![]() "Eunometic" wrote in message om... With a modified Fueselage it of course became a great maritime patrol aircraft known as the Nimrod. Nimrod is apparently superior than the Orion: at least as far as the airframe is concerned. Please xplain your reasons for arriving at this conclusion. While the Nimrod is a fine aircraft the P-3 has had rather more export success. The burried engines ( speys and now BMW/Rolls Royce BR715 ) provide a significantly reduced radar signature. (Here lies the disadvantage of burried eingines: installing high bypass ratio engines required re-engineering of the wing roots) I seriously doubt that any real advantage accrues from this. Nimrod has a LARGE radar signature. The engines which are close to the fueselage mean that opperation with engines shutdown does not create significant asymetric thrust problems. Indeed opperation on 2 engines is I believe normal on long loitering patrols. The latest Nimrods I believe have a range in excess of 6500nm and can launch cruise missiles. They can be armed with sidewinders and presumably AMRAAM style self homing missiles is a possibility. AMRAAM is highly unlikley With the correct systems and sighting they might even provide the RAF with a mini B52. The big wings must provide good altitude performance. Thats just silly. Nimrod simly doesnt have the payload carrying capacity. The RAF used to have a mini B-52 , it was called the Vulcan Keith |
![]() "Keith Willshaw" wrote in message ... "Eunometic" wrote in message om... With a modified Fueselage it of course became a great maritime patrol aircraft known as the Nimrod. Nimrod is apparently superior than the Orion: at least as far as the airframe is concerned. Please xplain your reasons for arriving at this conclusion. While the Nimrod is a fine aircraft the P-3 has had rather more export success. Our master of logic enters the fray. The VC10 and Super VC10 was a superior plane to the 707, yet the 707 outsold it. The burried engines ( speys and now BMW/Rolls Royce BR715 ) provide a significantly reduced radar signature. (Here lies the disadvantage of burried eingines: installing high bypass ratio engines required re-engineering of the wing roots) I seriously doubt that any real advantage accrues from this. Nimrod has a LARGE radar signature. The engines which are close to the fueselage mean that opperation with engines shutdown does not create significant asymetric thrust problems. Indeed opperation on 2 engines is I believe normal on long loitering patrols. The latest Nimrods I believe have a range in excess of 6500nm and can launch cruise missiles. They can be armed with sidewinders and presumably AMRAAM style self homing missiles is a possibility. AMRAAM is highly unlikley He is gussing now. With the correct systems and sighting they might even provide the RAF with a mini B52. The big wings must provide good altitude performance. Thats just silly. Nimrod simly doesnt have the payload carrying capacity. The RAF used to have a mini B-52 , it was called the Vulcan You must read what was written. |
![]() "Spiv" wrote in message ... "Keith Willshaw" wrote in message ... "Eunometic" wrote in message om... With a modified Fueselage it of course became a great maritime patrol aircraft known as the Nimrod. Nimrod is apparently superior than the Orion: at least as far as the airframe is concerned. Please xplain your reasons for arriving at this conclusion. While the Nimrod is a fine aircraft the P-3 has had rather more export success. Our master of logic enters the fray. The VC10 and Super VC10 was a superior plane to the 707, yet the 707 outsold it. It was far from superior which is why harly anybody except BA bought the thing and they only did so because the government made them. There was a famous leaked memo from BOAC requesting a subsidy because they were having to compete with 707's that were cheaper to run Not only were the initial operating costs of the VC-10 higher but the buried engine design meant that it couldnt use the new more efficient (and quieter) powerplants that the 707 and DC-8 were requipped with which meant the aircraft became increasingly uncompetitve and it could not meet the new noise restrictions introduced in the 70's and 80's. The burried engines ( speys and now BMW/Rolls Royce BR715 ) provide a significantly reduced radar signature. (Here lies the disadvantage of burried eingines: installing high bypass ratio engines required re-engineering of the wing roots) I seriously doubt