On Aug 8, 11:45*pm, mike wrote:
On Aug 8, 11:00*pm, Darryl Ramm wrote: On Aug 8, 9:29*pm, mike wrote: On Aug 8, 10:07*pm, Darryl Ramm wrote: On Aug 8, 8:57*pm, Mike wrote: Just loaded See You on a new Win 7 laptop, and notice that the 3D feature while viewing a flight on a sectional map supplied by Naviter does not show any elevations visually. The map is perfectly flat. *Is there a setting I am missing or does See You have a problem with Win 7? Thanks Mike Did you look in ToolsOptionsFlight3DView Make sure the show 3D terrain checkbox is checked. Make sure height exaggeration is not set to 0.0 or something close to that. It should normally be between 1 and 3 or so. If that does not fix it your best bet is in the Naviter online forums. Darryl Yes the 3D box is checked and the settings all seem correct. Another thing I noticed is that the sailplane image is quite a bit higher than ground levei when the program starts up. Humor me. Go to ToolsOptionsFlight3DView and click the default button in the lower left corner of the dialog panel. There may be problems with this dialog panel at times where settings get confused. BTW you say the glider looks high, SeeYou can tell you the AGL it thinks the glider is at if you select ViewFlight Parameters. Does that number make sense? Your PC should be connected to the Internet and you should hopefully notice the SeeYou terrain data status showing updates running in the lower right corner of the SeeYou window border. Failing all that you may have a graphics card/driver problem. Best place to deal with that is Naviter's support forums. Darryl Checked the forums and there was nothing there that would offer a solution. There might be if you describe your problem there and somebody answers. Darryl |
USB HUB and Windows XP | wan2fly99 | Simulators | 1 | July 1st 08 06:44 PM |
windows | [email protected] | Owning | 3 | November 26th 05 10:00 PM |
Opaque windows is FS9? | [email protected] | Simulators | 1 | August 17th 05 10:36 AM |
JustURLS - why did it not come with Windows! ? | Mark Hyland | Military Aviation | 0 | March 14th 04 06:33 AM |
Windows XP & soaring | C.Fleming | Soaring | 11 | February 13th 04 04:47 PM |
