On Aug 27, 10:25*am, mattm wrote:
On Aug 27, 1:36*am, Eric Greenwell wrote: On 8/26/2010 7:16 PM, akiley wrote: I mean clear the winds totally in SeeYou then enter the official winds aloft forecast. *Maybe SeeYou does a better job, I haven't really tested this. *I just look at my IGC file from this Wednesday and the winds were supposed to be 320 at 12kts in the 3000 to 6000 range. *At a few points spanning several minutes, SeeYou came back with winds from 160 at 2 kts. * But maybe this happens and is to be believed. *Or I'm really bad a drawing circles with a glider. *Probably the later.. I always let Mobile fill in the blanks. It does a good job of measuring the wind while circling, so I think it's better to use the actual wind instead of a forecast wind; less trouble, too. I will sometimes change the wind settings when I know I am flying into an area where the wind is different from what Mobile has measured. This is usually the final glide to the home airport, and since I haven't flown near home for the last few hours, the wind it measured after the takeoff and the first couple of thermals as I headed out on course may no longer be correct. I bought this used iPaq which was listed as a 3700 on the reciept from Wings and Wheels. *Just out of warrantee. *The label is worn and unreadable on the back. *Don't know of a software way to positively ID the unit. *It uses the CF cards and an add-on sleeve adapter to hold the CF card. *I have the slightly newer SeeYou Mobil ver 3.12. *I have had lots of IGC files with broken track or perfectly straight lines or both. *Also, I have to reboot my iPaq on a daily basis. *Not sure if I replace the iPaq next or the GPS. *I did get an uninterrupted file this wednesday on a 2.5 hr flight in the Cirrus. Mobile for PDAs is a mature, stable program. These problems are almost certainly hardware related. Can you borrow another Ipaq for a flight or two? I just have the navBox called "Magnetic track over ground" at the top center used as a heading indicator, even though it really is'nt. Unless you are really in love with magnetic bearings, I suggest you switch to "track over ground" to use True bearings instead. -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz I agree this may be a hardware problem. *What are you using for a GPS source? It may be losing lock periodically when you bank. -- Matt It's a GlobalSat BR-355 which I think is referred to as a mouse style GPS that plus into the bottom of my iPaq 3700. If it was always loosing a signal I would suspect that, but I don't have a really concrete set of errors that point to any one thing. Intermittent and varied issues I would describe it as. These have included the iPaq suddenly wanting to reformat my CF card, intermittant NavBox problems, usually showing data not available. Log file not stopping after landing, log file not starting at all. Daily reboots usually required when SeeYouM does not load. Some of these problems could have been the CF card sleeve which I replaced a few weeks back because I seems to be getting good uninterrupted IGC files now. Today, I'm borrowing a friends iPaq, trouble it I have to order an adapter cord so my mouse GPS can plug into it. I think iPaq changed the plug in the bottom at some point. ... akiley |
On 8/28/2010 7:06 AM, akiley wrote:
It's a GlobalSat BR-355 which I think is referred to as a mouse style GPS that plus into the bottom of my iPaq 3700. If it was always loosing a signal I would suspect that, but I don't have a really concrete set of errors that point to any one thing. Intermittent and varied issues I would describe it as. These have included the iPaq suddenly wanting to reformat my CF card, intermittant NavBox problems, usually showing data not available. Log file not stopping after landing, log file not starting at all. Daily reboots usually required when SeeYouM does not load. Some of these problems could have been the CF card sleeve which I replaced a few weeks back because I seems to be getting good uninterrupted IGC files now. Today, I'm borrowing a friends iPaq, trouble it I have to order an adapter cord so my mouse GPS can plug into it. I think iPaq changed the plug in the bottom at some point. ... akiley I suspect an Ipaq with a built-in slot would be inherently more reliable. The two I've used - 3830 and 2210 - had slots, and both worked without problems. Let us know how the new iPaq works out. -- Eric Greenwell - Washington State, USA (netto to net to email me) |
On Sat, 28 Aug 2010 07:06:45 -0700, akiley wrote:
-- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
I.D required | Glenn[_2_] | Aviation Photos | 8 | November 12th 08 10:22 PM |
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione | Steve Leonard | Soaring | 2 | September 14th 05 03:49 AM |
There is no penalty for failing to make the required FAA reports or investigation! | Larry Dighera | Piloting | 9 | October 12th 04 04:06 AM |
New Home Required | Ged McKnight | Soaring | 0 | February 1st 04 08:11 PM |
Good Home Required | Ged McKnight | Soaring | 6 | January 27th 04 10:00 PM |
