RANS S-9 Chaos loses a wing
  #11
Old August 19th 10, 09:05 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Morgans[_2_]
Default RANS S-9 Chaos loses a wing
"Oliver Arend" wrote
Even if you have a BRS installed, it is advisable to try an emergency
landing in a suitable field, since very likely the structure of the
airplane will suffer less damage. As someone pointed out, the airplane
comes down nose first, usually with a speed of about 5-6 m/s (15-20 ft/
s). That can break a lot of expensive stuff (prop, engine, fuselage).
Some airplanes, like Cirrius, have a harness that supports the aircraft, and
the aircraft comes down in a more or less level attitude. Are you saying
that your aircraft have the harness attatched to the aircraft so that it
always comes down nose first, or just that it will sometimes get tangled and
come down nose first?
It would seem like it would be a big advantage to come down level, for the
aircraft and the passengers.
Jim in NC
FAA falling further into chaos TheTruth[_2_] Piloting 2 March 12th 08 06:05 AM
Batavia Air 737 loses wing segment in flight BernieFlyer[_2_] Piloting 2 November 25th 07 10:05 AM
FAA Chaos MyCoxaFallen Piloting 12 June 6th 05 04:54 PM
DC Chaos, 9/11 and other assorted FAA diasters MyCoxaFallen Instrument Flight Rules 0 June 2nd 05 06:23 PM
