Stability augmentation promises to give you even less control
Old August 2nd 10, 10:19 AM posted to rec.aviation.piloting
Mxsmanic
Default Stability augmentation promises to give you even less control
Dave Doe writes:
I stall, a spin, a spiral dive (excessive pitch down and speed) - many
things - as long as they are also with NO PILOT INPUT - then is it not a
good idea for such a system to "do something".?
I suppose that's a good start, but when you write computer software, you have
to be way more specific ... and if you don't want to kill anyone, you also
have to be absolutely right.
A perfectly programmed computer might be able to do it, although I should
think it would also need mind-reading ability in order to determine the
pilot's intentions. But in any case, people write the software, so it's never
perfect--and that's the problem.
Promises to be a good show this year! PLMerite Aviation Photos 0 May 3rd 08 12:43 PM
Stability variation WingFlaps Piloting 2 April 28th 08 03:45 AM
Towing stability studies Dan G Soaring 27 February 21st 08 08:38 PM
Tow vehicle -- electronic stability control Greg Arnold Soaring 4 June 8th 06 12:31 PM
Atmospheric stability and lapse rate Andrew Sarangan Piloting 39 February 11th 05 05:34 AM
