Trig TT21 Transponder ... reports?
Old August 20th 10, 03:26 AM posted to rec.aviation.soaring
Darryl Ramm
Default Trig TT21 Transponder ... reports?
On Aug 19, 6:19*pm, Darryl Ramm wrote:
On Aug 19, 8:19*am, Mike Schumann
[snip]
BTW I don't want to get sidetracked here but the current USA rules
have not kept track with technology and as a result are strange in how
they do not for example strictly prohibit an ADS-B traffic receiver
(since it is not a "two-way communication device"), but by banning
"two-way communication devices" they do currently prohibit Flarm based
devices. As Dave says I suspect the rules committee understand the
issues.
Well darn I did get myself well sidetracked by typing this too fast. I
meant to say that I think actual interpretation of the USA contest
rules are strictly ambiguous. e.g. allowing two-way communication
products that report position but not being clear whether that means
reporting position our of the glider or into the glider or both. And
an ADS-B receiver to use ADS-B direct data from other aircraft is
currently allowed since it is not a two-way communication device.
Anyhow clear that the contest rules folks need to work on cleaning up
the rues whatever the future intent is.
[snip]
Darryl
Old August 20th 10, 02:04 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Thu, 19 Aug 2010 18:19:24 -0700, Darryl Ramm wrote:
BTW I don't want to get sidetracked here but the current USA rules have
not kept track with technology and as a result are strange in how they
do not for example strictly prohibit an ADS-B traffic receiver (since it
is not a "two-way communication device"), but by banning "two-way
communication devices" they do currently prohibit Flarm based devices.
I'm realising there is another passive collision warning system that we
use in the UK but I think may not be used as such in the USA - NOTAMS.
Whenever there's something happening here that raises a significant
collision risk such as a balloon festival, gliding competition or
microlite rally it will be NOTAMed, giving the base airfield, number of
participants and the area where significant numbers of participating
aircraft may be found. This at least warns other pilots to be more
vigilant in that area.
I've noticed that NOTAMs seem to be much less used in the USA than they
are here, so I'm wondering if your Regionals and national competitions
are routinely NOTAMed.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 21st 10, 04:19 AM posted to rec.aviation.soaring
Brian Whatcott
Anecdotally....a preliminary flight plan I did a month or two ago for
Corpus Christi from Altus (SW Oklahoma) as depicted on sectionals using
that handy service fltplan.com showed up with a flag because it crossed
close by an airfield south of Dallas marked for an air display via a NOTAM.
This approach beats paper modems easily - the planning service shows
only NOTAMS relevant to the track...
Brian W
Old August 23rd 10, 12:42 AM posted to rec.aviation.soaring
devices.
NOTAM.
Fighting through a wad of paper is a nightmare. I'd be lost without my
copy of NOTAMplot though I still have to read the unplottable ones. These
days AIS, our official NOTAM source, manages to weed the stack to a
mangeable size, but still doesn't plot them, and in consequence doesn't
really help us glider drivers because you can only anchor its route
briefings to licensed airfields, when we really need something like
NOTAMplot, which understands turnpoints.
org |
Trig TT21 transponder draws only 125 mA! Steve Koerner Soaring 5 March 15th 10 09:59 PM
TRIG TT21 Transponders Tim Mara[_2_] Soaring 12 September 26th 09 02:01 AM
Trig TT21 Transponder receives FAA TSO approval Paul Remde Soaring 12 September 19th 09 02:47 PM
Trig TT21 in Experimental Aircraft Paul Remde Soaring 5 July 5th 09 03:15 AM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 04:38 PM
