Antique 3 cyl 4 stroke radial engine used in an aircraft circa 1930s?
Old August 18th 10, 10:29 PM posted to rec.aviation.homebuilt
Stu Fields
Default Antique 3 cyl 4 stroke radial engine used in an aircraft circa 1930s?
I've seen what is purported to be an Indian 3 cyl radial engine that was
used on an aircraft. The cylinders appear to be Indian motorcycle cylinders
of the late 20s?? Anyone out there with and data on this??
Stu Fields
Experimental Helo Magazine
Old August 18th 10, 11:33 PM posted to rec.aviation.homebuilt
Scott[_7_]
Default Antique 3 cyl 4 stroke radial engine used in an aircraft circa1930s?
Stu Fields
It's not an Anzani or Salmson, is it? Something like 45 HP or so?
They had used the Salmson on the Corben Aces back in the 30s.
Old August 19th 10, 07:53 AM posted to rec.aviation.homebuilt
Bob Murray
There was a Lenape "Papoose", even found on some early Cubs.
Old August 23rd 10, 01:21 AM posted to rec.aviation.homebuilt
John[_9_]
Szekely?
Old August 23rd 10, 03:54 AM posted to rec.aviation.homebuilt
Stu Fields
"John" wrote in message
Szekely?
No, as I recall the Szekely had exposed rockers that had to be oiled by hand
prior to flight. My Uncle had a Buhl Pup with the Szekely.
The engine I saw had cylinders believed to come from an Indian MC.
Old August 23rd 10, 04:14 AM posted to rec.aviation.homebuilt
Bob Murray
"Stu Fields" wrote in message
Szekely?
hand prior to flight. My Uncle had a Buhl Pup with the Szekely.
May have been a homebrew. All the Indians that I know about were
flatheads,.
Bob
Old August 23rd 10, 11:22 PM posted to rec.aviation.homebuilt
xlch58
Szekely?
hand prior to flight. *My Uncle had a Buhl Pup with the Szekely.
May have been a homebrew. *All the Indians that I know about were
flatheads,.
Bob
The old flying and glider mags had plans for a three cylinder
Harley. Someone may have adapted it to Indian jugs. Indians were
flatheads, but the OP never stated OHV. There were conversions back
in the day and a few factory race bikes had OHV I think. In the
thirties there were a number of production three cylinder radials,
after the war they were all gone, as the opposed cylinder engine
displaced everything else in the small engine category and the turbine
ate up the big engine category.
Charles
Charles
Old September 22nd 10, 08:25 PM posted to rec.aviation.homebuilt
wright1902glider
flatheads,.
Bob
Stu,
What was the cylinder spacing? 120 degrees or 45? Was this an intake-
over-exhaust, flathead, or OHV?
The 3-cyl Anzanis would have been 45-45-45 "W" config. with intake-
over-exhaust valving. They would be from the Bleriot era 1910-1915. If
it is a one-off it may also date to the same era. I'd ping the boys at
Old Rhinebeck and see if they know what it is.
Harry Frey
DIY Two-Stroke Engine Construction Methods durabol[_2_] Home Built 68 April 16th 10 03:24 AM
DIY Two-Stroke Engine durabol[_2_] Home Built 55 April 5th 10 05:11 PM
Need Pic of a Bates 4-cylinder HO engine, circa 1912 [email protected] Aviation Photos 1 June 6th 08 02:44 AM
Small 4 stroke engine? Ron Wanttaja Home Built 35 July 2nd 05 07:25 PM
radial engine Randy Aviation Marketplace 2 December 3rd 03 02:28 PM
