required LD versus required MC to make it home ??
Old August 23rd 10, 09:14 PM posted to rec.aviation.soaring
johngalloway[_2_]
Default required LD versus required MC to make it home ??
How I use SeeYou mobile for final glides (when I get a chance to do
them):
With my chosen arrival altitude and my/or the computer's best
estimates of the wind set, then in the likely last thermal I use the
usual McCready/Cochrane considerations plus my personal wimp factor
to decide when to leave the thermal and to judge an appropriate
starting McCready setting. This is just to get in the ballpark of
when to start the glide.
Next, as I start the glide I take note of the required LD (SYM
calculates this to the arrival altitude) and as long as this number
stays the same or gets smaller then I am on glide or can speed up
respectively. If the number gets bigger I have to slow down or
climb. The required LD is wrongly named in SYM - it is actually the
glide angle with respect to the ground. All glide angles converge at
the destination so any glide angle that I can keep constant will
bring me to home at my arrival reserve altitude. This is independent
of any errors in wind/polar/bugs. I never have understood why most
glide calculators seem to work on altitude difference displays
resulting glides vertically parallel to the starting glide angle when
proportionately less altitude difference is required as one gets
closer to the destination.
(I don't find that the method recommended in the SYM manual of
comparing Achieved LD with Required LD is any good because the
Achieved LD varies so much in a much shorter time scale.)
John Galloway
Old August 24th 10, 04:11 AM posted to rec.aviation.soaring
Andy[_1_]
With the very, very, big caveat that there is no intervening terrain.
There is actually significant potential for advancement in gliding
computers. That is the display of a vertical profile view of the final
glide, complete with terrain. This display is known as the VSD
(Vertical Situation Display) in some non gliding display
applications. This type of display can clearly depict a multi-angle
final glide path when that is required to clear terrain and also make
the goal at the required finish altitude.
I suspect that this type of display would also be very useful for
understanding the effect on glide path and optimum MC when there is a
significant wind change when rounding the final turnpoint.
Andy (GY)
Old August 24th 10, 03:44 PM posted to rec.aviation.soaring
akiley
the destination *so any glide angle that I can keep constant will
glide, complete with terrain. *This display is known as the VSD
applications. *This type of display can clearly depict a multi-angle
Andy (GY)
I use Condor soaring simulator with my iPaq running from the serial
port. It's a great way to test if/then situations and to get familiar
with your navigator. One interesting way of looking at terrain is
also the program XC-Soar. It draws a dotted, terrain aware, wind
aware, polar aware circle around your current position that indicates
the terrain strike point at your current MC. For terrain, this dotted
line spills into other valley's through lower gaps and valleys. Also
SeeYou has a red box on the course line indicating any ridge you will
hit before reaching you destination. You can run somewhat parallel to
this ridge way before you get to it and if SeeYou finds a gap, the red
box disappears and you can proceed direct. akiley
Old August 24th 10, 04:24 PM posted to rec.aviation.soaring
mattm[_2_]
Andy (GY)
Personally I love the SoarPilot final glide table. There's a picture
of it at
http://www.soaringpilot.org/dokuwiki...l_glide_screen
It displays a table of MC settings (values 0-5, or 0-10 by 2) along
with
the speed to fly and a choice of arrival altitude, required altitude,
or
difference from glide slope. I find it very easy to follow on final
glide --
if I'm picking up energy I can see how fast I can fly and still
arrive,
or if I'm losing energy I can see how much I need to slow up and still
make it back.
The only problem with SoarPilot is that it runs on PalmOS,
which goes on outdated hardware these days. There's a version of
StyleTap that runs on the iPhone, but there's no serial port or
bluetooth
to connect it to any other devices in your plane. I don't know if
anyone
has gotten it to work on the PNDs that are being used nowadays.
-- Matt
I.D required Glenn[_2_] Aviation Photos 8 November 12th 08 10:22 PM
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione Steve Leonard Soaring 2 September 14th 05 03:49 AM
There is no penalty for failing to make the required FAA reports or investigation! Larry Dighera Piloting 9 October 12th 04 04:06 AM
New Home Required Ged McKnight Soaring 0 February 1st 04 08:11 PM
Good Home Required Ged McKnight Soaring 6 January 27th 04 10:00 PM