that any real advantage accrues from this. Nimrod has a LARGE radar signature. The engines which are close to the fueselage mean that opperation with engines shutdown does not create significant asymetric thrust problems. Indeed opperation on 2 engines is I believe normal on long loitering patrols. The latest Nimrods I believe have a range in excess of 6500nm and can launch cruise missiles. They can be armed with sidewinders and presumably AMRAAM style self homing missiles is a possibility. AMRAAM is highly unlikley He is gussing now. No and I'm not guessing either, AMRAAM requires rather more in the way of system integration than AIM-9 including a suitable aircraft radar fit to get a lock at BVR With the correct systems and sighting they might even provide the RAF with a mini B52. The big wings must provide good altitude performance. Thats just silly. Nimrod simly doesnt have the payload carrying capacity. The RAF used to have a mini B-52 , it was called the Vulcan You must read what was written. I didnt, it was full of errors Keith |
(Eunometic) writes: (Peter Stickney) wrote in message . com... Peter Skelton wrote in message . .. On Mon, 26 Jan 2004 00:49:41 -0500, (Peter Stickney) wrote: To add some Military Content. The groundings and losses did not necessarily mean the immediate scrapping of the Comet I. DH _did_ infact, come up with a rebuild program that would allow the airplane to have some useful life. The only Comet Customer who took them up on this was the Royal Canadian Air Force, which had purchased two Comets to support the First Air Division in Europe. These remained in service until the early 1960s. ISTR Comets in service with Freddie Laker into the 70's. Dan Air used them until Nov. 3, '80 (something over 110 passengers which must have been fun.) Those were Comet IVs, not Comet Is. Basically an entirely new airframe with a Comet-like shape. They were entirely redesigned structurally, and a bit larger. (71,760 kg MTOW rather than 47,620 kg) They used Rolls Avons (With about twice the push) rather than the centrifugal DH Ghosts. The Comet IV was actually a pretty good airplane. Unfortunately, it took about 4 years to get the Comet IV redesigned and off the ground. By that time, instead of competing with DC-6s and Lockheed 749 Constellations, it was competing with the Boeing 707 and the Douglas DC-8. At that point, it was too slow, and too short-ranged. (Pan Am 707 used to take off about a half-hour after BOAC Comet IVs, and they made a point of announcing when they passed the Comets somewhere between Iceland and Greenland. With a modified Fueselage it of course became a great maritime patrol aircraft known as the Nimrod. Nimrod is apparently superior than the Orion: at least as far as the airframe is concerned. Nimrods are a bit faster than P-3s. That's not really relevant though, when looking for submarines. They're both big enough, fast enough when need be, and slow enough when need be. The Orion beats in wrt fuel consumption, The efficiency of the sensor suites is about equivalent, with a little seesawing back & forth depending on what point in time you're comparing the two. It's kind of ironic that the Orion also grew out of a semi-successful 1950s airliner with a troubled beginning - the Lockheed L-188 Electra, the fastes of the Western prop-driven airliners (The Tu-114 can beat it) L-188s also suffered a spate of mysterious crashes. In their case, it was a resonant vibration in damaged engine mounts that induced fuilure in the wing spar. Like the COnet, it got fixed (A bit more quickly - they didn't have to redesign the entire airplane), but it took time to rebuild public confidence, and the introduction of pure jets on U.S. Domestic routes killed off demand. The burried engines ( speys and now BMW/Rolls Royce BR715 ) provide a significantly reduced radar signature. (Here lies the disadvantage of burried eingines: installing high bypass ratio engines required re-engineering of the wing roots) Not really. The fan sections are entirely exposed within the ducts, and they're spinning pretty fast - that makes the return scintillate, which makes it easier to pick out of clutter, if you know how to look at it. With that big honkin' wing, and the large, slab sided fuselage, even if it was a bit less obvious, it's a distincion without a difference. The engines which are close to the fueselage mean that opperation with engines shutdown does not create significant asymetric thrust problems. Indeed