On Aug 23, 7:02*am, Andy wrote:
On Aug 23, 6:40*am, "kirk.stant" wrote: Required L/D to target tells you what you need to achieve. It makes no sense to fold wind into that, its just the distance divided by the difference in height. Achieved L/D tells you what you are getting obviously with wind affects as well, all without any assumptions about polars, mass, bugs, or wind. That is the beauty of working with L/D required and achieved. But even better than asking on r.a.s. can you find a local accomplished XC pilot(s) who can mentor you on all this stuff? Darryl- Darry is spot on. *I would go a little further and dispense with the Achieved L/D - I just use L/D required and watch for the trend: if it is getting better (lower L/D required) then you are gaining on the glide and can either speed up or relax more. *If it's getting worse, or not changing and looks a bit high (say more than half your published L/D), then *you need to stop and get some altitude. *That takes care of the wind, bugs, etc. Totally agree with getting rid of all the navboxes that are "info only" - unless your PDA is hooked up to a 302 and getting air data, using GPS for fancy speed to fly info is a distraction. *Use it as a digital sectional, with your task, airspace, and landable fields (with L/D required) on it, and in most cases turn off the terrain (exception is in ridge country where the terrain can be really useful). *Less is more! Cheers, Kirk 66 I generally use arrival altitude for everything, especially final glide. *That way I know how much I need to climb to get to my goal and wind is accounted for automatically in the computer. I typically program in 1,000' for arrival altitude and speed up/slow down depending on whether the arrival height is building or declining. Typically I dial in 4 knots for the computation because it corresponds to a typical cruise speed. I try not to set below 3 knots unless it's a last resort. Except on very long glides low Mc settings just don't yield enough glide angle margin - a little sink and you're at best L/D or can't make it at all. 9B I do the same with arrival altitude, only am more conservative than Andy. I increase or decrease MacCready accordingly. It seems the only rational piece of data you need - arrival altitudes of less than zero are likely to be less than useful. Mike |
I.D required | Glenn[_2_] | Aviation Photos | 8 | November 12th 08 10:22 PM |
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione | Steve Leonard | Soaring | 2 | September 14th 05 03:49 AM |
There is no penalty for failing to make the required FAA reports or investigation! | Larry Dighera | Piloting | 9 | October 12th 04 04:06 AM |
New Home Required | Ged McKnight | Soaring | 0 | February 1st 04 08:11 PM |
Good Home Required | Ged McKnight | Soaring | 6 | January 27th 04 10:00 PM |
