On Aug 24, 10:32*pm, Ramy wrote:
On Aug 24, 5:16*pm, Darryl Ramm wrote: On Aug 24, 5:06*pm, Ramy wrote: On Aug 24, 2:54*pm, mattm wrote: On Aug 24, 4:44*pm, Ramy wrote: On Aug 24, 1:11*pm, mattm wrote: Reichmann points out that MC 1 is a better setting if you are in desparation mode, because you give up only a little glide distance but you get to sample more air in a given time. Are you sure about that? MC=0 will give you more time and more air to sample (beeing the best L/D speed) than MC=1. I always use MC=0 when I switch to survival mode unless I am also battling significant head wind. Ramy Yes, it's true. *It's on the last page of this paper:http://www.dragonnorth.com/djpresent...training_for_c... "A lot of pilots flew and fly unnecessarily low average speeds when they get low, because they are anxious and fly with a zero setting. They don’t know that with a setting at 1 knot they have almost the same glide angle and lose much less average speed in case they recover and complete the task." In my plane (ASW-19) MC=0 speed is 53kts, and L/D is 38:1. MC=1 speed is 61kts, and L/D is 35:1. *Granted my sink rate is about 30fpm faster, but I'll have almost 20% greater range to find that thermal I need to get back up again. -- Matt Matt I'm afraid you missunderstood Reichmann comment. He claimed that you will lose less average speed with MC1 which is true. But you will not gain 20% greater range. On the contrary, Your search range will always be less if you fly faster than MC=0 (unless you have significant head wind which requires flying faster than best L/D). Bottom line, as other pointed out, it all depends on your goal. If you are flying contest, in which every second counts, then flying correct MC is important. If you fly for OLC or distance, like I believe the majority of XC flights are, and your main objection is to make it back home at the end of the day (as the subject lline says), than fly *MC 0 when you are in survival mode or starting your final glide. Ramy But, but, but, (and I think I can hear John Cochrane pounding his head on his desk in Chicago...) when about to go on final glide and you are in that last thermal you know what the theoretical final glide Mc should be. And by all means factor in safety margins but if you have a climb significantly over your Mc="0" value then keep climbing and bump the Mc appropriately to match that climb. I mean why not? I know sometimes pilots like to float past the home airport and stretch a few more OLC miles then turn back. Personally the call of that cold beer makes me want to fly that final glide as fast as possible. What is really annoying about arguing with Ramy on this point (which I think I've done before) is no matter what I can argue on paper I have no hope of keeping up with him in practice. Sigh Darryl- Hide quoted text - - Show quoted text - Funny, I guess I can fly better than I can explain myself :-) All I am trying to say about the final glide is that if you are not competing (or competing against the sun as in my case sometimes) the exact speed you fly on your final glide wouldn't matter much. And instead of dialing MC according to your last climb to determine when to leave the thermal and then ignore this MC on your glide if you want to ensure you get back home even with no lift, just degrade your polar instead, climb as high as you feel comfortable, then fly as fast as you can without loosing glide. Simple. Of course while on course and high crank up the MC as high as you dare, just make sure you stay in the desired lift band. But honestly, I don't understand how many of you fly XC safely if you don't degrade your polar. How do you determine you are within safe glide from airports at any point in time? using your published polar and a safety altitude margin? Good luck if you hit any sink or head wind on the way unless you use a big altitude margin which will significantly hurt your decision down lower. The suggestion to use bug factor to degrade your polar is basically an implementation of the common rule of thumb to use 50%-75% of your published polar to determine arrival altitude. Ramy Within safe glide to an airport at any one time? What a concept! |
I.D required | Glenn[_2_] | Aviation Photos | 8 | November 12th 08 10:22 PM |
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione | Steve Leonard | Soaring | 2 | September 14th 05 03:49 AM |
There is no penalty for failing to make the required FAA reports or investigation! | Larry Dighera | Piloting | 9 | October 12th 04 04:06 AM |
New Home Required | Ged McKnight | Soaring | 0 | February 1st 04 08:11 PM |
Good Home Required | Ged McKnight | Soaring | 6 | January 27th 04 10:00 PM |
