On Aug 13, 12:00*pm, bildan wrote:
If your glider was certified with an Approved Flight Manual, as all JAR-22 gliders are, FAR's require you to operate in compliance with that manual. Please be more specific. What particular FAR requires me to operate my experimental (racing and exhibition) ASW-28 in compliance with the flight manual? The Experimental Operating Limitations contain specific extracts from the flight manual that I am required to comply with. If content of the flight manual was not extracted and included in the Experimental Operating Limitations I am not aware that is has any regulatory significance. The flight manual extracts included in my limitations relate only to maximum gross weight, allowable CG range, and maximum operating speeds. Sure, I recognize that it would be good practice to read and comply with the flight manual, but that is not the same as being required to do so by federal regulation. Andy |
On Aug 14, 5:28*pm, Andy wrote:
On Aug 13, 12:00*pm, bildan wrote: If your glider was certified with an Approved Flight Manual, as all JAR-22 gliders are, FAR's require you to operate in compliance with that manual. Please be more specific. *What particular FAR requires me to operate my experimental (racing and exhibition) ASW-28 in compliance with the flight manual? The Experimental Operating Limitations contain specific extracts from the flight manual that I am required to comply with. *If content of the flight manual was not extracted and included in the Experimental Operating Limitations I am not aware that is has any regulatory significance. The flight manual extracts included in my limitations relate only to maximum gross weight, allowable CG range, and maximum operating speeds. Sure, I recognize that it would be good practice to read and comply with the flight manual, but that is not the same as being required to do so by federal regulation. Andy Every E&R Experimental operations limitations letter I've seen requires operation in compliance with the AFM. FAR Part 91.9(a) requires operation in compliance with an AFM if one is part of the original airworthiness certification. (i.e JAR-22) I'm very sure (based on FAA interpretations) if an E&R airworthiness certificate is issued for a glider which had a standard airworthiness certificate with AFM in it's country of origin, the mere issuance of a US E&R airworthiness certificate does not excuse the owner of the glider from compliance with the AFM. |
On Aug 14, 6:37 pm, bildan wrote:
Every E&R Experimental operations limitations letter I've seen requires operation in compliance with the AFM. I can find no such requirement in mine. Does anyone else operating experimental (racing/exhibition) have this requirement in their operating limitations? If so, would you please email me a copy. FAR Part 91.9(a) requires operation in compliance with an AFM if one is part of the original airworthiness certification. (i.e JAR-22) My operating limitations do not require compliance with all of part 91. They reference very specific sections. In reference to 91.9 they state in para 21 - This aircraft shall contain the placards., markings, etc. required by 91.9. 91.9 (a) states a) Except as provided in paragraph (d) of this section, no person may operate a civil aircraft without complying with the operating limitations specified in the approved Airplane or Rotorcraft Flight Manual, markings, and placards, or as otherwise prescribed by the certificating authority of the country of registry. It is my interpretation that "or as otherwise prescribed by the certificating authority of the country of registry" means that the details of the operating limitations specified by FAA (the certificating authority in the country of registry) take precedence. Those operating limitations make specific reference to the requirement for placards and markings but make no reference to the AFM. Why would the operating limitations pick out specific sections of part 91, and specific data from the AFM, for inclusion unless only those included references/restrictions were applicable? It would be far simpler to state that the aircraft is required to operate in accordance with Part 91. I'm very sure (based on FAA interpretations) if an E&R airworthiness certificate is issued for a glider which had a standard airworthiness certificate with AFM in it's country of origin, the mere issuance of a US E&R airworthiness certificate does not excuse the owner of the glider from compliance with the AFM. Can you please give me references to, or email copies of, any interpretation that requires compliance with the AFM when the operating limitations do not. Do those interpretations also relate to compliance with an approved maintenance manual? thanks Andy |
The debate on the merits and technicalities of winch launching will