opperation on 2 engines is I believe normal on long loitering patrols. Asymmetric operation with an Orion isn't much of a big deal, either, although it can be a handful in some circumstances. Remember that it had to be able to climb out on 3 engines on takeoff, with a load of passengers aboard. Early on, it was policy on teh P-3 to patrol on 2 engines. The occasional difficulty in getting them both started again, and the need to have as many alternators running a possible to supply th electrical buses has changed that so that they only cage 1 engines. (The last I heard - one of my former bosses was a Navy Reserve P-3 Pilot) The latest Nimrods I believe have a range in excess of 6500nm and can launch cruise missiles. They can be armed with sidewinders and presumably AMRAAM style self homing missiles is a possibility. P-3s are good for about 4500 NM, including 3 hours stooging around at 20,000', and 1 houf chasing contacts at 200', with a 10% reserve. As for what it carries, we've got all teh Cruise Missile carriers the START Treaties will allow. (That's what happens when you're a Major Nuclear Power ![]() will carry a whole raft of Harpoons & SLAM-ERs, which are Cruise Missiles of a somewhat more subdued nature. I don't recall if anybody's stuck a Sidewinder on a P-3, but there's no reason why you can't. A SIrewinder requires a standard rack to fit the rail to, soem wires to wake it up, and some wires to insert the seeker's growl into the intercom system. AMRAAMs are right out, for either. While an AMRAAM has an active seeker, it still needs a fighter-type Fire COntrol System to properly program it before launch. With the correct systems and sighting they might even provide the RAF with a mini B52. The big wings must provide good altitude performance. As for the Nimrod being a mini-B-52, well, we've got B-52s to fill that role. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
![]() "Peter Stickney" wrote in message ... In article , (Eunometic) writes: (Peter Stickney) wrote in message . com... Peter Skelton wrote in message . .. On Mon, 26 Jan 2004 00:49:41 -0500, (Peter Stickney) wrote: To add some Military Content. The groundings and losses did not necessarily mean the immediate scrapping of the Comet I. DH _did_ infact, come up with a rebuild program that would allow the airplane to have some useful life. The only Comet Customer who took them up on this was the Royal Canadian Air Force, which had purchased two Comets to support the First Air Division in Europe. These remained in service until the early 1960s. ISTR Comets in service with Freddie Laker into the 70's. Dan Air used them until Nov. 3, '80 (something over 110 passengers which must have been fun.) Those were Comet IVs, not Comet Is. Basically an entirely new airframe with a Comet-like shape. They were entirely redesigned structurally, and a bit larger. (71,760 kg MTOW rather than 47,620 kg) They used Rolls Avons (With about twice the push) rather than the centrifugal DH Ghosts. The Comet IV was actually a pretty good airplane. Unfortunately, it took about 4 years to get the Comet IV redesigned and off the ground. By that time, instead of competing with DC-6s and Lockheed 749 Constellations, it was competing with the Boeing 707 and the Douglas DC-8. At that point, it was too slow, and too short-ranged. (Pan Am 707 used to take off about a half-hour after BOAC Comet IVs, and they made a point of announcing when they passed the Comets somewhere between Iceland and Greenland. With a modified Fueselage it of course became a great maritime patrol aircraft known as the Nimrod. Nimrod is apparently superior than the Orion: at least as far as the airframe is concerned. Nimrods are a bit faster than P-3s. That's not really relevant though, when looking for submarines. They're both big enough, fast enough when need be, and slow enough when need be. Being slow enough is very important for those types of planes. The Orion beats in wrt fuel consumption, The efficiency of the sensor suites is about equivalent, with a little seesawing back & forth depending on what point in time you're comparing the two. It's kind of ironic that the Orion also grew out of a semi-successful 1950s airliner with a troubled beginning - the Lockheed L-188 Electra, the fastes of the Western prop-driven airliners (The Tu-114 can beat it) L-188s also suffered a spate of mysterious crashes. In their case, it was a resonant vibration in damaged engine mounts that induced fuilure in the wing