FAA Medical Question
Old September 1st 10, 07:42 PM posted to rec.aviation.piloting
Default FAA Medical Question
On Sep 1, 11:38Â*am, wrote:
IMHO for private and below I agree.
There already exists the obligation to self certify before each flight
and there is nothing that requires one to run to a doctor to get evaluated
when you get sick or injured.
Agree and this applies to sports as well to PPL.
What I would propose is that the FAA medical exam for private and below
be replaced with a requirement to get a physical from a real doctor, any
doctor, once a year, which everyone should do anyway, and based on that
you self certify your general fitness to fly.
My take has always been, the damage on the ground will most likely be
the same whether it be a 110 hp plane or a 180. So, why not convert
the medical requirement based on equipment rather then certificate
type would be my take. (I see you said this later on)
As a bonus, most insurance will pay for an ordinary physical but not a
FAA physical.
Very true, but in my case, since I never have been the doctoring type,
my medicals every two years have been "life saving" literally and
figuratively. What you suggest essentially would cost me twice as
much since I never meet my insurance deductable.
Since my FAA physical is coming up soon I got a normal physical to insure
would be no surprises.
That, cash basis, cost me all of $80, which is not much of an adder to the
cost of flying.
Lab work can cost a lot more, but isn't a part of the FAA physical, so
that would be at your discretion based on what your doctor says.
And, FWIW, I opted for lab work which found a couple of things the FAA
medical would never find and doesn't care about but I do.
I'm on the fence where some ratings are involved as in should the current
FAA medical requirement be kept to hold and exercise ratings such as IFR,
jets or over 12,000 pounds.
Yep, was replying as I was reading, so yes, as I said above (and you),
more logical to base the medical requirement on equipment being
operated.
Jim Pennino
Remove .spam.sux to reply.
Old September 1st 10, 10:30 PM posted to rec.aviation.piloting
vaughn[_3_]
Good for you! But one could argue that it would be better to get that
private physical *AFTER* your FAA physical.
Why? Because there can be considerable difference between the disease
definitions your doctor uses and those contained in FAA regulations. In
particular, the thresholds for blood pressure and blood sugar have been
generally lowered over the years, while the FAA definitions have remained
unchanged. For example: if your doctor diagnoses you with type 2 diabetes, you
will be required to report that on your medical application and then you will be
required to jump through the appropriate hoops to get your medical, even though
you may (probably will) pass the AME's very crude urine-based blood sugar test.
Vaughn
Old September 1st 10, 10:50 PM posted to rec.aviation.piloting
* *Good for you! *But one could argue that it would be better to get that
Good point Vaughn.
Case in point with me. Had DVT which required the use of blood
thinners. By the time I got to my medical I was NOT on the
medication. But the question on the form does ask if you had any
vascular problems (or something to that effect) since the last exam.
I could have easily said no as I wasn't on my last medical and I
wasn't during this last exam. I did the right thing and reported it.
This put a 2 month delay on my medical even though I came in with the
proper INR and prognosis documentation per AOPA guidance AND I started
the medical process a month before expiration.
I don't see the FAA medical exam being a strict exam even though I had
this inconvenience..
In a nutshell for a class three certification, they check your vision,
hearing and pee to meet minimum requirements and depend on the pilot
to be upfront and honest about any other conditions. The actual exam
is not strict by any standards. (so much for Mx's knowledge of this
process)
In my case and I have posted this in the past, my past class three
exams revealed pre-melanoma on one exam and extreme high blood
pressure (210 over 170) on another exam and I was flying the day
before the exam with this blood pressure asymptomatic.
Neither of the above prevented me from flying AFTER I came up with the
appropriate documentation to recertify my medical.
Even with me seeing a doctor once a year, I am all for the FAA exam as
my current doctor doesn't check my vision or hearing.
Old September 1st 10, 11:20 PM posted to rec.aviation.piloting
Â* Â*Good for you! Â*But one could argue that it would be better to get that
Good point Vaughn.
process)
If your doctor doesn't check what you ask him to check, nor give you
a recommendation on what needs to be checked, find another doctor.
I told the doctor exactly why I was there and what I wanted checked.
His recommendation was while I was there and am over 50 to get a prostate
check and a basic blood panel, both of which sounded like a good idea to
me.
Jim Pennino
Old September 1st 10, 11:01 PM posted to rec.aviation.piloting
a[_3_]
Why? *Because there can be considerable difference between the disease
definitions your doctor uses and those contained in FAA regulations. *In
unchanged. *For example: if your doctor diagnoses you with type 2 diabetes, you
Vaughn
An interesting ethics question would be, what would you have done if
your 'ordinary' physical would have disclosed something that would
have prevented you from passing the FAA one?
Old September 1st 10, 11:23 PM posted to rec.aviation.piloting
Why? Â*Because there can be considerable difference between the disease
definitions your doctor uses and those contained in FAA regulations. Â*In
unchanged. Â*For example: if your doctor diagnoses you with type 2 diabetes, you
Vaughn
In my case I had already decided; sell the Tiger and buy a LSA assuming
whatever it was didn't mean flying would be stupid, like an aneurism that
could blow at any time.
Jim Pennino
Old September 1st 10, 11:15 PM posted to rec.aviation.piloting
Vaughn
I got the private physical 6 months before the FAA physical because that
would give me plenty of time to take care of any issues per the FAA
requirements.
It doesn't matter to the FAA what your doctor calls something, what matters
is numbers, as in your doctor can say you have high blood pressure but the
only thing the FAA cares about is that it is under 155.
Also, as you get older and don't take a private physical first, there is the
chance you will be denied and there goes everything, including Sport Pilot.
Jim Pennino
Old September 1st 10, 11:31 PM posted to rec.aviation.piloting
vaughn[_3_]
I am not sure that is true; are you? The question on form 2120-0034 is: "HAVE
YOU EVER IN YOUR LIFE BEEN DIAGNOSED...". You have only two blocks to check for
each listed condition: "Yes" or "No". If you check "Yes", it is up to your AME
to resolve to issue as per FAA guidlines, or deny you. My point is that the
thresholds that your doctor uses are subject to change based on current
research, and they are likely not the same thresholds found in FAA regulations.
Yes, and that might well play into your decision to get a prior physical...or
not. If you happen to be a professional pilot, Sport Pilot privaleges may not
be terribly important to you.
FYI Myself, I see my doctor regularly. I wat to keep flying, but continuing to
live is even more important to me.
Vaughn
Question on the medical... Richard Piloting 25 March 29th 06 04:41 PM
Yet another medical question Rachel Piloting 13 February 5th 06 10:44 PM
Medical question Michael Piloting 10 December 7th 05 06:58 PM
FAA medical question G. Sylvester Piloting 17 March 12th 05 11:13 AM
Question Medical Captain Wubba Piloting 5 June 11th 04 05:12 AM