rage on ad infinitum as it has for years in the winch newsgroups. However, in terms of winch safety the statistics for the UK and Germany are very different. Winch launching on the Continent shows a much lower accident rate than the British experience. In other cases a mishandling of statistics paints an out-of-focus picture. For example an article published in Soaring magazine a while back quoted statistics from a very small sample group to make a point about winch safety. The article was very much off-base and was a poor piece of work based on insufficient data. The German study, however, does appropriately apply statistical analysis to an appropriate sample size. I am surprised that no one has asked the question: Is it sensible to winch launch a 50-year old wooden glider, in which the type has had reported structural issues? A quick look at the UK winch accident records seems to involve a disproportionate number of old gliders and marginal winch equipment. Having flown at winch operations in both the UK and Germany, my limited experience has been that the Germans (generally speaking) are operating with better equipment than may be the case in the UK. (Yes, of course there are some operations in the UK with all the latest stuff and good procedures. But on the grand average maybe not as good as on the Continent.) So when the original question is asked, the first context should be – Really? Winch launching 50-year old wood wing gliders? Bob |
On Aug 15, 5:03*pm, RL wrote:
The debate on the merits and technicalities of winch launching will rage on ad infinitum as it has for years in the winch newsgroups. However, in terms of winch safety the statistics for the UK and Germany are very different. Winch launching on the Continent shows a much lower accident rate than the British experience. In other cases a mishandling of statistics paints an out-of-focus picture. For example an article published in Soaring magazine a while back quoted statistics from a very small sample group to make a point about winch safety. The article was very much off-base and was a poor piece of work based on insufficient data. *The German study, however, does appropriately apply statistical analysis to an appropriate sample size. I am surprised that no one has asked the question: Is it sensible to winch launch a 50-year old wooden glider, in which the type has had reported structural issues? * A quick look at the UK winch accident records seems to involve a disproportionate number of old gliders and marginal winch equipment. Having flown at winch operations in both the UK and Germany, my limited experience has been that the Germans (generally speaking) are operating with better equipment than may be the case in the UK. (Yes, of course there are some operations in the UK with all the latest stuff and good procedures. But on the grand average maybe not as good as on the Continent.) So when the original question is asked, the first context should be – Really? Winch launching 50-year old wood wing gliders? Bob If gliders are not capable of being winch launched using the correct weak link, they are not airworthy. We winch launch vintage gliders all the time in the UK as part of a very active Vintage Glider movement. Derek C |
rage on ad infinitum as it has for years in the winch newsgroups. However, in terms of winch safety the statistics for the UK and Germany are very different. Winch launching on the Continent shows a much lower accident rate than the British experience. In other cases a mishandling of statistics paints an out-of-focus picture. For example an article published in Soaring magazine a while back quoted statistics from a very small sample group to make a point about winch safety. The article was very much off-base and was a poor piece of work based on insufficient data. *The German study, however, does appropriately apply statistical analysis to an appropriate sample size. Glad you brought this up, I also didn't like that article. My main problem was less the sample data size, but rather the timeframe it represented. It lumps all the statistics going back to the 60s into single figures when it should really be separated into at least 2 or 3 different 'eras' for that same timeframe, when various gliding authorities and groups identified common problems and implemented standardized solutions that were game changers. Also, modern winches are orders of magnitude more powerful and more importantly quite controllable. That combined with material advances (UHMW etc) further separate modern winching from it's roots. Modern winching is pretty much a science and has come a long way since the 60s so it does not do the soaring community (US at least...) a favor to combine it all into single raw statistics cause it paints a negative biased picture based on irrelevant data. It would be like combining accident data from the era before seatbelts and airbags with modern car accident statistical data, and then using that to form statistics/articles to help potential future drivers decide how safe cars are. -Paul |
On Sun, 15 Aug 2010 10:29:49 -0700 (PDT), sisu1a
wrote: Modern winching is pretty much a science and has come a long way since the 60s so it does not do the soaring community (US at least...) a favor to combine it all into single raw statistics cause it paints a negative biased picture based on irrelevant data. Hmmm... I beg to differ. ![]() Modern winching has very much in common with winching in the 60s. The only difference is that the winches grew stronger in accordance to the rising weight and speed of the gliders, but otherwise -at least in Germany- very little has changed. Apart from the stronger engines the rest of the equipment as well as the procedures are still the same as fifty years ago. It is not necessary (Bill - I know you are going to cry out now ![]() have the latest state-of-the-art gizmos (telemetry, plastic cables, advanced speed control) to perform a perfectly safe and satisfactory winch launch. ![]() Cheers Andreas |
