On Aug 8, 9:29*pm, mike wrote:
On Aug 8, 10:07*pm, Darryl Ramm wrote: On Aug 8, 8:57*pm, Mike wrote: Just loaded See You on a new Win 7 laptop, and notice that the 3D feature while viewing a flight on a sectional map supplied by Naviter does not show any elevations visually. The map is perfectly flat. *Is there a setting I am missing or does See You have a problem with Win 7? Thanks Mike Did you look in ToolsOptionsFlight3DView Make sure the show 3D terrain checkbox is checked. Make sure height exaggeration is not set to 0.0 or something close to that. It should normally be between 1 and 3 or so. If that does not fix it your best bet is in the Naviter online forums. Darryl Yes the 3D box is checked and the settings all seem correct. Another thing I noticed is that the sailplane image is quite a bit higher than ground levei when the program starts up. Humor me. Go to ToolsOptionsFlight3DView and click the default button in the lower left corner of the dialog panel. There may be problems with this dialog panel at times where settings get confused. BTW you say the glider looks high, SeeYou can tell you the AGL it thinks the glider is at if you select ViewFlight Parameters. Does that number make sense? Your PC should be connected to the Internet and you should hopefully notice the SeeYou terrain data status showing updates running in the lower right corner of the SeeYou window border. Failing all that you may have a graphics card/driver problem. Best place to deal with that is Naviter's support forums. Darryl |
On Aug 8, 11:00*pm, Darryl Ramm wrote:
On Aug 8, 9:29*pm, mike wrote: On Aug 8, 10:07*pm, Darryl Ramm wrote: On Aug 8, 8:57*pm, Mike wrote: Just loaded See You on a new Win 7 laptop, and notice that the 3D feature while viewing a flight on a sectional map supplied by Naviter does not show any elevations visually. The map is perfectly flat. *Is there a setting I am missing or does See You have a problem with Win 7? Thanks Mike Did you look in ToolsOptionsFlight3DView Make sure the show 3D terrain checkbox is checked. Make sure height exaggeration is not set to 0.0 or something close to that. It should normally be between 1 and 3 or so. If that does not fix it your best bet is in the Naviter online forums.. Darryl Yes the 3D box is checked and the settings all seem correct. Another thing I noticed is that the sailplane image is quite a bit higher than ground levei when the program starts up. Humor me. Go to ToolsOptionsFlight3DView and click the default button in the lower left corner of the dialog panel. There may be problems with this dialog panel at times where settings get confused. BTW you say the glider looks high, SeeYou can tell you the AGL it thinks the glider is at if you select ViewFlight Parameters. Does that number make sense? Your PC should be connected to the Internet and you should hopefully notice the SeeYou terrain data status showing updates running in the lower right corner of the SeeYou window border. Failing all that you may have a graphics card/driver problem. Best place to deal with that is Naviter's support forums. Darryl Checked the forums and there was nothing there that would offer a solution. |
On Aug 8, 11:45*pm, mike wrote:
On Aug 8, 11:00*pm, Darryl Ramm wrote: On Aug 8, 9:29*pm, mike wrote: On Aug 8, 10:07*pm, Darryl Ramm wrote: On Aug 8, 8:57*pm, Mike wrote: Just loaded See You on a new Win 7 laptop, and notice that the 3D feature while viewing a flight on a sectional map supplied by Naviter does not show any elevations visually. The map is perfectly flat. *Is there a setting I am missing or does See You have a problem with Win 7? Thanks Mike Did you look in ToolsOptionsFlight3DView Make sure the show 3D terrain checkbox is checked. Make sure height exaggeration is not set to 0.0 or something close to that. It should normally be between 1 and 3 or so. If that does not fix it your best bet is in the Naviter online forums. Darryl Yes the 3D box is checked and the settings all seem correct. Another thing I noticed is that the sailplane image is quite a bit higher than ground levei when the program starts up. Humor me. Go to ToolsOptionsFlight3DView and click the default button in the lower left corner of the dialog panel. There may be problems with this dialog panel at times where settings get confused. BTW you say the glider looks high, SeeYou can tell you the AGL it thinks the glider is at if you select ViewFlight Parameters. Does that number make sense? Your PC should be connected to the Internet and you should hopefully notice the SeeYou terrain data status showing updates running in the lower right corner of the SeeYou window border. Failing all that you may have a graphics card/driver problem. Best place to deal with that is Naviter's support forums. Darryl Checked the forums and there was nothing there that would offer a solution. There might be if you describe your problem there and somebody answers. Darryl |