spar. Like the COnet, it got fixed (A bit more quickly - they didn't have to redesign the entire airplane), The Electra was hardly a plane making history and catapulting technology as was the Comet. The lessons from the Comet, the most extensive research into one plane and metal fatigue ever, were used on virtually every plane after in some way or other. but it took time to rebuild public confidence, and the introduction of pure jets on U.S. Domestic routes killed off demand. The burried engines ( speys and now BMW/Rolls Royce BR715 ) provide a significantly reduced radar signature. (Here lies the disadvantage of burried eingines: installing high bypass ratio engines required re-engineering of the wing roots) Not really. The fan sections are entirely exposed within the ducts, and they're spinning pretty fast - that makes the return scintillate, which makes it easier to pick out of clutter, if you know how to look at it. With that big honkin' wing, and the large, slab sided fuselage, even if it was a bit less obvious, it's a distincion without a difference. The engines which are close to the fueselage mean that opperation with engines shutdown does not create significant asymetric thrust problems. Indeed opperation on 2 engines is I believe normal on long loitering patrols. Asymmetric operation with an Orion isn't much of a big deal, either, although it can be a handful in some circumstances. Remember that it had to be able to climb out on 3 engines on takeoff, with a load of passengers aboard. Early on, it was policy on teh P-3 to patrol on 2 engines. The occasional difficulty in getting them both started again, and the need to have as many alternators running a possible to supply th electrical buses has changed that so that they only cage 1 engines. (The last I heard - one of my former bosses was a Navy Reserve P-3 Pilot) The latest Nimrods I believe have a range in excess of 6500nm and can launch cruise missiles. They can be armed with sidewinders and presumably AMRAAM style self homing missiles is a possibility. P-3s are good for about 4500 NM, including 3 hours stooging around at 20,000', and 1 houf chasing contacts at 200', with a 10% reserve. As for what it carries, we've got all teh Cruise Missile carriers the START Treaties will allow. (That's what happens when you're a Major Nuclear Power ![]() will carry a whole raft of Harpoons & SLAM-ERs, which are Cruise Missiles of a somewhat more subdued nature. I don't recall if anybody's stuck a Sidewinder on a P-3, but there's no reason why you can't. A SIrewinder requires a standard rack to fit the rail to, soem wires to wake it up, and some wires to insert the seeker's growl into the intercom system. AMRAAMs are right out, for either. While an AMRAAM has an active seeker, it still needs a fighter-type Fire COntrol System to properly program it before launch. With the correct systems and sighting they might even provide the RAF with a mini B52. The big wings must provide good altitude performance. As for the Nimrod being a mini-B-52, well, we've got B-52s to fill that role. His point is that it can be used for other functions too, which is cost effective. B52/Vulcan types of planes cost a "fortune" to make and maintain - 40 million people in the USA are excluded from medical care, make the armed forces more efficient and your people, benefit. The Nimrod was fitted with sidewinders during the Falklands war. |
![]() "Spiv" wrote in message ... The lessons from the Comet, the most extensive research into one plane and metal fatigue ever, were used on virtually every plane after in some way or other. How so? His point is that it can be used for other functions too, which is cost effective. B52/Vulcan types of planes cost a "fortune" to make and maintain - 40 million people in the USA are excluded from medical care, make the armed forces more efficient and your people, benefit. Nobody in the USA is excluded from medical care. |
Lost comms after radar vector | Mike Ciholas | Instrument Flight Rules | 119 | January 31st 04 11:39 PM |
All Vietnam Veterans Were Awarded The Vietnam Cross of Gallantry | Otis Willie | Military Aviation | 0 | December 1st 03 12:07 AM |
Vietnam, any US planes lost in China ? | Mike | Military Aviation | 7 | November 4th 03 11:44 PM |
Soviet Submarines Losses - WWII | Mike Yared | Military Aviation | 4 | October 30th 03 03:09 AM |
Attorney honored for heroism during the Vietnam War | Otis Willie | Military Aviation | 6 | August 14th 03 11:59 PM |
