from a low altitude high speed approach. *Reports from the site indicate the glider, like some others finishing that day, was low energy. Do you have new information that conflicts with those reports? If not, can you please explain how the finish type was a factor in the accident. Andy (GY) The difference is that the direct finish, flown perfectly means you cross the finish line(airport boundary?) at exactly your average speed for the task and at as little altitude as you dare. It doesn't take much to have that go wrong. The issue of safety of people other than the pilots is mostly a factor of whether potential victims are in the flight path as opposed to finishes across a lake(like Finland or big fields as we had in Germany). I suspect we will see a trend, even in Europe, away from direct finishes. Also a factor is this is the "big race" and people will take risks they would not take any other time. I speak from experience on this. FWIW UH |
You're all a bunch of girlie men, being led by hysterics. Have all of
you aligned your cycles. We have been down this road before and it seems some continue to want to bubble wrap the world from any possiblility of pain or failure. This attempt at fine tuning the rules to cover all the possiblilties is futile. Mankind can make only so many feet of guard rails and airbags. Old men are ruining this sport. R |
Few impressions from WWGC 2009 Szeged (HUN) | db | Soaring | 1 | August 4th 09 03:01 PM |
DA 42 accident | Karl-Heinz Kuenzel | Piloting | 86 | April 29th 07 09:05 AM |
F6F accident | Larry Cauble | Naval Aviation | 4 | October 14th 05 06:19 PM |
Accident db? | [email protected] | Owning | 3 | July 25th 05 06:22 PM |
KC-135 accident | Big John | Piloting | 3 | November 19th 03 04:36 PM |