On Aug 8, 9:29*pm, mike wrote: On Aug 8, 10:07*pm, Darryl Ramm wrote: On Aug 8, 8:57*pm, Mike wrote: Just loaded See You on a new Win 7 laptop, and notice that the 3D feature while viewing a flight on a sectional map supplied by Naviter does not show any elevations visually. The map is perfectly flat. *Is there a setting I am missing or does See You have a problem with Win 7? Thanks Mike Did you look in ToolsOptionsFlight3DView Make sure the show 3D terrain checkbox is checked. Make sure height exaggeration is not set to 0.0 or something close to that. It should normally be between 1 and 3 or so. If that does not fix it your best bet is in the Naviter online forums.. Darryl Yes the 3D box is checked and the settings all seem correct. Another thing I noticed is that the sailplane image is quite a bit higher than ground levei when the program starts up. Humor me. Go to ToolsOptionsFlight3DView and click the default button in the lower left corner of the dialog panel. There may be problems with this dialog panel at times where settings get confused. BTW you say the glider looks high, SeeYou can tell you the AGL it thinks the glider is at if you select ViewFlight Parameters. Does that number make sense? Your PC should be connected to the Internet and you should hopefully notice the SeeYou terrain data status showing updates running in the lower right corner of the SeeYou window border. Failing all that you may have a graphics card/driver problem. Best place to deal with that is Naviter's support forums. Darryl The alt above ground is a few feet less than the fields asl. |
Hi,
I suspect that Darryl hit the nail on the head with his suggestion below that you need to be connected to the internet so SeeYou can automatically download elevation data. It loads the data for the region you are currently looking at. It is somewhat quick if you have a high-speed internet connection. Best Regards, Paul Remde Cumulus Soaring, Inc. "Darryl Ramm" wrote in message ... On Aug 8, 9:29 pm, mike wrote: On Aug 8, 10:07 pm, Darryl Ramm wrote: On Aug 8, 8:57 pm, Mike wrote: Just loaded See You on a new Win 7 laptop, and notice that the 3D feature while viewing a flight on a sectional map supplied by Naviter does not show any elevations visually. The map is perfectly flat. Is there a setting I am missing or does See You have a problem with Win 7? Thanks Mike Did you look in ToolsOptionsFlight3DView Make sure the show 3D terrain checkbox is checked. Make sure height exaggeration is not set to 0.0 or something close to that. It should normally be between 1 and 3 or so. If that does not fix it your best bet is in the Naviter online forums. Darryl Yes the 3D box is checked and the settings all seem correct. Another thing I noticed is that the sailplane image is quite a bit higher than ground levei when the program starts up. Humor me. Go to ToolsOptionsFlight3DView and click the default button in the lower left corner of the dialog panel. There may be problems with this dialog panel at times where settings get confused. BTW you say the glider looks high, SeeYou can tell you the AGL it thinks the glider is at if you select ViewFlight Parameters. Does that number make sense? Your PC should be connected to the Internet and you should hopefully notice the SeeYou terrain data status showing updates running in the lower right corner of the SeeYou window border. Failing all that you may have a graphics card/driver problem. Best place to deal with that is Naviter's support forums. Darryl |
On Aug 9, 5:19*am, "Paul Remde" wrote:
Hi, I suspect that Darryl hit the nail on the head with his suggestion below that you need to be connected to the internet so SeeYou can automatically download elevation data. *It loads the data for the region you are currently looking at. *It is somewhat quick if you have a high-speed internet connection. Best Regards, Paul Remde Cumulus Soaring, Inc. "Darryl Ramm" wrote in message ... On Aug 8, 9:29 pm, mike wrote: On Aug 8, 10:07 pm, Darryl Ramm wrote: On Aug 8, 8:57 pm, Mike wrote: Just loaded See You on a new Win 7 laptop, and notice that the 3D feature while viewing a flight on a sectional map supplied by Naviter does not show any elevations visually. The map is perfectly flat. Is there a setting I am missing or does See You have a problem with Win 7? Thanks Mike Did you look in ToolsOptionsFlight3DView Make sure the show 3D terrain checkbox is checked. Make sure height exaggeration is not set to 0.0 or something close to that. It should normally be between 1 and 3 or so. If that does not fix it your best bet is in the Naviter online forums.. Darryl Yes the 3D box is checked and the settings all seem correct. Another thing I noticed is that the sailplane image is quite a bit higher than ground levei when the program starts up. Humor me. Go to ToolsOptionsFlight3DView and click the default button in the lower left corner of the dialog panel. There may be problems with this dialog panel at times where settings get confused. BTW you say the glider looks high, SeeYou can tell you the AGL it thinks the glider is at if you select ViewFlight Parameters. Does that number make sense? Your PC should be connected to the Internet and you should hopefully notice the SeeYou terrain data status showing updates running in the lower right corner of the SeeYou window border. Failing all that you may have a graphics card/driver problem. Best place to deal with that is Naviter's support forums. Darryl- Hide quoted text - - Show quoted text - The computer is always connnected to the internet, so I do not think that is the problem. I appreciate everyones efforts. Thanks Mike |
On Aug 9, 7:39*am, mike wrote:
On Aug 9, 5:19*am, "Paul Remde" wrote: Hi, I suspect that Darryl hit the nail on the head with his suggestion below that you need to be connected to the internet so SeeYou can automatically download elevation data. *It loads the data for the region you are currently looking at. *It is somewhat quick if you have a high-speed internet connection. Best Regards, Paul Remde Cumulus Soaring, Inc. "Darryl Ramm" wrote in message ... On Aug 8, 9:29 pm, mike wrote: On Aug 8, 10:07 pm, Darryl Ramm wrote: On Aug 8, 8:57 pm, Mike wrote: Just loaded See You on a new Win 7 laptop, and notice that the 3D feature while viewing a flight on a sectional map supplied by Naviter does not show any elevations visually. The map is perfectly flat. Is there a setting I am missing or does See You have a problem with Win 7? Thanks Mike Did you look in ToolsOptionsFlight3DView Make sure the show 3D terrain checkbox is checked. Make sure height exaggeration is not set to 0.0 or something close to that. It should normally be between 1 and 3 or so. If that does not fix it your best bet is in the Naviter online forums. Darryl Yes the 3D box is checked and the settings all seem correct. Another thing I noticed is that the sailplane image is quite a bit higher than ground levei when the program starts up. Humor me. Go to ToolsOptionsFlight3DView and click the default button in the lower left corner of the dialog panel. There may be problems with this dialog panel at times where settings get confused. BTW you say the glider looks high, SeeYou can tell you the AGL it thinks the glider is at if you select ViewFlight Parameters. Does that number make sense? Your PC should be connected to the Internet and you should hopefully notice the SeeYou terrain data status showing updates running in the lower right corner of the SeeYou window border. Failing all that you may have a graphics card/driver problem. Best place to deal with that is Naviter's support forums. Darryl- Hide quoted text - - Show quoted text - The computer is always connnected to the internet, so I do not think that is the problem. I appreciate everyones efforts. Thanks Mike- Hide quoted text - - Show quoted text - Installed the sectional a third time and it works! Thanks again to those that responded. Mike |
USB HUB and Windows XP | wan2fly99 | Simulators | 1 | July 1st 08 06:44 PM |
windows | [email protected] | Owning | 3 | November 26th 05 10:00 PM |
Opaque windows is FS9? | [email protected] | Simulators | 1 | August 17th 05 10:36 AM |
JustURLS - why did it not come with Windows! ? | Mark Hyland | Military Aviation | 0 | March 14th 04 06:33 AM |
Windows XP & soaring | C.Fleming | Soaring | 11 | February 13th 04 04:47 PM |