rest of the equipment as well as the procedures are still the same as fifty years ago. Here are some post 1960 hardware differences: (shooting from the hip... ![]() 1) standardized weak links (Tost system) 2) implementation and standardization of preamble/strop/trace 3) high aspect drums/doing away with level-winds 4) synthetic cables 5) much better control of torque/speed/launch profile 6) electric winch(es) While procedures may have remained pretty consistent in Germany (though adapted to accommodate newer hardware setups like strops, and some some for UHMW...) most everyone else seems to have been quite behind on the curve and continue to play catch-up; with some groups in doing it in distinct steps like the GFA writing a manual in 98 http://www.scribd.com/doc/24475893/Winch-Manual and BGA with their 'safe winch launch initiative started in 05 for instance: http://www.gliding.co.uk/bgainfo/saf...hlaunching.htm , which have changed SOP in those places as far as I can tell. Also up until quite recently, a complete mathematical model of the entire launch did not exist, only partial models. This information is (debatably) relevant to further hardware and procedural evolution as well, pushing it even closer towards science and further from it's trial and error past. Details aside, the point is if you look at 40-50yrs of winching as a generic lump sum the picture looks undeservedly bleak compared to looking at it by what is now commonly being done abroad, with Germany leading the way with a long record of safety and good procedures. (which I have a hard time imagining there being *some* changes in the last 50yrs of German winching though... ![]() -Paul |
On Aug 15, 1:21*pm, Andreas Maurer wrote:
On Sun, 15 Aug 2010 10:29:49 -0700 (PDT), sisu1a wrote: Modern winching is pretty much a science and has come a long way since the 60s so it does not do the soaring community (US at least...) a favor to combine it all into single raw statistics cause it paints a negative biased picture based on irrelevant data. * Hmmm... I beg to differ. ![]() Modern winching has very much in common with winching in the 60s. The only difference is that the winches grew stronger in accordance to the rising weight and speed of the gliders, but otherwise -at least in Germany- very little has changed. Apart from the stronger engines the rest of the equipment as well as the procedures are still the same as fifty years ago. It is not necessary (Bill - I know you are going to cry out now ![]() have the latest state-of-the-art gizmos (telemetry, plastic cables, advanced speed control) to perform a perfectly safe and satisfactory winch launch. ![]() Cheers Andreas Actually, I don't disagree. You don't need all new stuff to be safe but then you can drive a 1960's car and be safe too - as long as you're careful not to hit anything or get hit. It's a fact that people driving new cars with air bags and crush zones drive a lot more aggressively. That's basically what you get from the new winch designs. Easier, safer launches with greater performance. Dyneema is an exception. It has been proven safer than steel cable by every industry that has adopted it - there's lots of industrial safety data on that. Besides being safer, it's just way nicer to work with. |
On Aug 15, 8:21*pm, Andreas Maurer wrote:
On Sun, 15 Aug 2010 10:29:49 -0700 (PDT), sisu1a wrote: Modern winching is pretty much a science and has come a long way since the 60s so it does not do the soaring community (US at least...) a favor to combine it all into single raw statistics cause it paints a negative biased picture based on irrelevant data. * Hmmm... I beg to differ. ![]() Modern winching has very much in common with winching in the 60s. The only difference is that the winches grew stronger in accordance to the rising weight and speed of the gliders, but otherwise -at least in Germany- very little has changed. Apart from the stronger engines the rest of the equipment as well as the procedures are still the same as fifty years ago. It is not necessary (Bill - I know you are going to cry out now ![]() have the latest state-of-the-art gizmos (telemetry, plastic cables, advanced speed control) to perform a perfectly safe and satisfactory winch launch. ![]() Cheers Andreas I think that one of the most important safety changes we have made in the UK is the addition of 'Eventualities' to the pre-flight check list. That is to remind pilots to plan for the possibility of a launch failure and also applies to aerotows. No fancy computer controlled winches or other gizmos required. Derek C |
physics question about pull ups | John Rivers | Soaring | 59 | June 10th 10 12:21 PM |
FS: Wings&Wheels Wing Stand | James Hamilton[_2_] | Soaring | 0 | September 12th 09 01:15 AM |
Pull up a chair and hear me out: | Vaughn | Aviation Marketplace | 0 | February 2nd 06 02:04 AM |
Better GPS, Flight Computer, Variable Wing Geometry, abililty to Self-Launch | Stewart Kissel | Soaring | 7 | May 2nd 05 06:02 PM |
Glider pull-up and ballast | M B | Soaring | 0 | September 15th 03 06:29 PM |
